    Retro Pie Help
    emulatorssneshelp
    2 Posts 2 Posters 577 Views
      mwight
      Hi all, I have little knowledge of how to do the technical side of retro pi... I do know how to move games on and off from the emulator but I was having an issue in which the SNES emulator would not actually load the games (not even or loaded pacman). I tried factory resetting the emulators but after that finished the SNES and many other emulators won't even appear as a gaming option. HELP!! (sorry in advance, I will be a pretty simply worded explanation) I know how to navigate for the most part just not how to fix it
      DarkWolfD 1 Reply Last reply Reply Quote 0
      • DarkWolfD
        DarkWolf @mwight
        @mwight Seems like you messed up a lot...
        Go into the retropie-setup menu and update all packages... This should reinstall the emulators
        Other wise: save configs/roms and reinstall...
        System: Raspberry 3 Model B, RetroPie 4.2.1
        Storage: 16gb Micro SD, 64gb USB Drive
        Theme: Updated NBBA
        Documentation solves many problems: https://retropie.org.uk/docs/
