    Pi Zero W - Retropie - Gamepad problems
    pi zero wgamepad
    2 Posts 2 Posters 542 Views
    • F
      frobi
      Hello everybody,
      i have recently added a Pi Zero W and retracted it.
      My problem is that when I connect my gamepad via USB (http://amzn.to/2pKfZVr), this does not react after a short time. It usually takes only a few minutes.
      With a keyboard via USB (Mac) there are no problems.
      Can someone give me a tip why? Or are more info needed?
      Many Thanks!
      Greeting,
      frobi
        mediamogul Global Moderator @frobi
        @frobi
        Topic moved to 'Help and Support'
        Have you tried any other controllers? Also, more information on your setup and usage would help. The necessary information is found at:
