    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 136.5k Views
    • O
      OrehRuoy @cyperghost
      @cyperghost said in Multi Switch Shutdown Script!:
      @orehruoy You can modify the code of the script of course. But if you just want to glow a LED for power on/off control then use the UART port. A simple solution and no script needed.
      Here is a guide of how to do this
      I didn't know how to access your code in the pi. I will try that other method though seems simple. Thanks.
      • darkniorD
        darknior
        I finally try your script :)
        Correct a problem for me because you install the script in /home/pi/Retropie/Scripts/ and this directory is on my USB drive.
        I can't have good right to execute .sh on USB drive with the auto-mount :p
        I change to use it in /home/pi/Scripts/ and it's perfect, thanks a lot :)
        Only one question, when i want to quit RetroArch to ES i must clic 3 time on my reset button ... Is it normal ?
        The power off button working fine every time. Using Reset in ES to restart ES is not working for me.
        Your PID detection is impressive, it works with emulators and also OpenBOR :p
        Life is game, just play it !
          cyperghost @darknior
          @darknior said in Multi Switch Shutdown Script!:
          Well the detection of button press is just checked every 1 second. So you might press the button for a longer time.
          The PID detection is introduced by runcommand script as entry point ;) And from this point I create PID array.
          • darkniorD
            darknior
            Ok thanks i understand better now :)
            Your PID idea is cool and can maybe be used to improve other scripts?
            I use this one, where we must make an array to list all the emulators and homebrews to stop music :(
            https://retropie.org.uk/forum/topic/16458/modified-background-music-script-with-added-overlays
            I'm sure we can do it with your idea, or maybe just detect when runcommand launch something and mute the music.
              @darknior That's is possible, too.
              try the parameter multi_switch.sh --es-emupid
              If it returns 0 than there is no emulator called by runcommand.
                mrfalk
                Hi there love this script and community I’m trying to implement this to a 12v relay that turns the pi on and off using NO port so it’s ether open or close depending on if the 12v trigger is on or off
                Is it possible with the generic trigger in the script?
                  cyperghost @mrfalk
                  @mrfalk Yes, this should work with generic button script.
                  So 12V closes the relais and as long your car keeps running the relais stays close. You turn off the vehicle the relais turns to off-state and releases the circuit.
                    mrfalk
                    Cool I was messing around with it yesterday but dident get it to work I’ll try again today after work.
                    And it’s not a car I’m using it’s a trigger signal from my projector that is normally used to tell screen go down when projector is on and hop when you turn the projector off.
                    But I guess it works the same.
                    And yes relay circuit is ether close or open depending in if the projector is on or off so same principle i guess
                    One question do I only install script and tell which button to use or do I need to mess with python commands?
                      cyperghost @mrfalk
                      @mrfalk
                      You download the script with wget command or insert the code with nano and make the script executable (chmod +x). By default GPIO3 (=Pin5) is used because this pin is the only one to wake the Raspberry from deep sleep. The shutdown function is independent from GPIOs but as I said only GPIO3 offers full shutdown/repower ability.
                      The just type ./multi_switch.sh --generic and follow intructions. It's very likely you need to install raspi-gpio with sudo apt install raspi-gpio before but the script will tell you.
                      Yes please report your progress. But why you want to use a relais? Opto-isolators are much cheaper and easier to use.
                      Wiki Opto Isolator
                      https://en.wikipedia.org/wiki/Opto-isolator
                        mrfalk
                        couse im a newbie at the electronic/rasberry/ stuff but learning and relay was only thing i could think of and that i had laying around =)
                        when i do ./multi_switch.sh --generic nothing happens
                        im in /RetroPie/scripts & folder and when i type ./multi_switch.sh --generic nothing comes up or happens
                        i do get it to wake up from sleep when i turn projector on and relay goes to close state.
                        but i doesent shut down when i turn projector off and relay goes to open state
                        and uhm what do i need to make it executable sorry for my noobishness =/
                        Edit
                        nvm found out how to do it
                        Edit 2
                        but still cant get shutdown to work when the relay opens the circuit and the two pins get seperated (open/not shorted) nothing happens
                        and when i do raspi-gpio set PIN# ip pu i get unknown GPIO PIN# im guessing PIN# is 3 then
                          mrfalk
                          Finally got it to work after few hours of bug searching
                          and reason was that I hade (boot to desktop auto login as pi) and change to (boot to text console auto login as pi) and Now everything workes perfectly exectly as I want it to at least hehe thx @cyperghost for all your hard work on this script was exactly what I was looking for and I would have never could have done something like this myself
                          //peace
                            cyperghost @mrfalk
                            @mrfalk
                            I think it is enough to just write ./multi_switch --generic & to send the process to background. Then you avoid the second text console ;)
                              mrfalk
                              It works great it boots in to EmulationStation and turns On/Off
                              But I encounter a problem it randomly starts it self when projector is still off and dont give out signal to relay wich means circut is open
                                cyperghost @mrfalk
                                @mrfalk Then there is a kind of "backstroke" somewhere. Maybe it's the relay coil itself, or the relais falls back in closed state somewhere.... Really have no idea why this is happening.
                                  mrfalk
                                  Yeah going to do some more bug searching I’ll get back if I’ll find what causes it //
                                  • jandalf81J
                                    jandalf81
                                    @cyperghost First of all, thank you for this script. It works great with the RetroFlag SuperPi case. But I do have a feature request...
                                    Would it be possible (and sensible?) to add fan control to this? What I mean is a way to disable the fan if the temperatures are below a certain threshold. If the temperature rises, enable the fan until the Pi has cooled down again.
                                    I know the Kintaru Super Ursus 9000 has something like this. I don't know how they've done it, though. I looked at their installer, which executes two BaSh scripts and installs a DEB package:
                                    • https://www.dropbox.com/s/gmziwqpipzpe38l/kintaroinstaller.sh (this script is executed first, it executes the next script)
                                    • https://packagecloud.io/install/repositories/kintaro/pcb/script.deb.sh (seems to install some pre-requisites for the DEB package)
                                    • last, the package kintarosnes is installed
                                    I tried to control the fan via raspi-gpio but have not been successful, yet. What I was successful at is reading the CPU and GPU temperature and making the PowerLED switch on and off:
                                    #!/bin/bash
                                    function measureTemps ()
                                    	local cpuTempC
                                    	local gpuTempC
                                    	# header
                                    	printf "DATE\t\t\t\tCPU\t\tGPU\n"
                                    	while [ true ]
                                    	do
                                    		if [[ -f "/sys/class/thermal/thermal_zone0/temp" ]]
                                    		then
                                    			cpuTempCINT=$(cat /sys/class/thermal/thermal_zone0/temp)
                                    			cpuTempC="${cpuTempCINT:0:2}.${cpuTempCINT:2:1}"
                                    		else
                                    			cpuTempC="n/a"
                                    		fi
                                    		if [[ -f "/opt/vc/bin/vcgencmd" ]]
                                    		then
                                    			gpuTempC=$(/opt/vc/bin/vcgencmd measure_temp)
                                    			gpuTempC=${gpuTempC:5:4}
                                    		else
                                    			gpuTempC="n/a"
                                    		fi
                                    		printf "$(date +%FT%T%:z):\t${cpuTempC}\t\t${gpuTempC}\n"
                                    		sleep 5
                                    	done
                                    measureTemps
                                    # RetroFlag SuperPi Case
                                    # 	PowerLED OFF
                                    # 	raspi-gpio set 14 op pn dl
                                    # 	PowerLED ON
                                    # 	raspi-gpio set 14 op pn dh
                                    Is my request even possible? I know the fan is connected to the case's PCB, but so is the PowerLED and that can be controlled!
                                      cyperghost @jandalf81
                                      @jandalf81 said in Multi Switch Shutdown Script!:
                                      Well the best solution would be a PWM fan control but I'm not very familar with such things. There are so much possibilities to control fans the easiest way to do this is due an opto-isolator. Then you add an additional GPIO to just power on/off the fan. This works same like the LED control.
                                      But to add this in the script.... No I don't think so. Because you need additional hardware. But your function could be invoked to the loop and will check button action and output CPU temperature.
                                      Sadly you can't control the fan directly through the case.... so as I wrote. You need always additional hardware and I would stay away to directly use GPIOs as power source. The 3,3V line is only capable of 100mA current. Enough for a few LEDs, microcontrollers ... but near the edge to power a 5V fan (imho)
                                      Looks like PWM control... take a look here
                                      Here someone did PWM control into NESPi case
                                      After long reading here is the short answer: No!
                                      Because:
                                      The LED is directly connected to GPIO14 so this can be controlled
                                      The fan is directly connected to main power.... Can only be controlled like the complete case -- Power Cut!
                                      But:
                                      With additional hardware and some new wiring: Yes!
                                      jandalf81J 1 Reply Last reply Reply Quote 1
                                      • jandalf81J
                                        jandalf81 @cyperghost
                                        @cyperghost
                                        Thank you very much for your reply! Although that's not the answer I had hoped for I appreciate your time and effort!
                                        Well, I'll just turn the volume up, then... ;-)
                                          If the fan is to loud then use following tricks:
                                          1. You can try to connect to 3,3Voltage (that is PIN 1 on Raspberry GPIO header - I don't recommend this)
                                          2. Let it connected to 5V and add two Si-diodes to this
                                            like:
                                          +5V --->|---->|------ FAN
                                          each diode consumes 0,6V-0,7V so you've a drop to 3,8-3,6V and the fan is more silent ;) You can also use resistors but this is a bad way I do not recommend.
                                          • denisuuD
                                            denisuu
                                            This might not the right forum to be posting this, but no one else seems to want to help and I don't have enough scripting/programming skills to understand your script.
                                            I have my pi partitioned with PINN (Retropie, OSMC and Raspbian) However your script only works on Retropie. I found another script that does work on both OSMC & Raspbian but doesn't shut down the PI completely. The standby light stays on and the fans keep spinning.
                                            I want to add the shutdown_fan part from your script to this script: LINK
                                            #!/usr/bin/python
                                            import RPi.GPIO as GPIO
                                            import os
                                            # hide warning
                                            GPIO.setwarnings(0)
                                            # connect RPi numbered pin
                                            button = 5
                                            # hide warning
                                            GPIO.setwarnings(0)
                                            # pins setup
                                            GPIO.setmode(GPIO.BOARD)
                                            GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                                            # wait for button press
                                            print('Wait for button press...')
                                            GPIO.wait_for_edge(button, GPIO.FALLING)
                                            # activate system command
                                            # Updated to make true safe shutdown w/emustation (incase OSMC has been added)
                                            os.system('sudo sleep 5s & sudo shutdown -h now')
                                            From what I understand I need parts from these parts?:
                                            #From shutdown_fan script
                                            [ "$1" = "poweroff" ] && raspi-gpio set 4 op pn dl
                                            #From multi_switch.sh scipt
                                            echo "    PowerOnControl GPIO 4 (BCM 4), output, high, power on control!"
                                                    pack_check raspi-gpio
                                                    cli_parameter resetbtn= powerbtn= powerctrl= ledctrl=
                                                    NESPiPlus ${call[@]}
                                            function cli_parameter() {
                                                unset call
                                                local PARAMETER=$@
                                                for i in ${PARAMETER[@]}; do
                                                    value="${CLI#*$i}"
                                                    [[ $value != $PARAMETER ]] && value="${value%% *}" || value="-1"
                                                    [[ $value =~ ^[0-9]{1,2}$ ]] || value="-1"
                                                    call+=("$value")
                                                done
