    Bluetooth no longer working after fresh install
    bluetooth8bitdo sn30 pro
    60 Posts 6 Posters 5.1k Views
      psyke83 Global Moderator
      My daemon log shows similar (but not all of your) errors:
      ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Tue 2019-02-19 17:57:35 GMT; 24h ago
           Docs: man:bluetoothd(8)
       Main PID: 527 (bluetoothd)
         Status: "Running"
         CGroup: /system.slice/bluetooth.service
                 └─527 /usr/lib/bluetooth/bluetoothd
      Feb 19 17:57:35 retropie systemd[1]: Starting Bluetooth service...
      Feb 19 17:57:35 retropie bluetoothd[527]: Bluetooth daemon 5.43
      Feb 19 17:57:35 retropie systemd[1]: Started Bluetooth service.
      Feb 19 17:57:35 retropie bluetoothd[527]: Starting SDP server
      Feb 19 17:57:35 retropie bluetoothd[527]: Bluetooth management interface 1.14 initialized
      Feb 19 17:57:35 retropie bluetoothd[527]: Failed to obtain handles for "Service Changed" characteristic
      Feb 19 17:57:35 retropie bluetoothd[527]: Sap driver initialization failed.
      Feb 19 17:57:35 retropie bluetoothd[527]: sap-server: Operation not permitted (1)
      Feb 19 17:57:35 retropie bluetoothd[527]: Endpoint registered: sender=:1.5 path=/A2DP/SBC/Source/1
      Feb 19 17:57:35 retropie bluetoothd[527]: Failed to set privacy: Rejected (0x0b)
      Are you absolutely certain that you tested the latest master script, making sure to remove the device before registration?
      Again, to return to master:
      git checkout master
      I can't really see how my changes would negatively affect the authentication phase, as I didn't change anything in that part of the script.
        charleszimm @psyke83
        @psyke83 I'm positive. I looked through the commit log and I agree: It doesn't quite look like any of the changes that were made should really affect the handoff between the device and the service.
        I removed the controller, checked back out to master, confirmed in the Setup script that we're at 5dff90ef, and tried to resync the controller through the Bluetooth menu. With the controller in the same mode (Switch) that worked on 179e2f37, I'm back to getting the message:
        An error occurred connecting to the bluetooth device (Creating device failed: org.bluez.Error.AuthenicationFailed: Authentication Failed)
        If I go into bluetoothctl, I get the familiar Yes/No:
        [bluetooth]# connect 98:B6:E9:42:4B:35
        Attempting to connect to 98:B6:E9:42:4B:35
        [CHG] Device 98:B6:E9:42:4B:35 Connected: yes
        [CHG] Device 98:B6:E9:42:4B:35 Connected: no
        I'm not sure where you're located but I'm in the northeast of the US and we're getting pounded with snow so I'm going to start our digging out. Let me know if you want me try anything else today!
          @charleszimm
          We can try to zero in on what may possibly cause the issue.
          See this test change: https://github.com/RetroPie/RetroPie-Setup/compare/master...psyke83:bluez_test
          This will break sixaxis pairing, but let's see if it helps in your case.
          You can test by adding my repo as a remote and then check out the branch:
          git remote add psyke https://github.com/psyke83/RetroPie-Setup.git
          git fetch psyke
          git checkout psyke/bluez_test
          As far as I can tell, enabling and setting the default-agent takes effect for the active bluetoothctl session only, and should be unregistered as soon as the scanning has finished... so I'm skeptical as to whether this is the root of the issue.
          I've also created another commit on a separate branch that will still set up the agent, but only removes the part that responds to authorization challenges: https://github.com/RetroPie/RetroPie-Setup/compare/master...psyke83:bluez_test2
          To test this one (assuming you've already added the psyke remote):
          git checkout psyke/bluez_test2
          I'd appreciate if you could try both and let me know which ones work (or not), and we can move on from there.
          I suspect that both will work, and might see the potential issue. If your device is actually producing an authorization prompt, the final "disconnect" command may be turning off your controller just before you reach the security type section. But, let's wait and see.
          Good luck with the excavation and keep safe! :)
            @psyke83 Okay I have survived clearing my driveway and have a whiskey in hand so let's continue.
            I cleared out the devices from bluetoothctl and on the psyke/bluez_test build (854a114e), I get the bluez Authentication Failed message, along with the Connected Yes/No in bluetoothctl.
            Moving on to bluez_test2 (f2d44077), same result. Authentication failed, Connected Yes/No in bluetoothctl.
              psyke83 Global Moderator @charleszimm
              @charleszimm
              I'm a bit stumped, then. I don't see any significant changes to explain why you're having this problem.
              Am I missing something obvious?
              git diff master 2c9fa79a1ae41c2988d21bd179c33ce515e29245 -- scriptmodules/supplementary/bluetooth.sh
              The only behaviour difference is the method in which commands are redirected to the bluetoothctl shell (with a deliberate 1 second pause between lines), but I really don't see why that'd cause this issue, as it only affects the "Scanning" phase and not the subsequent authorization which is done via bluez-simple-agent.
              You're certain that for each test you've followed the same procedure to remove/register, turned on the controller in the appropriate mode and selected the same security type? Was the successful pairing with the older version of the script a fluke or does it work reliably every time?
              I'm not sure what else to suggest as the bluez_test branch has very little changed apart from the "slow echo" code which I don't think would change anything.
                @psyke83 Positive same scenario. Here's the results from the git diff:
                diff --git a/scriptmodules/supplementary/bluetooth.sh b/scriptmodules/supplementary/bluetooth.sh
                index f0c0b3d5..3cdd4c49 100644
                --- a/scriptmodules/supplementary/bluetooth.sh
                +++ b/scriptmodules/supplementary/bluetooth.sh
                @@ -46,37 +46,34 @@ function get_script_bluetooth() {
                     echo "$name"
                -function _slowecho_bluetooth() {
                -    local line
                -    IFS=$'\n'
                -    for line in $(echo -e "${1}"); do
                -        echo -e "$line"
                -        sleep 1
                -    done
                -    unset IFS
                 function bluez_cmd_bluetooth() {
                     # create a named pipe & fd for input for bluetoothctl
                     local fifo="$(mktemp -u)"
                     mkfifo "$fifo"
                     exec 3<>"$fifo"
                     local line
                -    while true; do
                -        _slowecho_bluetooth "$1" >&3
                -        # collect output for specified amount of time, then echo it
                -        while read -r line; do
                -            printf '%s\n' "$line"
                -            # (slow) reply to any optional challenges
                -            if [[ -n "$3" && "$line" =~ $3 ]]; then
                -                _slowecho_bluetooth "$4" >&3
                +    while read -r line; do
                +        if [[ "$line" == *"[bluetooth]"* ]]; then
                +            echo -e "$1" >&3
                +            read -r line
                +            if [[ -n "$2" ]]; then
                +                # collect output for specified amount of time, then echo it
                +                local buf
                +                while read -r -t "$2" line; do
                +                    buf+=("$line")
                +                    # reply to any optional challenges
                +                    if [[ -n "$4" && "$line" == *"$3"* ]]; then
                +                        echo -e "$4" >&3
                +                    fi
                +                done
                +                printf '%s\n' "${buf[@]}"
                             fi
                -        done
                -        _slowecho_bluetooth "quit\n" >&3
                -        break
                +            sleep 1
                +            echo -e "quit" >&3
                +            break
                +        fi
                     # read from bluetoothctl buffered line by line
                -    done < <(timeout "$2" stdbuf -oL bluetoothctl --agent=NoInputNoOutput <&3)
                +    done < <(stdbuf -oL bluetoothctl <&3)
                     exec 3>&-
                @@ -86,15 +83,16 @@ function list_available_bluetooth() {
                     local info_text="\n\nSearching ..."
                     # sixaxis: add USB pairing information
                -    [[ -n "$(lsmod | grep hid_sony)" ]] && info_text="Searching ...\n\nDualShock registration: while this text is visible, unplug and replug the controller, then press the PS/SHARE button."
                +    [[ -n "$(lsmod | grep hid_sony)" ]] && info_text="Searching ...\n\n(To register a DualShock controller, please unplug and replug your controller while this text is visible...)"
                     dialog --backtitle "$__backtitle" --infobox "$info_text" 7 60 >/dev/tty
                     if hasPackage bluez 5; then
                         # sixaxis: reply to authorization challenge on USB cable connect
                +        [[ -n "$(lsmod | grep hid_sony)" ]] && bluez_cmd_bluetooth "default-agent" "10" "Authorize" "yes" >/dev/null &
                         while read mac_address; read device_name; do
                             echo "$mac_address"
                             echo "$device_name"
                -        done < <(bluez_cmd_bluetooth "default-agent\nscan on" "15" "Authorize service$" "yes\ntrust\ndisconnect" >/dev/null; bluez_cmd_bluetooth "devices" "3" | grep "^Device " | cut -d" " -f2,3- | sed 's/ /\n/')
                +        done < <(bluez_cmd_bluetooth "scan on" "10" >/dev/null; bluez_cmd_bluetooth "devices" "2" | grep "^Device " | cut -d" " -f2,3- | sed 's/ /\n/')
                     else
                         while read; read mac_address; read device_name; do
                             echo "$mac_address"
                @@ -400,7 +398,7 @@ function gui_bluetooth() {
                         local choice=$("${cmd[@]}" "${options[@]}" 2>&1 >/dev/tty)
                         if [[ -n "$choice" ]]; then
                             # temporarily restore Bluetooth stack (if needed)
                -            service sixad status &>/dev/null && sixad -r
                +            service sixad status >/dev/null && sixad -r
                             case "$choice" in
                                 R)
                                     register_bluetooth
                @@ -427,7 +425,7 @@ function gui_bluetooth() {
                             esac
                         else
                             # restart sixad (if running)
                -            service sixad status &>/dev/null && service sixad restart && printMsgs "dialog" "NOTICE: The ps3controller driver was temporarily interrupted in order to allow compatibility with standard Bluetooth peripherals. Please re-pair your Dual Shock controller to continue (or disregard this message if currently using another controller)."
                +            service sixad status >/dev/null && service sixad restart && printMsgs "dialog" "NOTICE: The ps3controller driver was temporarily interrupted in order to allow compatibility with standard Bluetooth peripherals. Please re-pair your Dual Shock controller to continue (or disregard this message if currently using another controller)."
                             break
                         fi
                     done
                  @charleszimm
                  We're kind of grasping at straws now, but try the bluez_test3 branch:
                  git fetch psyke
                  git checkout psyke/bluez_test3
                  That branch just reverts the code adding the new "slow echo" function in case it's somehow causing the issue.
                    @psyke83 said in Bluetooth no longer working after fresh install:
                    Okay so same thing with the Authentication Failure. Made sure that the controller wasn't in the Display Registered & Connected Bluetooth Devices menu as well as not in bluetoothctl before getting into that branch.
                    In bluetoothctl when I look at info:
                    [bluetooth]# info 98:B6:E9:42:4B:35
                    	Name: Pro Controller
                    	Alias: Pro Controller
                    	Class: 0x002508
                    	Icon: input-gaming
                    	Paired: yes
                    	Trusted: no
                    	Blocked: no
                    	Connected: no
                    	LegacyPairing: no
                    [bluetooth]# trust 98:B6:E9:42:4B:35
                    [CHG] Device 98:B6:E9:42:4B:35 Trusted: yes
                    Changing 98:B6:E9:42:4B:35 trust succeeded
                    So I removed your branches and brought back down the code from 12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e, then removed the controller:
                    pi@theaterretropie:~/RetroPie-Setup $ git checkout 12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e^
                    Previous HEAD position was 45645719... bluetooth test3
                    HEAD is now at 179e2f37... Merge pull request #2591 from cmitu/dolphin-build
                    pi@theaterretropie:~/RetroPie-Setup $ bluetoothctl
                    [NEW] Controller B8:27:EB:81:C7:4C theaterretropie [default]
                    [NEW] Device 98:B6:E9:42:4B:35 Pro Controller
                    [bluetooth]# remove 98:B6:E9:42:4B:35
                    [DEL] Device 98:B6:E9:42:4B:35 Pro Controller
                    Device has been removed
                    [bluetooth]# exit
                    [DEL] Controller B8:27:EB:81:C7:4C theaterretropie [default]
                    Confirmed in that version of the setup script (HEAD 179e2f37) that no devices were connected and then tried to connect the controller. Remember when you said it might have been a fluke that it worked before? I think you might be right. Authentication Failure again.
                    There's obviously other people besides me, you, and @BuZz viewing this. Has anyone else besides @snoogans had this issue?
                      @charleszimm
                      Dive back into bluetoothctl-only for a moment...
                      I suspect that the authorization is failing via the script, but when you manually "trust" via the shell, it will work... with the important caveat that you power cycle (or disconnect) the controller afterwards, and then allow it to start over with a fresh pairing. Give it a shot and see.
                        @charleszimm Try an older firmware for the controller ? 1.26 or older.
                          @psyke83 Hi didn't forget about this. Got busy doing other things last night. I'll probably be able to give it a shot some time this evening once I get home.
                          @mitu I wouldn't mind trying that but I have a few questions: I was on an older firmware (I think 1.19) when this whole thing started and wasn't able to connect. Now of course I wasn't monitoring bluetoothctl and the associated Bluetooth services, but I'm not sure the firmware is the culprit here.
                          mituM C 2 Replies Last reply Reply Quote 0
                            mitu Global Moderator @charleszimm
                            @charleszimm I mentioned the firmware downgrade because of this topic. There was also a discussion on the LIbretro forums about the 1.29 version changing the button mappings (https://forums.libretro.com/t/8bitdo-sn-30-pro-firmware-1-29-changes/20162).
                              charleszimm @charleszimm
                              @psyke83 bluetoothctl can't connect it either now. Something is either weird with the controller or the entire Bluetooth stack.
                              Failed to connect: org.bluez.Error.Failed
                              I'm debating on reimaging the SD card with the latest image available from the site and before loading any other content or updates to it trying to connect the controller through bluetoothctl.
                              I reboot the Pi and same Connected Yes/No message. I boot it into the Android mode and this happens:
                              [bluetooth]# connect E4:17:D8:49:FD:83
                              Attempting to connect to E4:17:D8:49:FD:83
                              [CHG] Device E4:17:D8:49:FD:83 Connected: yes
                              [CHG] Device E4:17:D8:49:FD:83 Paired: yes
                              [CHG] Device E4:17:D8:49:FD:83 Connected: no
                              I'm at a loss at this point. Do you agree with the reimage idea?
                                @charleszimm
                                I'm 99% certain that a re-image is pointless. Once you "remove" a profile in bluetoothctl, there is nothing left persistent that can realistically screw up future pairings.
                                There's a plausible explanation for what's happening to you:
                                • You were on firmware 1.19, which was working fine.
                                • You updated the script to a version dated somewhere between Feb 3rd-7th, where the Bluetooth script was temporarily broken for some devices (caused by this commit, and then fixed by this commit).
                                • Before the fix was applied on the 7th, you upgraded your firmware to 1.29 as a troubleshooting measure, but the new firmware is defective (or at least requires different steps to pair correctly than before).
                                My advice is to try a firmware downgrade as @mitu suggested, or at least try all other pair modes available besides Switch on your existing firmware.
                                Alternatively, you might be experiencing issues that are related to the differences between jessie and stretch in the kernel and bluez stack. At this stage I'm 99% certain that the Bluetooth script in RetroPie is not the source of your problems.
                                  @psyke83 I agree. I don't think the script is the problem at this point. We had a problem with the script which we've fixed so that's good (I did see some Reddit posts where people were complaining about the Searching... issue).
                                  I originally did the reimage to get to from Jessie to Stretch because I was seeing weird Bluetooth issues after I updated the setup script. I figured that since I was having an issue I might as well do the OS upgrade at the same time.
                                  I think I still might try the reimage over the weekend and see if I can get the controller to successfully stay connected before doing any updates. I keep the game collection backed up to an external that's connected to the Pi anyway so for me to restore after a reimage only takes a few minutes. If that doesn't work...downgrade the firmware on the controller. Plus that'll give me something to do while the dog is napping.
                                  Thanks for all your help everyone. This was a fun few days of troubleshooting! I'll report back if I come into something that suddenly flickers a light bulb in my head.
                                    @charleszimm
                                    If you already have an old jessie image ready to flash (or on a separate card), maybe you could try booting it up, check the existing version of the Bluetooth script from the image as-is, then update the RetroPie script to the latest version and see if it works. That will help you to isolate whether the problem is related to the a) Bluetooth script updates (unlikely, IMHO), b) jessie -> stretch OS component changes (possible), or c) if it's just your new firmware that's not working properly (more likely than the rest).
                                    (Keep in mind that we've dropped official support for jessie - i.e. providing binary updates for packages or testing against that distribution version - so staying on an old image for reasons beyond troubleshooting is not advised).
                                      @psyke83 Well hey while it was fresh I reimaged and...it does the same Connected Yes/No on cda9ffcb from 10 months ago. Next step is to try to downgrade the controller firmware.
                                      I have a second Retropie (livingroomretropie) that is still on Jessie, so the upgrade of the script on that on is a good idea. I have two 8bitdo controllers connected to that one (none of them are the SN30 Pro but still) so we can see what that does as well.
                                      • GeekOBG
                                        GeekOB
                                        I can confirm I'm also having issues with my 8Bitdo NES30 Pro Bluetooth controllers (I have 2). Both controllers are detected properly and input configuration goes well until the right analog stick left and right positions, I'm able to map right to +2 but left will not detect movement at all, same behavior for both controllers.
                                        Editing the mapping files for both retroarch and emulationstation has no effect.
                                        Happy to provide more details if this helps.
                                        Thanks!
                                          mitu Global Moderator @GeekOB
                                          @GeekOB You're having a different problem - this topic is about not being able to pair - via Bluetooth - the controller. You clearly don't have a problem with this part.
                                          You should open a new topic with your problem and add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first to it.
                                          GeekOBG 1 Reply Last reply Reply Quote 0
                                          • GeekOBG
                                            GeekOB @mitu
                                            @mitu Oooops, sorry about that. Will do!
