    [SOLVED] lr-ppsspp emulator does not work, please help !!
    pspnot working
    48 Posts 5 Posters 27.4k Views
      darthlink
      I had install previously ppsspp and i had downloaded the rom little big planet for psp and i added it to the psp folder in retropie. When i start retropie, the psp emulator does not even show. So i installed lr-ppsspp but got the same result. Then i uninstalled both and only re-installed lr-ppsspp but still the same thing, no psp in the menu where all my other console are. The rom is a .iso file
      Please need help to have the psp emulator working ??
      DarkWolfD 1 Reply Last reply Reply Quote 0
      • DarkWolfD
        DarkWolf @darthlink
        @darthlink
        Check this:
        • the parse gamelists only option is turned off
        • is the emulator installed
        • your roms are in the right folder
        • your roms have one of these extension .iso / .cso / .pbp
        • you rebooted your pi
        If it isn't showing up after checking the steps:
        This method is not recommended!
        It could be the case that the systems configuration file wasn't updated.
        If this is the case the psp system will not show up in the system carousel.
        You have to add it manualy to the es_system.cfg
        Here is how you do it:
        1. Connect via ssh
          2.a If you don't have a modified es_system.cfg copy the default one with sudo cp /etc/emulationstation/es_system.cfg /home/pi/.emulationstation/
          2.b If you already have a modified es_system.cfgbackup your old config withsudo cp /home/pi/.emulationstation/es_systems.cfg /home_/emulationstation/es_system.cfg.backup
        2. Open the config file sudo nano /home/pi/.emulationstation/es_systems.cfg
        3. Copy this somewhere between <systemlist>...</systemlist> (this is untested):
          <system>
            <name>psp</name>
            <fullname>PlayStation Portable</fullname>
            <path>/home/pi/RetroPie/roms/psp</path>
            <extension>.iso .ISO. cso .CSO .pbp . PBP</extension>
            <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ psp %ROM%</command>
            <platform>psp</platform>
            <theme>psp</theme>
          </system>
        1. Save the config file with ctrl+x, y and enter
        2. Restart Emulationstation
        Why not editing the default config?
        The default config should stay as it is. Emulationstation will read the config file in /home/pi/.emulationstation as primery system config, so no need to mess up the default config if it is safer this way :)
        I don't want to use SSH:
        Well, you could use a program like winSCP (Windows machines), but keep in mind that you have to set hidden folder visible first:
        Click on the "view" menu (or "options", if using the Norton Commander interface).
        Click on "preferences".
        In the preferences window, click on "Panels" on the left menu.
        Uncheck (or check) the "Show Hidden Files" box to show or hide the files
        Please check if there is a emulator folder for psp in /opt/retropie/emulators
        Now the PSP system should show up
        System: Raspberry 3 Model B, RetroPie 4.2.1
        Storage: 16gb Micro SD, 64gb USB Drive
        Theme: Updated NBBA
        Documentation solves many problems: https://retropie.org.uk/docs/
        D 2 Replies Last reply Reply Quote 0
          darthlink @DarkWolf
          @DarkWolf
          Hooo my god !!! really ?? loll
          That is what i did for kody and raspbian, i added them both manually in es-_systems.cfg and they both work great if i start them within retropie.
          Thank ;) i will do that and try it this evening. I will let you know if that works out ;)
          thx again
          Just one thing though, if that should work, should i uninstall the lr-ppsspp and just reinstall ppsspp instead ? I rather have the controller work directly instead of being attached to retroarch since i am having problem with the left analog stick as of now ??
          • DarkWolfD
            DarkWolf @darthlink
            @darthlink I edited my answer with a (hopefully) working solution
            Theme: Updated NBBA
              darthlink @DarkWolf
              @DarkWolf
              <system>
              <name>psp</name>
              <command>/home/pi/RetroPie/emulators/ppsspp/PPSSPPSDL %ROM% en</command>
              <theme>psp</theme>
              </system>
              This will not work because in the Retropie folder, i do not have a emulators folder. I have only 4 folder and they are: BIOS, retropiemenu, roms, splashscreen
              But in command i think i would put: bash %ROMS%
              no ?
              DarkWolfD TMNTturtlguyT 2 Replies Last reply Reply Quote 0
              • DarkWolfD
                DarkWolf @darthlink
                @darthlink
                Yeah, sry, that was a old path, edited it
                You should check this first
                Theme: Updated NBBA
                • TMNTturtlguyT
                  TMNTturtlguy @darthlink
                  @darthlink said in lr-ppsspp emulator does not work, please help !!:
                  This is because you need to let WinSCP see hidden folders. I believe the instructions below should let you see the hidden folders:
                  • DarkWolfD
                    DarkWolf @TMNTturtlguy
                    @TMNTturtlguy Actually there is no emulators (but I don't know if it apperas when installing ppsspp, I guess not)
                    Theme: Updated NBBA
                    • TMNTturtlguyT
                      TMNTturtlguy @DarkWolf
                      @DarkWolf if you want to edit the .es_systems.cfg you should do that in:
                      /home/pi/.emulationstation (i don't have my pi running, but i am pretty sure this is the correct path
                      .emulationstation is a hidden folder. Your modified es_systems.cfg file should live in this folder. Emulationstation will read this file as the primary systems file.
                      DarkWolfD D 2 Replies Last reply Reply Quote 0
                      • DarkWolfD
                        @TMNTturtlguy Yeah, I missed that one, I will edit my answer once again :)
                        Theme: Updated NBBA
                          darthlink @TMNTturtlguy
                          @TMNTturtlguy said in lr-ppsspp emulator does not work, please help !!:
                          That is true, es_systems.cfg is in .emulationstation, i am editinhg it right now with ssh.
                            darthlink @DarkWolf
                            @DarkWolf said in lr-ppsspp emulator does not work, please help !!:
                            @darthlink
                            all i have in /opt/retropie is: mupen64plus, pcsx-rearmed, pifba and retroarch
                            • DarkWolfD
                              DarkWolf @darthlink
                              @darthlink did you install the lr-ppsspp ?
                              than it should be in /opt/retropie/libretrocores
                              Theme: Updated NBBA
                                darthlink @DarkWolf
                                yes i had install lr-ppsspp but i will uninstall it and install ppsspp instead
                                • DarkWolfD
                                  DarkWolf @darthlink
                                  @darthlink it shouldn't depend in the emulator you use, just wanted to make sure the runcommand script will find the emulator...
                                  so install the one you want, edit the es_system.cfg and try it out
                                  Btw: My answer is kinda overkill now :D
                                  Theme: Updated NBBA
                                    darthlink @DarkWolf
                                    i just checked and yes it is in /opt/retropie/libretrocores
                                    • DarkWolfD
                                      DarkWolf @darthlink
                                      @darthlink yeah
                                      non lr- emus: /opt/retropie/emulators
                                      lr- emus: /opt/retropie/libretrocores
                                      but this is a unnecessary information
                                      Theme: Updated NBBA
                                        darthlink @DarkWolf
                                        @darthlink yeah
                                        so does this mean ( let say i keep the lr-ppsspp ) that i have to change my command line in es_systems.cfg to point to /opt/retropie/libretrocores/lr-ppsspp ??
                                        • DarkWolfD
                                          DarkWolf @darthlink
                                          @darthlink no, you can change it by pressing A atfer you selected a rom and it loads
                                          that opens the runcommand config and you can change the emulator it will use to run roms
                                          Theme: Updated NBBA
                                            dankcushions Global Moderator
                                            psp does appear in emulationstation - i'm not sure why we're editing es_systems.cfg
