    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 130.5k Views
      mitu Global Moderator @Efriim
      @Efriim said in Multi Switch Shutdown Script!:
      A new feature of the reicast emulator is to save the rtc setting to emu.cfg when invoking the exit by pressing the exit hotkey
      Are you sure ? The RTC is saved in the NVRAM file (BIOS/dc/dc_nvmem.bin), not in the emu.cfg file.
      • EfriimE
        Efriim @mitu
        The setting looks like this from emu.cfg
        Dreamcast.RTC = 1543281985
        The nvram needs to be within a number of seconds of this setting, that is why it asks for the time/date even if it has already been saved in the nvram.
          cyperghost @Efriim
          @Efriim This could happen if the kill command fails. After 2 seconds annother kill command with -9 parameter is send to process and this will terminate the emulator. The only way I see is to use the NET commands retroarch offers. There you can send key commands to proper exit the core. Let me think about it ..,
          • EfriimE
            Efriim
            Though it is only with the standalone reicast, indeed. There must be a passthrough to the sdl to initialize the emulator to its shutdown state.
              cyperghost @Efriim
              @Efriim oh yes and even it's not a libRetro core UDP will also fail. You may find a way to send signal level 15 to this core then it will save the day time
              • EfriimE
                Efriim
                @cyperghost said in Multi Switch Shutdown Script!:
                > /dev/null 2>&1
                This broke some things, mostly only the rc.local stopped working. I shouldn't have added it to rc.local, but It worked with rc.local as long as I'm not fumbling around on other things so much.
                  cyperghost @Efriim
                  @Efriim Sorry ... I should think more about next time.
                  The output of stdout to /dev/null can't work. Because this output is needed for the python scripts to get response from the script. Maybe just send stderr to /dev/null is better? I did not test so far but I think that makes more sense. Yes, set it for the python script because this causes the error.
                  2>/dev/null
                  Yes /etc/rc.local is used for the retroflag script for automatic startup. But you can also use autostart.sh from emulationstation. That's the way I prefer...
                  You can edit with nano /opt/retropie/configs/all/autostart.sh
                  Broken means your installation does not boot anymore? Oh dear, you may edit the file from a second mashine?
                  About the commands... please don't forget to add an & at last sign. This will send the process to background otherwise the boot progress stops here.
                  EfriimE 2 Replies Last reply Reply Quote 0
                  • EfriimE
                    Efriim @cyperghost
                    @cyperghost
                    Thanks. I got the rc.local to work again, I left one of these ">" when I deleted /dev/null.
                    When I made reicast from source with /dev/null added to the rc.local I didn't notice any build errors, though when I ran reicast.sh it did give me an error about /dev/null and wouldn't work. I recompiled it and it is not working still. So I guess I was dumb and it had not to do with that.
                    I don't know what is up with reicast, the controller used to work without ever setting it up, and then it stopped and the joyconfig didn't work and now the emulator wont even start.
                    • EfriimE
                      Efriim @cyperghost
                      @cyperghost
                      Sorry for blaming you. It looked to me that way but I didn't think. They were concatenated in my head as I went from that to this and I apologize.
                      The reicast binary installation still works, maybe building has trouble with my environment or maybe it is just broke. The PS3 controller needed to be removed from the bluetooth and resynced because of the alternative driver, it is working again. And now I just might try to add the > /dev/null 2>&1 for the third time.
                      On top of that my powersupply was halfway falling out of the surge protector, and I couldn't figure out why I was getting low voltage errors, and I got experimental settings going on with 667 sdram_freq. And I couldn't even think of all the things that can't go wrong with /dev/null.
                      Yes the Reicast source is broken and the binary is somewhat broken, there is the older binary in the "working dreamcast games" thread somewhere and I'm using that now. The updated binary works for a while and then crashes on the second round. The errors are a gl get error 0x500 on start and about 15 OMX buffer underruns, which existed with the old version and persist if using "oss"
                      I thought about creating a new thread, it will probably get fixed eventually. Or is it more sensible to add to the github?
                      cyperghostC 1 Reply Last reply Reply Quote 2
                        cyperghost @Efriim
                        There is no need for an apologize, I never felt offended. But nice you sorted this out.
                        Maybe you can give feedback how we can get rid off some error messages.
                        • RanmaR
                          Ranma
                          Hi, hope I'm OK asking this here. My Google-fu has failed me, and searching has proved complicated.
                          I'm using the Mega-Pi case with your shutdown script and it works brilliantly. However I'd really like to hide the console text on shutdown for cosmetic reasons. I understand that sometimes things go wrong and output is needed when this happens, but I have a backup image and do not intend updating my system. I feel like I've finished my project now and would like to wrap it up with the addition.
                          I did find a comment somewhere that suggested to add >/dev/null 2>&1 to /etc/profile.d/10-retropie.sh. I did this and it removed the "terminated 671" line, but the console prompt remains. This is pretty much what displays before shutting down - alt text
                          I'd like it to simply go to a black screen if possible before shutting off. If you can help that would be very much appreciated. many thanks.!
                          lostlessL 1 Reply Last reply Reply Quote 2
                          • lostlessL
                            lostless @Ranma
                            @Ranma you need to edit the cmdline.txt file in the /boot directory.
                            I use this for all my pi projects and it hides all text during bootup and shutdown.
                            dwc_otg.lpm_enable=0 console=serial0,115200 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait usbhid.quirks=0x0079:0x1801:0x40 quiet loglevel=3 consoleblank=0 plymouth.enable=0 quiet logo.nologo
                            put it in all as one line.
                            RanmaR 1 Reply Last reply Reply Quote 1
                            • RanmaR
                              Ranma @lostless
                              @lostless Hi thanks for replying. I've already got all that in my cmdline.txt file. I'd already followed a guide to silence the Pi during boot and shutdown, but it doesn't completely work. If I shutdown Retropie via the menu, it's completely quiet, but if I use the button on the Mega-Pi I get the console as above.
                                cyperghost @Ranma
                                @Ranma you can try to edit $HOME/.bashrc and play around with it a bit.
                                The reason for showing the terminal is that the multi_switch script terminates ES and you will be set back to terminal. Maybe it helps to just add a clear command at the end of .bashrc
                                • RanmaR
                                  Ranma @cyperghost
                                  @cyperghost Thanks so much for replying. Could I ask, what would be the best way to do this? I can find a number of commands on the internet but I'm not sure of the best one to try. I've been using Linux for some time but never had to edit ./bashrc at any time in the past so my knowledge is non-existent I'm afraid.
                                    cyperghost @Ranma
                                    @Ranma To be true I have not a real clue about this topic, too. I never ran RetroPie as complete hidden software.
                                    Best way to accomplish this task is to use nano $HOME/.bashrc
                                    then add clear as last command. This will likely reduce your screen to just the prompt. Maybe @mitu can tell how to redirect the complete terminal tty1 to tty3 or so ;)
                                    The clear command gots the advantage that it does not break anything on your current setup. So I consider it as ("breakfail"-)save solution.
                                    RanmaR 1 Reply Last reply Reply Quote 2
                                    • RanmaR
                                      Ranma @cyperghost
                                      @cyperghost Excellent, thanks for replying. I added a simple clear at the end of the file and you're right - there's just the login prompt onscreen now. If there's a way to hide that too, that would be even better. Many thanks for your help. :-)
                                        mrnebu
                                        @cyperghost hello, i use the nespi+ case, 3b+ but no retropie. the scripts i found so far only work with emulationstation but not if you run console. could you add shutdown now for power and reboot for reset with the led? i tried myself but too much stuff going on in the nespi case for me to finish it within a year and i dont want to mess up your script.
                                        would it be possible to add a function in case shutdown is stuck cause no es is running? it could work down other shutdown / reboot options and your script your get even more universal?
                                          cyperghost @mrnebu
                                          @mrnebu said in Multi Switch Shutdown Script!:
                                          That's already possible within the script. For the NESPi+ you see the lines
                                              # Initiate Shutdown per ES
                                              es_action --ES-CLOSEEMU
                                              es_action --ES-POWEROFF
                                              # If ES isn't running use regular shutoff
                                          sudo poweroff
                                          So indeed if ES is not running it already uses the regular poweroff. On the other hand you can use this script to read status of ES or running emulators and can then decide on your own what to do. So I think it is as flexible as you descripe and will cover a lot of usescases if you know how to use. So I made created a usecase for python here and also RetroFlag mentioned the script.
                                          • RionR
                                            Rion @Ranma
                                            @Ranma I have been wondering about that to. @mitu Do you have any taughts, ideas?
                                            FBNeo rom filtering
                                            Mame2003 Arcade Bezels
                                            Fba Arcade Bezels
                                            Fba NeoGeo Bezels
