    3d Games - Randomly Freezing for 3 seconds
    freezeromroms3d gameshanging
    16 Posts 6 Posters 3.2k Views
      red2blue
      As title says, my games are freezing during gameplay. N64 and PS1 to be exact, also sometimes in rom gamelist when im scrolling i get random freezes for a few seconds.
      I just tested it and didnt press anything on my controller running a rom thru ps1 and its not freezing at all, its only when im doing something on my controller with a input ill get occasionally freezing.
      I'm using a external hd to hold system and roms files. controller is wired xbox one.
      all other emulators dont freeze its just these 2 i have problems with.. im not sure about PSP because i dont use it.
        pjft
        Emulator versions? Emulator names?
          red2blue @pjft
          @pjft its the default psx one and default n64 one.. lr-rearmedpsx i believe? unsure ofthe version
            red2blue
            I just updated the lr-pscx-rearmed let me see if it still freezes..
            Meanwhile, how do i fix freezing in menus?
              pjft @red2blue
              @red2blue in pcsx go and disable vibration in the core options menu.
                red2blue @pjft
                @pjft is this for in game freezing or game list freezing?? if game list i dont think that has anything to do with it freezing when im scrolling down NES games for example
                R pjftP 2 Replies Last reply Reply Quote 0
                  red2blue @red2blue
                  didnt freeze for a long time in game, till 5 seconds ago had one hiccup.
                    dankcushions Global Moderator
                    fill out https://retropie.org.uk/forum/topic/3/read-this-first
                      pjft @red2blue
                      @red2blue it's obviously for psx in game freezing. There was a fix for similar issues a few months back, related to vibration.
                        red2blue @pjft
                        @pjft yeah that vibration thing fixed it thank you....
                        How about the menu?
                          edmaul69 @red2blue
                          @red2blue try a different theme.
                            pjft
                            Or scrape lower resolution images/videos, or batch resize them yourself, or use a faster SD card/USB drive, or move to a USB drive if you're using a SD card...
                            There are so many possibilities. We're kind of flying blind here as we don't know anything about your setup.
                            Best of luck.
                            • DD-IndeedD
                              DD-Indeed
                              What format do you have in your drive, where the games are ? I noticed, that when I changed the format from FAT32 to NTSC, the issue in the actual gameplay was gone.
                              My soul rests, when I hear the PS1 boot music
                              • DarksaviorD
                                Darksavior
                                If you aren't using the hdd for movies, you're better off getting a large USB stick for faster reads and less power usage.
                                  red2blue @pjft
                                  @pjft As mentioned in original post, im using a usb drive. it stores all my retropie system files, and my roms and videos and images.
                                  Everything is updated to latest version.
                                  The theme is ComicBook but it will freeze on any theme, doesnt really matter which theme i use.
                                  The scraping is from UXS, there isnt a option to resize or compress.
                                  @dd-indeed its FAT, but i'm pretty sure FAT is suppose to be the format your suppose to use? if i change the format i would have to reformat it right?
                                  DD-IndeedD 1 Reply Last reply Reply Quote 0
                                  • DD-IndeedD
                                    DD-Indeed @red2blue
                                    @red2blue
                                    Yes it is, because it's supported by every system. But if you got it fixed up, good. But if not, you should try it out with other USB stick instead, so don't yet format your main drive, if it's not going to work in the end.
