    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 130.7k Views
    • V
      vivesladron
      Hi, noob here
      I don't undestand 4 and 5 steps:
      1. Now edit ES autostart with nano /opt/retropie/configs/all/autostart.sh and add script to like ....
      2. /home/pi/RetroPie/scripts/multi_switch.sh --nespi+ & but BEFORE the last line emulationstatio #auto
      What I need if I want to make a power off option in retropie menu?
        cyperghost @vivesladron
        @vivesladron What do you want to do?
        • V
          vivesladron @cyperghost
          @cyperghost I want to do that
          but using your script
            @vivesladron then change the delieverd scripts from YouTube with calls according to help in multi_switch e.g. bash /path/to/multi_switch.sh --es-restart & to restart ES properly.
            • V
              vivesladron
              Ok
              I designed my power button menu
              And I edited es_systems.cfg
              <system>
              <name>power</name>
              <fullname>Power</fullname>
              <path>/home/pi/RetroPie/scripts</path>
              <extension>.rp .sh</extension>
              <command>/home/pi/RetroPie/scripts/multi_switch.sh --es-poweroff</command>
              <platform/>
              <theme>power</theme>
              Is that a good option to do it?
              Will it save metadata and shutdown the system?
              How can I run it directly without the next screen?
              Thank you!
              • Drakaen391D
                Drakaen391
                try changing the path to the full path to the script, to see if that works
                RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
                Retropie (Latest Stable)
                PiBox with Wind Tunnel Cooling System
                • V
                  vivesladron @Drakaen391
                  @Drakaen391 Thanks I’ll try that
                    @vivesladron Do following
                    on es_systems
                    <system>
                    <name>power</name>
                    <extension>.sh</extension>
                    <command>bash %ROM%</command>
                    <platform/>
                    Then put your script files into /home/pi/RetroPie/scripts
                    nano "/home/pi/RetroPie/scripts/PowerOff.sh
                    #Poweroff Script by cyperghost
                    /home/pi/RetroPie/scripts/multi_switch.sh --es-poweroff &
                    nano "/home/pi/RetroPie/scripts/Restart ES.sh"
                    #Restart EmulationStation by cyperghost
                    /home/pi/RetroPie/scripts/multi_switch.sh --es-restart &
                    That should work.
                    • V
                      @cyperghost
                      That’s perfect
                      Thanks!
                      What if I want only poweroff by pressing just once from the power menu?
                      I didn’t check @drakaen391 suggestion yet
                        @vivesladron
                        Not possible - therfore someone has to change the code of EmulationStation.
                        You've got the same behaviour with KODI. One file to start but you have to enter the "system" and to start the single "ROM" file ;)
                        V 1 Reply Last reply Reply Quote 1
                        • V
                          @cyperghost
                          I'm running the ROMs from a USB drive and I'm having problems with the scripts
                          /home/pi/RetroPie/scripts/PowerOff.sh: line 2 /home/pi/RetroPie/scripts/multi_switch.sh: Permission denied
                          I tried with chmod +x but no difference
                          Do you know how to fix it?
                            @vivesladron Shure... just add bash command inside the scripts
                            so it will look like
                            bash /home/pi/RetroPie/scripts/multi_switch.sh --es-restart &
                            • V
                              @cyperghost
                              So easy!
                              Thank you!
                              • RionR
                                Rion
                                @cyperghost Hi! Is your script compatible with mini-mods NesPi Fan Controller?
                                Github link to the script
                                FBNeo rom filtering
                                Mame2003 Arcade Bezels
                                Fba Arcade Bezels
                                Fba NeoGeo Bezels
                                • EfriimE
                                  Efriim
                                  I really appreciate this script and have used it since before I registered to the forums here.
                                  Since I have had the same retropie build for a while and I uninstalled two or three other shutdown scripts before installing this one.
                                  I like that I can exit the dreamcast emulator without having to use the controller. I was wondering about when I press the reset button to do this. I get this error:
                                  rc.local[__]: /opt/RetroFlag/multi_switch.sh: line 63: kill: (___) - No such process
                                  Is this normal behavior, and can I fix it?
                                  I was also wondering about the fan_shutdown additional script.
                                  When I turn my pi off, say using the Emulationstation menu to shutdown; the fan always stays on until I hit the switch on my case; Was the fan_shutdown script meant to turnoff the fan in that usage? If so what do I need to do to get it to work properly?
                                  Thanks, @cyperghost
                                  cyperghostC 1 Reply Last reply Reply Quote 2
                                    cyperghost @Efriim
                                    @Efriim This could happen if the kill command fails because the PID was closed already and the kill commands leads to a already closed process.
                                    You can add a > /dev/null 2>&1 to python script in rc.local to get rid of it.
                                    The fan script is needed for some old NESPi cases. Some users report the fan is still blowing without it. So your description sounds like that it can help in this case. I've a SNES case and I do not need it.
                                    • EfriimE
                                      Efriim @cyperghost
                                      @cyperghost
                                      I think I didn't describe the fan concisely. I was suggesting that the fan should be shutdown with the system e.g. sudo poweroff, and without having to get up and hit the powerswitch. What you say makes sense, that the fan wouldn't shutdown even when hitting the power switch on some cases.
                                      I have Retroflag MegaPi Case.
                                        cyperghost @Efriim
                                        @Efriim You may add the shutdown script according to the github description
                                        1. Install fan_shutdown script: cd /lib/systemd/system-shutdown/ && sudo wget https://raw.githubusercontent.com/crcerror/ES-generic-shutdown/master/shutdown_fan && sudo chmod +x shutdown_fan
                                        2. Install raspi-gpio with sudo apt install raspi-gpio
                                        3. The shutdown_fan is setted to GPIO4 as standard
                                        4. Therefore you might edit with sudo nano /lib/systemd/system-shutdown/shutdown_fan
                                        The script will be executed miliseconds before shutdown and will cut off power and stops the fan from everlasting blowing.
                                        • EfriimE
                                          Efriim
                                          I'm trying the different GPIO for the shutdown_fan as it isn't doing anything. I'll update if I am successful. The fan is not connected to the gpio however it is connected to the board that connects to the GPIO. I tried GPIO set 1,2,3,4,5,7,8,10 none did as I wanted it to do. Hitting the powerswitch turns off the fan as per normal.
                                          • EfriimE
                                            Efriim @cyperghost
                                            @cyperghost Hi, along with the script and its shutdown function working for dreamcast. A new feature of the reicast emulator is to save the rtc setting to emu.cfg when invoking the exit by pressing the exit hotkey. Using the script reset button to exit the emulator does, so successfully however it doesn't save the rtc settings. Meaning I have the set time/date screen until I make a clean exit with the controller and this lasts for a month or so. Do you think we will be able to add this type of exit to the script for reicast?
                                            I meant here that the reset button to exit reicast works and I am happy and proud to use this script. If there was a way to passthrough a command to reicast to initialize the poweroff where it saves the rtc, I would too like to know this.
                                            mituM cyperghostC 2 Replies Last reply Reply Quote 0
