    Playstation 1 controls are working except for Diablo 1 plese help
    controllerpsxdiablo
    8 Posts 4 Posters 4.4k Views
    • Z
      zhajdu
      Pi Model or other hardware: 3 B i think(aliexpress is not quite straitfowrad)
      Power Supply used: 3 A ; https://www.aliexpress.com/item/Raspberry-Pi-3-Model-B-Plus-Starter-Kit-ABS-Case-16-32-GB-SD-Card-3A/32832744933.html
      RetroPie Version Used: 4.3
      Built From:Retropie version 4.3, no image was used
      USB Devices connected: 2x Dragonrise zero delay controllers in slot 1 and 2 on Pi. (joysticsks are connected with 5 pin cable) USB extension with 3 holes with 2 SNES like usb controllers. No other devices used
      https://www.aliexpress.com/item/G3-Office-Computer-Desk-Round-Hole-USB-Splitter-USB-Hubs-Converter-Laptop-PC-Mac-Expansion-Interface/32885072444.html
      https://www.aliexpress.com/item/USB-Controller-Gaming-Joystick-Gamepad-Controller-for-Nintendo-SNES-Game-pad-for-Windows-PC-For-MAC/32863906297.html
      https://www.aliexpress.com/item/Free-Shipping-2-Player-Zero-Delay-MAME-Cabinet-DIY-Kits-Parts-Encoder-8-Way-Joystick-20x/32657362835.html
      Error messages received: No error message
      Problem is that play station controllers are working for all the roms only not for diablo. Do you have an ide what to do? should i configure it in retroarch?
        mitu Global Moderator @zhajdu
        @zhajdu said in Playstation 1 controls are working except for Diablo 1 plese help:
        You don't have any PS controllers in the list you posted. Do you mean controls in Playstation games ? If yes, then some PS1 games require an analog controller present and they don't respond to controls if they don't detect one. Use RetroArch gui to switch the controller (RetroPad) to analog + digital - see https://retropie.org.uk/docs/Playstation-1/#analog-controller-type.
        • Z
          zhajdu @mitu
          @mitu thank you
            aewoodall520
            You need to download the psx bios scph1001.bin
            mituM 1 Reply Last reply Reply Quote 1
              mitu Global Moderator @aewoodall520
              @aewoodall520 Please don't post to years old topics, and without adding any useful information to it.
                Blixa @mitu
                @mitu Hello there, just wanted to point out his advice was the only one that helped me after two days of searching.
                  mitu Global Moderator @Blixa
                  @blixa So you had the same issue as @zhajdu and only the reply from @aewoodall520 has provided the solution ? The PS1 doc page already has the same info - https://retropie.org.uk/docs/Playstation-1/#bios.
                  B 1 Reply Last reply Reply Quote 2
                    Blixa @mitu
                    @mitu Yes. And you are right. Unfortunatelly I did not realize each emulated system needs it's BIOS. It was indeed written in the link that was provided. I was looking for a specific controller problem and being new to the whole raspberry thing, I overlooked that information.
                    @aewoodall520 just happened to point out the thing I was missing.
                    P.S.: After updating the ES, I had to reconfigure the controlls for PSX again. It was a breeze thanks to your link, thank you.
