    How do i move retropie from sub back to sd card basically undo manual mount
    support
    20 Posts 3 Posters 1.5k Views
      chris419
      I have a rasberry pi. 3 modle b n im running retropie 4.4. Had no luck loading roms so i tryed manual mounting it n now icant do any thing anyone know how to undo this n get retropie back on my startup screen n no uuid set up did not work
        mitu Global Moderator @chris419
        @chris419 If you're just starting, re-write the RetroPie image to the sd-card again and start over.
          chris419 @mitu
          @mitu. Do i have to redo the usb drive to or is that ok i couldnt get it to transfer the roms at all n had problems geting the file names to the usb from retropie
            @chris419 I'm sorry, maybe I misunderstood - what's the actual problem ? The USB drive or RetroPie not loading when you start your PI ?
              chris419 @mitu
              @mitu emulatonstaton is fine i manuly mounted my usb n the camands sent the retropie menue to my usb. I have both formated to windows 10 at fat32 but the uuid commands didnt work n i couldnt get. The usb to auto mount n all my options are on my usb
                chris419 @chris419
                @chris419 im basicly looking for the comand to put everything from my usb back on my sd card
                  mediamogul Global Moderator @chris419
                  @chris419
                  It might help to nail down the specific information requested at https://retropie.org.uk/forum/topic/3/read-this-first. Along with the rest of the information, take care to note what method it was you used to transfer the files. For instance, did you use the automatic or manual process documented here?
                    chris419 @mediamogul
                    @mediamogul. Yes this is the exact prossece i used.
                      chris419 @chris419
                      @chris419. After sudo line code to move fretropie to usb. Nothing worked line code wise
                        @chris419 You don't need to move anything. If you used the automatic method, the proper folders will be created automatically and you'll be able to see them on the PC.
                        From what's you're saying, did you try the manual method ?
                          chris419 @mitu
                          @mitu automatic method didnt do anything the usb didnt transfrer n after 3 hrs im sure thr 4.6 gs would have done it n yyes i went thre manual thats how retropie got sent to my usb
                          C mituM 2 Replies Last reply Reply Quote 0
                            chris419 @chris419
                            @chris419 sudo mv -v/home/pi/retropie/* /media/usb0/
                              @chris419 In Linux, the commands, as well as filenames, are case-sensitive. So copy and paste the command from the docs AS IS:
                              # correct command
                              sudo mv -v /home/pi/RetroPie/* /media/usb0/
                              # wrong command
                              # sudo mv -v/home/pi/retropie/* /media/usb0/
                              If this gives an error, then please paste the error here so we can take a look.
                                chris419 @mitu
                                @mitu. Ok i did this properly thats why it was moved to the usb. Uuid is where im haveing problems once i get to the step after the command i posted. The commands dont work
                                  chris419 @chris419
                                  @chris419 im just gonna take it to my couzins n have him flash it with lenix n directly put the roms on the sd card thanks for the time but none of u guys helped at all
                                  mituM mediamogulM 2 Replies Last reply Reply Quote 0
                                    @chris419 Word !
                                      @chris419
                                      What, we don't get credit for helping you reconnect with your cousin?
                                        @mediamogul lol no i been bitching at him for a week to help me with this he lives a block away
                                          chris419 @chris419
                                          @chris419 he actuly blew me off the day i started this so i went to my ex wifes to use her labtop to do this im running vista still
                                            @chris419
                                            My brother lives a block over and has been promising to bring my sling blade back for over a month. It's such a nice day out, I think I'll walk over there and borrow it back.
