    [SOLVED] lr-ppsspp emulator does not work, please help !!
    pspnot working
    48 Posts 5 Posters 27.4k Views
    • DarkWolfD
      DarkWolf @dankcushions
      @dankcushions it doesn't for me?
      System: Raspberry 3 Model B, RetroPie 4.2.1
      Storage: 16gb Micro SD, 64gb USB Drive
      Theme: Updated NBBA
      Documentation solves many problems: https://retropie.org.uk/docs/
        darthlink @dankcushions
        @dankcushions said in lr-ppsspp emulator does not work, please help !!:
        psp does appear in emulationstation - i'm not sure why we're editing es_systems.cfg
        because mine does not automatically appear unfortunatelly
          dankcushions Global Moderator
          that must be some sort of bug if true. there's nothing special about psp that would make it not appear. editing es_systems.cfg is generally a bad idea.
          DarkWolfD D 2 Replies Last reply Reply Quote 0
          • DarkWolfD
            @dankcushions it wasn't in my es_system.cfg so it doesn't appear if I got the functionality of the config right
            Theme: Updated NBBA
              It was installed properly. why is it a bad idear ? I also had to edit the es_systems.cfg to add kodi and raspbian in retropie. Not because i had to but because i wanted to. I just did not want to have to quit retropie if i wanted to go to kodi or raspbian so this works perfectly after editing the es_systems.cfg.
              If it also work with psp then it great for me
              DarkWolfD herb_fargusH dankcushionsD 3 Replies Last reply Reply Quote 0
              • DarkWolfD
                DarkWolf @darthlink
                @darthlink I downloaded the lr-ppsspp emulator and edited my es_system.cfg and it is showing up now, so it should work for you... As I don't want to download a rom for it I can't test it (just created a empty testrom.iso to test if it shows up)
                Theme: Updated NBBA
                • herb_fargusH
                  herb_fargus administrators @darthlink
                  @darthlink you shouldn't be recommending people edit es_systems.cfg if they don't know what the repercussions are especially when if psp was installed properly it should be generated by default. There is no reason it shouldn't be generating unless it either didn't install properly or user error.
                  DarkWolfD D 2 Replies Last reply Reply Quote 1
                  • DarkWolfD
                    DarkWolf @herb_fargus
                    @herb_fargus Basicly this is totally right and I experienced this behavior before, but for me it doesn't work for ppsspp (like it doesn't for darthlink)
                    so I edited it manually and it works... I don't know what is going on, I'm using the latest retropie version
                    Theme: Updated NBBA
                      darthlink @herb_fargus
                      @herb_fargus said in lr-ppsspp emulator does not work, please help !!:
                      it is not too hard to do in a comand prompt: sudo ~/RetroPie-Setup/retropie_setup.sh
                      then go in manage packages then optional packages and just choose either ppsspp or lr-ppsspp and it does install all with no error
                      Probleme is that even after a reboot, it was still not in retropie and not in es_systems.cfg
                      i have a backup of es_systems.cfg and a full backup of my raspberry pi 3 so i dont know why the fuss about giving and receiving help that may solve an issue but i am appreciating all help because this is what this is about right, helping each other.
                      dankcushionsD 1 Reply Last reply Reply Quote 1
                        dankcushions Global Moderator @darthlink
                        @darthlink said in lr-ppsspp emulator does not work, please help !!:
                        kodi also automatically appears in ES once installed (in the ports menu). and raspbian/pixel i expect (i don't use it)
                          @darthlink my guess, you have turned 'parse gamelists only' on, in the emulationstation options. you should have it turned off.
                          • DarkWolfD
                            @dankcushions yes, thats true, but if you want it as a "own" system on the system carousel you have to add them to the es_systems.cfg
                            Theme: Updated NBBA
                            • DarkWolfD
                              @dankcushions well, I completely forgot about that one...
                              However it was turned off when I installed ppsspp and it didn't show up
                              Theme: Updated NBBA
                                do you mean there: sudo ~/RetroPie-Setup/retropie_setup.sh ?
                                i just went there and i cant find parse gamelist only ??
                                DarkWolfD 1 Reply Last reply Reply Quote 0
                                • DarkWolfD
                                  DarkWolf @darthlink
                                  @darthlink No, in Emulationstation press Start and go to Other Settings
                                  Theme: Updated NBBA
                                    @dankcushions
                                    When i installed kodi, i did not even know about the port menu, i only found that out 2 days ago. i originally went there because i was looking for a way to add more scrapper and i found that here: https://github.com/retropie/retropie-setup/wiki/scraper it is where i saw that there was also the ppsspp and lr-ppsspp emulator that i could install so i did it and you know the rest loll
                                    But editing the es_systems.cfg was good for me to add both kodi and raspbian with pixel to emulationstation ;)
                                      darthlink @DarkWolf
                                      @DarkWolf said in lr-ppsspp emulator does not work, please help !!:
                                      haaa ok, then i will only be able to try that later this evening unless there is a way to get there through ssh ?
                                      • DarkWolfD
                                        DarkWolf @darthlink
                                        @darthlink There is:
                                        cat /home/pi/.emulationstation/es_settings.cfg
                                        it contains something like that:
                                        <bool name="ParseGamelistOnly" value="false" />
                                        Theme: Updated NBBA
                                          darthlink @DarkWolf
                                          thx ;) so yes my pasre gamelist only value is: false
                                            darthlink
                                            Now my emulation wont start because its telling me that es_systems.cfg cant be loaded.
                                            So i removed the part i changed witch was the psp part and then everything is working back again.
                                            Can you please tell me what is wrong with my psp part that make emulationstation not loading ?
                                            there it is:
                                            <system>
                                            <name>psp</name>
                                            <fullname>playstation portable</fullname>
                                            <path>/home/pi/RetroPie/roms/psp</path>
                                            <extension>.iso .ISO .cso .CSO .pbp .PBP .zip .ZIP .rar .RAR .7z .7Z</extension>
                                            <command>bash %ROMS%</ROMS>
                                            <plateform>psp</plateform>
                                            <theme>psp</theme>
                                            </system>
                                            herb_fargusH DarkWolfD 2 Replies Last reply Reply Quote 0
