    Controller Mapping Problem - Working Globally but I don't know why
    controllerssetupretroarchn64snes
    1 Posts 1 Posters 514 Views
      spacehamster
      So it has taken me absolutely forever to get my controller set up to use in retropie. Essentially, I have a USB N64 controller.
      This is the ONLY way it will work at all:
      My "configs > all > retroarch > autoconfig > Generic USB Joystick" file looks like this:
      input_device = "Generic USB Joystick "
      input_driver = "udev"
      input_l_btn = "4"
      input_load_state_btn = ""
      input_start_btn = "9"
      input_enable_hotkey_btn = "9"
      input_exit_emulator_btn = "7"
      input_l_y_minus_axis = "-1"
      input_up_btn = "h0up"
      input_a_btn = "6"
      input_b_btn = "8"
      input_z_btn = "7"
      input_reset_btn = ""
      input_down_btn = "h0down"
      input_l_x_plus_axis = "+0"
      input_l_y_plus_axis = "+1"
      input_r_btn = "5"
      input_save_state_btn = ""
      input_right_btn = "h0right"
      input_state_slot_increase_btn = ""
      input_l_x_minus_axis = "-0"
      input_left_btn = "h0left"
      input_state_slot_decrease_btn = ""
      input_menu_toggle_btn = ""
      input_state_slot_decrease_axis = ""
      input_state_slot_increase_axis = ""
      input_reset_axis = ""
      input_menu_toggle_axis = ""
      input_load_state_axis = ""
      input_save_state_axis = ""
      input_exit_emulator_axis = ""
      Then I have a file located at configs > n64 named "InputAutoCfg" which looks like this:
      ; Generic USB Joystick _START
      plugged = True
      plugin = 2
      mouse = False
      AnalogDeadzone = 4096,4096
      AnalogPeak = 32768,32768
      Mempak switch =
      Rumblepak switch =
      R Trig = button(5)
      L Trig = button(4)
      Start = button(9)
      Y Axis = axis(1-,1+)
      Z Trig = button(7)
      DPad U = hat(0 Up)
      A Button = button(6)
      DPad D = hat(0 Down)
      X Axis = axis(0-,0+)
      DPad R = hat(0 Right)
      B Button = button(8)
      DPad L = hat(0 Left)
      C Button R = button(1)
      C Button L = button(3)
      C Button D = button(2)
      C Button U = button(0)
      ; Generic USB Joystick _END
      This setup works great when playing N64 games. However, I want to re-map the same controller to use with SNES.
      Changing anything in the N64 or SNES "retroarch" file does nothing.
      I tried removing all Autoconfig files and placing the initial controller mapping (from the first file above) in the configs > all > "retroarch" file . This prevents everything from working.
      I am completely stumped on how to set up this controller to work with multiple games.
