    After disconnecting 8bitdo BT controller, player 1 does not work
    8bitdobluetoothcontrollermappings
    1 Posts 1 Posters 561 Views
      BoyApfel
      Hey guys,
      I'm quite new to this and searched far and wide for an answer, but I can't seem to get my hands on the solution. Here's the problem:
      I setup my Retropie image (4.2, pre-made from MadLittlePixel) in an bartop arcade-cabinet that I built myself. All is fine in setting the thing up to the point were I want an BT-controller to run as player 2 (it's an one-player arcade cabinet). The USB-controller in the case itself configures itself to port #0 when it's plugged in without the BT-controller. So all my mappings are set to port #0 and it works fine. But when I connect the BT-controller the USB-controller reconfigures itself to port #1 and the BT-controller to port #0.
      So after adjusting the mappings (player 1 to port #1 and player 2 to port #0) to this setup I found that when I disconnected the BT-controller the usb-controller reconfigures itself to port #0 and the whole thing is unplayable.
      Does anyone have a solution to this? I would be so grateful.
      Thanks,
      Boy
