    SNES Gamelist.xml Will Not Save
    gamelist.xmlsnes
    4 Posts 2 Posters 635 Views
    • GreenHawk84G
      GreenHawk84
      Hello,
      I was editing my Metadata in Emulationstation and got tired of typing over and over again. So I tried to open the gamelist.xml for SNES and copy/paste lines of paths to marquee files. Well before I started I copied the gamelist "as-is" to my desktop. Then I noticed the gamelist was not saving. I went back to edit marquee paths the manual way in Emulationstation, but upon restart, the system said it could not save the file. Now my gamelist cannot be edited.
      Here is the file: https://1drv.ms/u/s!AluYjzvuXNufiSCFoDRCeCeEd7fF
      Any ideas?
      Update: I can go in through WinSCP and save the file that way, but I can no longer edit the SNES metadata while in Emulationstation. The edit will take, but will not save on restart/shutdown.
      KN4THXK 1 Reply Last reply Reply Quote 0
      • KN4THXK
        KN4THX @GreenHawk84
        @greenhawk84 Try resetting permissions through the Retropie Setup script
        "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
        GreenHawk84G 1 Reply Last reply Reply Quote 1
        • GreenHawk84G
          GreenHawk84
          Thank you for the advice, it hasn't been easy to get help lately. I will try this later after work, but I must note that I was able to edit Sega Genesis metadata through Emulationstation and it saved normally. Not sure if that means the SNES gamelist has a problem alone.
          • GreenHawk84G
            GreenHawk84 @KN4THX
            @thedatacereal not sure how to do your suggestion. :(
            Update: GOT IT! Yea, win!
