    Artwork/Icons for Ports Not Saving
    portsartworkemulationstatioscraper problem
    27 Posts 2 Posters 8.5k Views
      Muddyhardcore
      I'm trying to add artwork or whatever you want to call it to Kodi and Doom in the Ports menu. I'm able to add them manually and with the built in scraper. Unfortunately when i restart Emulation Station, the artwork disappears. I'm saving properly after adding the image. Any ideas?
      Pi 3, Retropie 4.2.7, 128GB SanDisk SD , CanaKit 5.1v Power Supply, 8bitdo NES30,
        mediamogul Global Moderator @Muddyhardcore
        @Muddyhardcore
        Emulation Station needs to be shutdown before making any manual changes, otherwise it'll save over them the next time it exits.
          Muddyhardcore @mediamogul
          @mediamogul I'm not understanding what you mean. If using the built-in scraper to get the images. That's worked fine for me before. When I shutdown my Pi I do get an error saying that there's no gamelist found for kodi and doom. How do I add the images I want to use with Emulationstation shutdown?
            @Muddyhardcore
            When you said you were adding them manually, I assumed that meant that you were editing the gamelists with an outside text editor. In fact, I'm still a little unsure of what it is that you're trying to do. Kodi and Doom shouldn't have their own gamelists anyway, as they reside in the ports menu. If you would, post the contents of your /opt/retropie/configs/all/emulationstation/es_log.txt file. Also, as always when making a help request, please post the information requested at https://retropie.org.uk/forum/topic/3/read-this-first.
              @mediamogul I'm not trying to add a gamelist. I have 2 items(Kodi, Doom) in the Ports menu. I wanted them to have an Image/Artwork and description like all of my Roms do. I use the built-in scraper to get the Artwork and description, then scroll down and click save. After this, Kodi and Doom both have the artwork and description that was scraped. Unfortunately once I restart emulationstation or shut down the Pi, the Artwork and description from the scraper are no longer there. I'm just trying to figure out why. I don't know how to upload what you asked me to. I'm sorry for being a noob.
                @Muddyhardcore
                Ah, I got ya now. Make sure that 'Save Metadata on Exit' is set to yes under 'Other Options' in the Emulation Station settings.
                  @mediamogul
                  It is set to On. Any other suggestions?
                    @Muddyhardcore
                    When you restart Emulation Station, are you you doing it from within the 'Quit' options in the settings?
                      @mediamogul
                      Yes I am.
                        @Muddyhardcore
                        As a troubleshooting measure, try altering the information of an item outside of the Ports menu and then restart ES to see if it's applied.
                          @mediamogul
                          Ok I was able to change the artwork and description for the one Game Boy Color Rom I have and it was still applied after restarting emulationstation station
                            @Muddyhardcore
                            Very bizarre. When I get a chance, I'll try to alter an item in the Ports menu of my setup.
                              @mediamogul
                              I did try using that Universal XML scraper a while ago to do this. Could that have created a file that can't be overwritten?
                              mediamogulM 2 Replies Last reply Reply Quote 0
                                @Muddyhardcore
                                I'm not familiar with that scraper, but it's a consideration if nothing else pans out.
                                  @Muddyhardcore
                                  Alright, mine is saving as it should. Let's try removing your current gamelist.xml from the equation first. While in Emulation Station, drop to the command line by pressing 'f4' on your keyboard. From there type:
                                  cp /opt/retropie/configs/all/emulationstation/gamelists/ports/gamelist.xml /opt/retropie/configs/all/emulationstation/gamelists/ports/gamelist.xml.bak
                                  Press 'enter', then type:
                                  emulationstation
                                  Press 'enter' and once Emulation Station fully launches, try applying information to one of the items in the Ports menu and restart ES to see if it then persists.
                                    @mediamogul
                                    No unfortunately that didn't work. I tried it twice incase I made a typo.
                                      @Muddyhardcore
                                      Looking at the log might help. To do that you'll need to familiarize yourself with SMB or SFTP so that you can copy the log contents of /opt/retropie/configs/all/emulationstation/es_log.txt and post it here.
                                        @mediamogul
                                        Can I do that using WinScp?
                                          @Muddyhardcore
                                          Yessir.
                                            Muddyhardcore
                                            Says I don't have enough privileges to attach the file
