    NES Advantage controller won't map correctly
    nes advantagecustom pipi zerocontrollersgpio
    18 Posts 6 Posters 5.2k Views
    • allenpieA
      allenpie
      https://en.wikipedia.org/wiki/NES_Advantage
      I have 4.2 and I Pi zero I have it all solder correctly
      I have it detected as SNES Pad
      https://github.com/RetroPie/RetroPie-Setup/wiki/GPIO-Modules
      I have the SNES Drivers and GamePad Drivers installed
      No matter what I do I can' get my A and B Buttons to work correctly. I can switch them and one will always never work.
      it's mostly the B button ie jump in NES games
      I'm setting it up in Emulation Station with the Configuration Tool and I'm 98% done just can't get my A and B buttons to map correctly. The buttons are set but no matter what won't work in game. B will go back and a will go forward in the menu but in game it's not the same. I'm going to try to manually set up the controller in retroarch via select.
      But here is the kicker
      The Switch from player 1 to player 2 act's as the b button even tho I never mapped it. Each time I make a map even setting up the player 1 player 2 switch it will always be the B button. Even if it's mapped or not.
      See the controller here
      http://www.instructables.com/id/How-to-Clean-and-Repair-an-NES-Advantage/
      See Pic Here
      Any one ever messed with this or have any other way's I can fix this issue?
      Retro Pie and Chill
      edmaul69E mediamogulM 2 Replies Last reply Reply Quote 0
        edmaul69 @allenpie
        @allenpie not sure if the gpio is the same but most adapters say they aren't compatible with an nes advantage. There are some that are. But the snes gpio setup might not be.
          mediamogul Global Moderator @allenpie
          @allenpie
          Moved to 'Help and Support'.
            SuperSirLink
            @allenpie said in NES Advantage controller won't map correctly:
            The NES advantage works on my setup, I have NES sockets wired to a GPIO adapter v1 from PetrockBlog and I am using SNESdev for the driver...
            Might want to try the SNESdev driver...
            • allenpieA
              allenpie
              @SuperSirLink said in NES Advantage controller won't map correctly:
              SNESdev drive
              I am running the SNESdev drive as I have it setup for 2 player
              Both work and it detects as a SNES PAD
              Still having the same issue I can't map the B button correctly.
              Retro Pie and Chill
                SuperSirLink
                Are you using a GPIO adapter or a control block, or did you solder the pins straight to the Pi?
                What about jstest, does it register all the buttons?
                http://blog.petrockblock.com/2012/10/21/the-retropie-gpio-adapter/
                allenpieA 1 Reply Last reply Reply Quote 0
                • allenpieA
                  allenpie @SuperSirLink
                  @SuperSirLink I solder the pins straight to the pi zero
                  Retro Pie and Chill
                  • allenpieA
                    allenpie
                    Giving this a shot now
                    Installation and Troubleshooting
                    You can find a complete getting-started guide for the RetroPie GPIO Adapter on this page.
                    With the SNESDev driver enabled you can test for working connections between the game pads and the RPi with the jstest command (Ctrl+C exits the tool):
                    jstest /dev/input/js0
                    and
                    jstest /dev/input/js1
                    Retro Pie and Chill
                    • allenpieA
                      allenpie
                      ![0_1494615924282_log.jpg](Uploading 100%) ![0_1494615933528_log.jpg](Uploading 100%)
                      Retro Pie and Chill
                      • allenpieA
                        allenpie
                        http://imgur.com/a/afJD2
                        Screen shot
                        Retro Pie and Chill
                        • allenpieA
                          allenpie
                          It's funny cuz in the main menu's both my a and b keys work but when i run a NES game it's player 1 player 2 switch as B
                          Not sure why
                          Retro Pie and Chill
                            SuperSirLink
                            disable the retroarch controller auto config... Take the inputs that jstest gives you for each number and put that in the retroarch config...
                            I use different configs per system, since I have NES sockets, but leave the controller set as SNES... That way I can use an NES to SNES adapter and set inputs for SNES separately...
                            Here is mine for NES:
                            # Input device buttons.
                            # Figure these out by using RetroArch-Phoenix or retroarch-joyconfig.
                            # You can use joypad hats with hnxx, where n is the hat, and xx is a string representing direction.
                            # E.g. "h0up"
                            input_player1_b_btn = 3
                            input_player1_a_btn = 1
                            input_player1_start_btn = 7
                            input_player1_select_btn = 6
                            input_player2_b_btn = 3
                            input_player2_a_btn = 1
                            input_player2_start_btn = 7
                            input_player2_select_btn = 6
                            # Axis for RetroArch D-Pad.
                            # Needs to be either '+' or '-' in the first character signaling either positive or negative direction of the axis, then the axis number.
                            # Do note that every other input option has the corresponding _btn and _axis binds as well; they are omitted here for clarity.
                            input_player1_left_axis = -0
                            input_player1_right_axis = +0
                            input_player1_up_axis = -1
                            input_player1_down_axis = +1
                            input_player2_left_axis = -0
                            input_player2_right_axis = +0
                            input_player2_up_axis = -1
                            input_player2_down_axis = +1
                            • allenpieA
                              allenpie
                              I have these inputs Take the inputs that jstest gives you for each number and put that in the retroarch config
                              I have done this whats the best way to disable the retroarch controller auto config from starting?
                              \retropie\configs\all\autoconf.cfg
                              I set it to disabled
                              Retro Pie and Chill
                              • allenpieA
                                allenpie
                                SuperSirLink I LOVE YOu man!
                                It's working great now such a simple FIX thanks so much for the HELP!
                                Retro Pie and Chill
                                  SuperSirLink
                                  Sweet! glad I could help... For some strange reason I never had much luck with the auto config... Didn't see your particular issue, some other oddities between my NES controllers and the SNES controllers via the adapter... Though I never tried the NES advantage on my setup with the auto config enabled...
                                  Glad you got it working!
                                  • chipsnblipC
                                    chipsnblip
                                    does the Advantage work completely, ie. turbo buttons/dials and slow-mo etc? i'm thinking about wiring mine up like this
                                      SuperSirLink @chipsnblip
                                      @chipsnblip
                                      Yes, it does... I actually use mine across multiple emulators... Even Atari 2600, though the turbo doesn't work for Atari and the B button is the main button...
                                      • F
                                        fsd2s
                                        I successfully am using an NES Advantage on RetroPie 4.2.3
                                        I have an NES to USB Adapter plugged into the Raspberry and connect the NES Advantage to the adapter.
                                        I do notice a problem when I boot the Raspberry Pi and the NES Advantage has the SLOW button turned on. The Pi also did not detect the controller the first time when I had the SLOW button turned on. With the SLOW and TURBO buttons turned off the Pi detects the controller without any problem. Then when I load and start playing a game I can turn the SLOW and TURBO buttons on or off without problem. For me, it seems only when the Pi is booting that I cannot have the TURBO and SLOW buttons on or else the controller does not work (I also get stuck on EMULATION STATION LOADING screen when booting up with the SLOW button turned on).
