    Shock Troopers (shocktro.zip) not loading using FBA:
    fbashock troopersnot loading
    43 Posts 8 Posters 15.2k Views
      dankcushions Global Moderator @barbudreadmon
      @barbudreadmon said in Shock Troopers (shocktro.zip) not loading using FBA::
      This is seriously depressing when people prefer trusting a web page instead of what the emulator is showing in its menu. The fbalpha2012 version shown in the wiki page is also wrong, it has been known for almost 3 years that it was not 0.2.97.30, and the emulator menu has been showing 0.2.97.29 for almost 2 years.
      be fair - the github for 2012 says 0.2.97.24! also, i was going to update it ages ago but then we had this conversation: https://github.com/libretro/fbalpha2012/issues/53 - i thought it was .24 with some backports from .29/.30? who knows what the right romset is to use with that thing...
        barbudreadmon @dankcushions
        @dankcushions said in Shock Troopers (shocktro.zip) not loading using FBA::
        I was just stating the fact people shouldn't blindly trust a wiki page. Imho, at least for lr-fbalpha, you should just link the repository for information about the last release and the dats.
        • robertvb83R
          robertvb83 @dankcushions
          @dankcushions i fully understand that. Also your leck of motivation. For mame and fba related emulation it is nearly impossible to keep everything up to date. For me it was for long time not easy to understand what this is all about. Why the heck do i need to sort ALL roms new in case of an update and not only put some new roms in the set. (i know better now, as i understand the concept more clearly)
          i did not really get the point when commenting that one. I thought more in the direction that there are different types of emulators but they are pretty much fixed. and thus there is a fixed corresponding romset... so i was just confused that there would be a different fba emulator as retropie standard with a new romset that is not described anywhere
          I think mame will never be a plug and play thing. If you want it working nice you have to deal with it and learn. But that is ok for me considering the insane benefit and historical meaning of this project.
          My full size arcade cabinet Robotron vs. Octolyzer
            i agree - i did update all the dat links a while back to the actual files on the repo, but those links might now be dead following the update, not checked.
            it's a bit difficult for us as the documentation here repeats much stuff from github readmes, but also those tend to be written for a different audience (our audience does not need to know build instructions, etc, since retropie's scripts do all that). the balance is tricky!
              As a sidenote, there is quite a lot of new things in the readme, perhaps you should take a look.
                clewis
                I just tried compiling from source, and it still installs v0.2.97.42. I would like to upgrade to v0.2.97.43. Did something change or am I doing something wrong?
                  mitu Global Moderator @clewis
                  @clewis What version of RetroPie are you using ?
                    clewis @mitu
                    4.4.1
                    I tried compiling on a RPI3 and a RPI3B+
                      @clewis If you have 4.4.1, then installing from source will get you the latest version of libretro-fbalpha from the github repository, which should be v0.2.97.43. How are you checking the version ? Note that the install script still outputs Installing .. v0.2.97.42 in the logs, but if you check in RetroArch, after starting a game, it should show the right version.
                        clewis
                        I see! Let me check that.
                        I was hoping to play vertical classics without the need of samples, and I guess lr-mame2016 is not compiling for anyone right now? Anyway, this version of FBA is based off Mame .197? I was hoping to get more accurate colors, and not have to use sound samples.
                        BRB and thanks!
                        You were right, and it is .43
                        Unfortunately DK colors and sounds are not like lr-mame2016 so I'm stuck. Thanks for your help!
                          barbudreadmon @clewis
                          @clewis said in Shock Troopers (shocktro.zip) not loading using FBA::
                          If you think something is wrong with colors or sound in current fba, give more details (DK is Donkey Kong ?).
                          Also, be aware that mame2016 is not current mame.
                            clewis @barbudreadmon
                            @barbudreadmon
                            EDIT: I just read some of your posts and I didn't realize who you were. Sorry I'm new!
                            Using Donkey Kong as an example, there are classic arcade games that would historically require sound samples in order to get all of the sound effects or music. These days in Mame, samples are no longer required for Donkey Kong and others. lr-mame2016 is new enough that the sounds are all emulated.
                            As far as the colors go, here are some pics:
                            This is FBA. The colors are the same as mame2003.
                            Here is the actual PCB. I would show how close mame2016 is, but It can't be compiled on Stretch yet, but it is so close I can't tell the difference.
                            Sorry for the glare! I know most people don't care as much for the 80's verticals and are more interested in the 90's horizontals.
                              @clewis Removing the sound samples would be hard at this moment, proper sound support is not an easy one for this hardware. Are there missing sounds in the samples ? I also took a look at the color issue and something can probably be done about it. I'll let you know as soon as i get a feedback about it from upstream.
                                @barbudreadmon
                                Thanks barbudreadmon!
                                The samples are all there. The analog sounds that are sampled, are way louder than the digital sounds that are emulated. What you get is Jumpman's footsteps super loud and the barrel jumping sound too quiet.
                                It's great that the color fix might be doable. That would be huge!!
                                B 3 Replies Last reply Reply Quote 0
                                  Even if they are samples, i guess some balance adjustment could be done.
                                    @clewis 2 good news :
                                    • i found out why lr-mame2016 fails building, i just created the PR to fix it, it should be merged soon
                                    • i just tested the dkong color fix for fba (and compared it to lr-mame2016), it looks great, if the fba standalone team gives me the ok (this is new stuff and not a simple hotfix, this kind of improvement is generally only made public when a new standalone fba is released), i'll push it to the lr-fbalpha repository later today, otherwise you'll have to wait for the .44 release.
                                      @clewis i just got the ok from upstream, fba now displays the proper colors in dkong (it was fixed in mame141u2 btw). I'll also open an issue on mame2003-plus's github, perhaps they'll be able to port the new code to their mame core.
                                        barbudreadmon @barbudreadmon
                                        To be fair i only fixed building on x86/x86_64, to my knowledge it doesn't support arm, and it wouldn't run well on a rpi anyway.
                                          This is really amazing, and huge thanks!
                                          I will compile tonight and try it out.
                                            It actually runs the older vertical games really well. I will try compiling this one tomorrow night.
                                            Again, amazing and thanks!
