    Need guidance: Best MAME emulator to use for classic 80's games?
    guidancemameclassic80s
    71 Posts 7 Posters 51.4k Views
    • RiverstormR
      Riverstorm @dankcushions
      @dankcushions said in Need guidance: Best MAME emulator to use for classic 80's games?:
      @Riverstorm thanks, I wrote it :) I have corrected the quotes thing. well spotted!
      and that link you posted is the readme for the core - it's not retropie specific, so some of the instructions are too retropie -centric to go there.
      our mame2003 wiki linked on the retropie wiki (scroll down in the mame page), but I know what you mean - the first links at the top of the mame page are to the GitHub projects. that's just how the wiki was originally written, but I do think it could be restructured in that regard, so each core has its own wiki page, but yeah... someday!
      Ok, I found it further down the page where you indicated. The Github projects are a bit confusing to say the least. The one you wrote is fantastic! I was able to get lr-mame2003 up and running and tweak it perfectly using it. Thank you! :)
        dankcushions Global Moderator @briankross
        @briankross said in Need guidance: Best MAME emulator to use for classic 80's games?:
        @dankcushions
        Good idea!
        Which file are you editing to change or include directories?
        the .rc files in /opt/retropie/configs/mame-advmame/
        When you have multiple paths for the same thing, will it still recreate folders in the rom folder? (I'm assuming it will). I'm looking to point the AdvanceMAME folders to another logical location so it will no longer recreate folders in the rom folder root directory, cleaning it up a bit.
        it only creates folders where you tell it to in the .rc. if you have multiple it will create them in both. it seems to read files from both, but it will only update or create files in the first one in the list, at least in my tests.
        • RiverstormR
          works for me. are you using the latest version? i fixed this stuff semi-recently. you might need to rebuild from source.
          I downloaded the source code from RetroPie Setup. Is there a Wiki on the steps to compile it? I did a search and found steps for 2010 but not 2003.
          I saw a lot of errors similar to this downloading the source. Is that fairly typical more like warnings of defined unused variables?
          src/vidhrdw/konamiic.c:6347:24: warning: variable âsrc_moduloâ set but not used [-Wunused-but-set-variable]
            int count, src_pitch, src_modulo;
          I was wondering also with the newest can you use the left and right analog sticks on a controller like the XBOX 360?
          The other button I see that doesn't work on the older version is the XBOX action button (silver button in center). I was using that to enter the MAME TAB setup from controller as it was pretty handy.
            dankcushions Global Moderator @Riverstorm
            @Riverstorm said in Need guidance: Best MAME emulator to use for classic 80's games?:
            that's all done for you by retropie-setup as part of the update/install from source process. downloading the raw source would take seconds.
            typical of old code :) warnings are 'fine'. errors will cause the compile to fail.
            oh, depending on your version of retropie you may also need to update retroarch (from binaries is fine).
            • RiverstormR
              Thanks Dank, I am mainly using 3.7 would that require a Retroarch upgrade?
              Also should the left and right analog sticks and the XBOX action button (silver button in center) work or is that a feature request? :) I used them frequently in my TAB--General Input Configuration for MAME. Referring to lr-mame2003 of course as it does work in mame4all-pi, lr-imame4all and AdvMAME.
              • RiverstormR
                Riverstorm
                @dankcushions The new source fixed the history.dat issue. Very nice! There's some good information in the history.dat. Cheats work great.
                Everything works except using the analog sticks and XBOX button in the Configure Input menu. Is their a way to enable them or is that an enhancement that might come in the future?
                Nice job with lr-mame2003! Have a great holiday weekend if it applies! ;)
                • RiverstormR
                  Riverstorm
                  @dankcushions & @caver01 Artwork does work with the new source.
                    mediamogul Global Moderator @Riverstorm
                    Very nice to hear. Is there any noticeable slowdown?
                    EDIT:
                    Everything works except using the analog sticks and XBOX button in the Configure Input menu. Is their a way to enable them?
                    As a temporary solution to this problem, I have mapped the left and right analog sticks, as well as the XBox button to read as keyboard input and it works very well.
                      After updating RetroArch from binary, lr-mame2003 from source, adding a complete 'artwork' folder to /home/pi/RetroPie/BIOS/mame2003/ and changing the name of /home/pi/RetroPie/BIOS/mame2003/sample to 'samples', I neither have artwork or samples functioning. Are they now meant to be enabled somewhere with this newest version?
                      • RiverstormR
                        Riverstorm @mediamogul
                        @mediamogul said in Need guidance: Best MAME emulator to use for classic 80's games?:
                        As far as I can tell there isn't any slowdown. I know this is a bit simplified but artwork is more like a wallpaper. Something I wasn't even aware of was the ability to set the translucency of the artwork. Thanks to Caver for a great tutorial on vector based games.
                        I think getting the analog sticks working would be a tremendous asset as they can be used for the management function (TAB menu) but also they may be utilized for several dual joystick games like Crazy Climber, Cloak & Dagger, Karate Champ, Robotron, Smash T.V., Total Carnage, Batte Zone, Front Line (I think this one required a spinner too). It basically allows you to play those games with a joystick like the XBOX or PS.
                        No, if you have them in the correct folders (which they look right) you should be good to go. :)
                        mediamogulM caver01C 2 Replies Last reply Reply Quote 0
                          Re-reading what I wrote, I realized it was a little ambiguous and perhaps you knew exactly what I meant, but what I was trying to express was that I've mapped the analog sticks of my gamepad to output keyboard keys so that use of the sticks can register in MAME for the games you mentioned. This works out quite nicely as those games don't rely on the full analog range that is lost in that particular solution. Of course getting those sticks to register without a workaround would be most ideal. I logged a report about the issue, but at the time I was under the impression that it just affected the right joystick. This is likely because I have RetroArch configured to duplicate the DPad control to the left analog stick.
                          About the samples and artwork, I just can't seem to get that working. I'm going to try installing the required pieces again to see if I missed something along the way. If that doesn't work, I'll probably open up a separate topic for my issue as this thread is likely to suffer an identity crisis with any additional topics of conversation. If I do, I'd appreciate your input on the matter, if you have any thoughts.
                          • caver01C
                            caver01 @Riverstorm
                            Frontline (I used to love playing this in the arcade) originally had a big rotary dial to aim your gun. It clicked as you rotated it to aim the gun in 8 directions and was also a pushbutton (push to fire). This is nearly impossible to play with arcade controls unless you have the dial described, but I could see how using two sticks and LR shoulder buttons on a hand-held controller might work.
                              I was pleased to see him make mention of 'Cloak & Dagger'. I love the
                              and the game. I'm considering going to this year's 'Mid-Atlantic Nostalgia Convention' to ask Dabne Coleman why they never released a 'Cloak & Dagger' breakfast cereal.
                              • RiverstormR
                                Riverstorm @caver01
                                @caver01 said in Need guidance: Best MAME emulator to use for classic 80's games?:
                                Ah, that's right! You have to love the classics. I did grab a copy of Ready Player One from Ernest Cline you said was a classic. I will give it a read through this fall/winter when spending more time indoors. We have tough winters here so you have to take advantage of these nice long warm light days getting those outdoor projects done. :)
                                @mediamogul
                                The true mysteries of the universe! :) Is he still alive, he must be as old as dirt. Some good old movies but another classic from that era is War Games with Dabney Coleman, Matthew Broderick and Ally Sheedy.
                                  He was actually around to beta test the stuff that ended up becoming dirt. He looks great for a guy his age though. I love his movies and I hope I can work out the trip to meet him in September. You're in for a HUGE treat with 'Ready Player One'. I'll likely end up reading it a third time before Spielberg's movie adaptation comes out.
                                  • RiverstormR
                                    I don't have a lot of input here. What I did was an update from the RetroPie setup. It took like 30 to 45 minutes it seemed. Nothing special as it downloads, compiles, etc. It's a one-click upgrade. Very nice!
                                    I created those two folders "artwork" and "samples" and then copied files over. The only thing I can think of is they are not the correct versions/names possibly?
                                      That's really all it can be. I'll reinstall everything later today and hope for the best.
                                      • caver01C
                                        caver01 @Riverstorm
                                        It's a fun read for sure! I recommend the Audio book version too. Just make sure you read it before the movie comes out (2018, so you have time).
                                        • RiverstormR
                                          I spoke a bit to soon. I must have been in the wrong MAME since they all show the same ES icon. I have 3, one for lr-imame4all, AdvMAME and lr-mame2003. I think the only way to tell the difference is knowing your gamelist and when you launch a game and you briefly see the emulator started. Right now my AdvMAME and lr-mame2003 are almost identical. Anyway I don't have samples or artwork working either.
                                          I verified the samples with both the Wiki DAT:
                                          https://github.com/RetroPie/RetroPie-Setup/wiki/Managing-ROMs
                                          I also used the official MAME 0.78 executable to create a DAT.
                                          Both show dkong.zip should contain:
                                          effect00.wav
                                          effect01.wav
                                          effect02.wav
                                          When running the game it's missing sounds when the Donkey Kong is stomping the girders in the intro. It's also missing the running and jumping sounds.
                                          I also re-checked Solar Quest and the artwork does not work. The zip is solarq.zip. The files contained within are:
                                          solarq.art
                                          I am using the same artwork for AdvMAME which has the dark blue translucent backdrop and red/yellow colored circles.
                                          Can anyone that does have it working verify the sample names and if it Donkey Kong or another game does have working sound samples in lr-mame2003? (CRC doesn't matter with samples just the proper name).
                                            @Riverstorm where are your samples/artwork? see https://github.com/RetroPie/RetroPie-Setup/wiki/lr-mame2003#samples for the correct location for samples. artwork isn't documented, but it's in the same place (although in .../artwork rather than .../samples)
                                            mediamogulM RiverstormR 2 Replies Last reply Reply Quote 0
