    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 136.4k Views
      mitu Global Moderator @Rion
      @Rion said in Multi Switch Shutdown Script!:
      taughts
      The early bird catches the ... something.
      Now, if you want the prompt to disappear and you already modified the .bashrc file, just add as last lines of the file:
      export PS1=""
      tput civis
      and then logout.
      RionR RanmaR 2 Replies Last reply Reply Quote 3
      • RionR
        Rion @mitu
        @mitu Thank you Mr Bash Shell Wizard!
        FBNeo rom filtering
        Mame2003 Arcade Bezels
        Fba Arcade Bezels
        Fba NeoGeo Bezels
        • RanmaR
          Ranma @mitu
          @mitu I'll add my love here too. This works! Awesome! Thanks so much for replying.
          You always know the answer @mitu
          Superstar!
            janderclander14
            I've modified the python script from this post, which calls the Multiswitch script, to add several reset behaviors with generic buttons connected to the GPIO.
            Assuming two buttons, the behavior is as follows:
            • One button (connected to GPIO 3) acts as shutdown (and power up)
            • The other button resets the system. One short press, quits the current emulator or restarts emulationstation. One long press (3 sec) restarts the system.
            I attach here the code just in case someone finds it useful (it assumes multi_switch.sh is in /home/pi). You may add this as a python call to /opt/retropie/configs/all/autostart.sh
            #!/usr/bin/env python3
            from gpiozero import Button, LED
            import os
            from signal import pause
            import subprocess
            import time
            powerPin = 3
            resetPin = 2
            resetMinSeconds = 2
            #functions that handle button events
            def when_pressed():
             output = int(subprocess.check_output(['/home/pi/multi_switch.sh', '--es-pid']))
             if output:
                 os.system("/home/pi/multi_switch.sh --es-poweroff")
             else:
                 os.system("sudo shutdown -h now")
            def reboot():
             start_time=time.time()
             diff=0
             while rebootBtn.is_active and (diff < resetMinSeconds):
                 now_time=time.time()
                 diff=-start_time+now_time
             output_rc = int(subprocess.check_output(['/home/pi/multi_switch.sh', '--rc-pid']))
             if (diff > resetMinSeconds):
                 if output:
                     os.system("/home/pi/multi_switch.sh --es-reboot")
                 else:
                     os.system("sudo reboot")
             else:
                 if output_rc:
                     os.system("/home/pi/multi_switch.sh --closeemu")
                 elif output:
                     os.system("/home/pi/multi_switch.sh --es-restart")
                 else:
            btn = Button(powerPin)
            rebootBtn = Button(resetPin)
            rebootBtn.when_pressed = reboot
            btn.when_pressed = when_pressed
            pause()
            cyperghostC M 3 Replies Last reply Reply Quote 3
              cyperghost @janderclander14
              @janderclander14 Hehe ;) Nicely done
                @janderclander14 I've done some changes to the python script for some other system. To get rid of the pathes I added
                #get script directory
                scriptDir = os.path.dirname(os.path.realpath(__file__))
                So the directory from the python script is catched. Assuming the python and the bash script are stored in the same directory we can use....
                os.chdir(scriptDir)
                     elif output:
                         os.system("./multi_switch.sh --es-restart")
                I was fixed to to /opt/RetroFlag because RetroFlag use as default in the installer and so I use this path to overwrite their script. But congrats you are the first one who activly uses the provided output to create a new shutdown script. Such it was intended to do ;)
                  janderclander14 @cyperghost
                  @cyperghost Certainly, using relative directories is always better. And thanks to you for the script! It just had all the functionalities one would need.
                  • quicksilverQ
                    quicksilver
                    @cyperghost Would it possible to adapt your script to work with the new RetroFlag GPi case? It only has a shutdown switch (no reset function). This is the script that is currently supplied by retroflag:
                    import os
                    powerPin = 26
                    powerenPin = 27
                    hold = 1
                    power = LED(powerenPin)
                    power.on()
                    def when_pressed():
                      os.system("sudo killall emulationstation && sleep 5s && sudo shutdown -h now")
                    btn = Button(powerPin, hold_time=hold)
                    pause()
                    As you can see they are just using a "sleep" function to handle saving metadata which is not ideal.
                      cyperghost @quicksilver
                      @quicksilver Yes .... the os.system call has to be changed.
                      os.system("bash /path/to/multi_switch/multi_switch.sh --es-poweroff")
                      This will try to close all open emulators and then shutdown the system (after all metadata is saved)
                      quicksilverQ 1 Reply Last reply Reply Quote 1
                      • quicksilverQ
                        quicksilver @cyperghost
                        @cyperghost That was easy and it works like a charm! Thank you my friend!
                        • quicksilverQ
                          quicksilver
                          @cyperghost is there a way to get your script to shutdown if you exit emulation station to the terminal? Or if emulation station crashes or something?
                            @quicksilver said in Multi Switch Shutdown Script!:
                            Therefore you can use .bashrc from your home directory.
                            Just add a poweroff command and if you go to terminal the command will be executed.
                            You would ask for the PID of Emulationstation simply with pidof emulationstation
                            You will obtain the one from the binary and as long this is alive you know ES is running. If there is a change in the PID or the status of SIGNAL has changed you can assume that there someting happend to ES. To determine if it a user action (Reboot, Shutdown...) you watch for files placed into/tmp dir
                            The files are
                            1. /tmp/es-sysrestart for sytem wide reboot
                            2. /tmp/es-restart for just restarting ES
                            3. /tmp/es-shutdown for poweroff
                            So to answer your question if my script can do this .... only for the .bashrc part that is really no rocket science and a sudo poweroff command call would be more effictive.
                            Be aware to not shoot in your own leg with this!
                            • WeirdHW
                              WeirdH
                              Just wanted to say thanks for this awesome script. After (unsuccessfully) messing around with 'dtoverlay' in config.txt and some years old non-functioning auto-installed stuff, I finally have a single button safe shutdown for ES. Thanks to cyperghost and all involved!
                                danick8989
                                SuperPi case, i came from your outdated script that's linked on RetroFlag's github and this script doesn't work. When a game is running, i need to flip the reset button several times then it kills retroarch. Same for shutdown, after 2-3secs "Killed" appears on the screen then it shuts down
                                  cyperghost @danick8989
                                  @danick8989 You to explain in a more clear way. The script can be utilzed in two ways.
                                  1. If you use it in pure shell mode then you need to hold the button for one second. The pure bash script uses simple polling to check GPIO state.
                                  2. If you "came" from RetroFlag then you utilize python and this uses interrupts so it recognizes button presses instantly. And the lack of "reaction" is likely a faulty case.
                                  Furthermore: if it terminates retroarch and returns you to ES and it shuts down your Pie why are you assuming it's outdated and does not work?
                                    danick8989 @cyperghost
                                    @cyperghost I'm not assuming it as outdated, i said i came from your previous revision of the script that's linked on RetroFlag's github page(they didn't update it to this one). And i thought killing retroarch and ES would be discouraged? Like, previously didn't the script send a command to ES for it to close RA properly or something? Also it's not clear to me, how do i use python instead of a bash script, and since it seems to work more seamlessly, why isn't it the default? I rolled back to the old multiswitch script in the meantime, since it still works flawlessly for me aside from exiting from Kodi.
                                    • AndersHPA
                                      AndersHP
                                      Hi, I kind of hijacked another thread regarding Pegasus, but thought I would ask here instead.
                                      I'm not using a RetroFlag unit, but a Kite Circuit Sword from Sudomod.com
                                      I'm unsure if my shutdown script, the cs_shutdown.sh file in /opt/ folder, does something special that can harm the safe-shutdown process if not built into another script, e.g. your Multi Switch Script. My file looks like this (also mentions a shutdown file?):
                                      #!/bin/bash
                                      # Get ES pid
                                      ES_PID=`pidof emulationstation`
                                      if [[ $ES_PID != "" ]] ; then
                                        echo "ES_PID: $ES_PID"
                                        # Touch the shutdown file
                                        touch /tmp/es-shutdown
                                        chown pi:pi /tmp/es-shutdown
                                        # Tell ES to terminate
                                        kill -s SIGTERM $ES_PID
                                        echo "ES has been asked to shutdown"
                                      else
                                        echo "Could not find ES PID ($ES_PID)"
                                        sudo shutdown -h now &
                                      fi
                                      Could I just delete this file, and install your Multi Switch Script with the modifications that @SinisterSpatula mentions? Or would I miss something? How much is this solely for RetroFlag builds?
                                      For instance: The RetroFlag is a Pi Zero right? My Circuit Sword is a CM3+ module (not GPIO based, but basically a RPi 3+).
                                      How can I tell if the script works as intended apart from the screen going black?
                                      My Gameboy
                                        mitu Global Moderator @AndersHP
                                        @AndersHP Try replacing
                                        with
                                        ES_PID=`pidof pegasus-fe`
                                        or what's the actual process name of the Pegasus front-end. The rest of the script should be the same.
                                        AndersHPA 1 Reply Last reply Reply Quote 0
                                        • AndersHPA
                                          AndersHP @mitu
                                          @mitu OK thanks, but can I see somehow if everything is working as planned - apart from the obvious thing that Pegasus should quit?
                                          My Gameboy
                                            @AndersHP The script you posted does nothing more than stopping Pegasus and shutting down, so if comment out the shuttind down part you can check by seeing if the front-end stops.
