I have read everything that resembles my issue but still need help.
I installed retropie on my rp3 a few weeks ago and everything was fine. I installed the snap previews and expanded external hard drive and with the new space I decided to add some ds games. I installed the emulator, placed roms in the rom folder (most on the extended but 1 in the original rom folder just in case.) roms are the correct extensions and bios in bios folder. The ds emulator doesn't show.
Did I mess something up with the install of external extension or the video snaps? -
Did you add it on the sd card or a usb drive
at first i tried using wifi to place the roms but i had the same problem as you and then i used a usb drive and then everything showed up
I have the roms in the usb and 1 on the sd card.
I put them on the usb not via wifi.
@se7enout did you install the emulator? Nothing will show up if you didnt.
yes emulator is installed...
for some reason there is no nds folder in the emulationstation/gameslist/ not sure if that has anything to do with it. Or how i remedy it.
@budgingwhale922 andy ideas?
@edmaul69 notice the gamefiles doesn't have an nds folder?
@se7enout gamelist shouldnt matter at all. Do you have an nds folder in /home/RetroPie/roms/ ? The next thing is do you have an es_systems.cfg in /opt/retropie/configs/all/emulationstation/ ? If yes, you need to delete it or copy the nds section from /etc/emulationstation/es_systems.cfg
@edmaul69 Thanks! All is good now!
