    Bluetooth no longer working after fresh install
    bluetooth8bitdo sn30 pro
    60 Posts 6 Posters 5.7k Views
      charleszimm @BuZz
      @BuZz Yep updated and the SN30 Pro is on firmware 1.29 which is the latest firmware for it I can see on 8bitdo's site.
        BuZz administrators @charleszimm
        @charleszimm It might be worth trying to register/pair with different power on modes.
        found this post - a little old but may be useful. https://retropie.org.uk/forum/topic/15201/8bitdo-sf30-pro-and-sn30-pro
          charleszimm @BuZz
          @BuZz I gave that a shot prior to trying to reaching out on here, but I just ran a quick test in Windows mode. Similar error in the Setup script:
          "An error occurred connecting to the bluetooth device (Creating device failed: org.bluez.ErrorConnectionAttemptFailed: Page Timeout)"
            psyke83 Global Moderator
            @charleszimm
            I think you're comfortable with using the terminal, so could you try reverting RetroPie-Setup to just before my recent major bluetooth changes and retry the same procedure (remove & register via the script only)?
            You need to test before commit 12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e, so:
            git checkout 12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e^
            To go back:
            git checkout master
            Thanks.
              @charleszimm said in Bluetooth no longer working after fresh install:
              I also did a quick google of the error in conjunction with those controllers, and it does suggest that @buzz is correct that the boot method is related to your issue. See: https://www.reddit.com/r/RetroPie/comments/8pxe5d/help_with_8bitdo_n30_pro_bluetooth_gamepad/
              Please keep us informed as to your results as we need to know if the recent Bluetooth changes need any more fixes.
                charleszimm @psyke83
                @psyke83 I should probably state at this point that I'm a Linux sys admin...but I'm also a Linux sys admin that doesn't do a lot with GitHub. Don't I need a branch or a repo for that command to work? When I run git checkout, I get this:
                pi@theaterretropie:~ $ git checkout 12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e
                fatal: Not a git repository (or any of the parent directories): .git
                Do I need to clone it first?
                Also the boot mode and security type make no difference. I followed the link from Reddit and that just brings its back to the 8bitdo wiki page on the RetroPie GitHub. Those steps were tried (and remember originally didn't work because of the "Searching..." hang).
                  psyke83 Global Moderator @charleszimm
                  @charleszimm
                  No need to clone a new copy - simply make sure that you're in the same directory as the existing RetroPie-Setup script:
                  cd ~/RetroPie-Setup
                  Note that you omitted the caret to signify the commit preceding the commit specified, so make sure to include it (since you want to test the script right before that commit).
                    @psyke83 Sorry for the delay. Here's the response:
                    pi@theaterretropie:~/RetroPie-Setup $ pwd
                    /home/pi/RetroPie-Setup
                    pi@theaterretropie:~/RetroPie-Setup $ git checkout 12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e^
                    error: pathspec '12cb7eb1bc9d810e98adbc8ec7f9a8369ed1f25e^' did not match any file(s) known to git.
                      Huh that's odd. Try to fetch origin before checkout:
                      git fetch origin
                      I just tried a fresh clone of the repo and was able to checkout that commit without any problem (on my Pi and laptop).
                        charleszimm
                        I keep getting flagged as spam but tried the git fetch origin and then the commit point but same message. I recloned the entire RetroPie-Setup from GitHub and tried it again and got the same error.
                          @charleszimm
                          Not sure what's going on there, sorry. Perhaps the caret is causing issues somehow, so it might help to specify another commit that precedes the change. Try:
                          git checkout 2c9fa79a1ae41c2988d21bd179c33ce515e29245
                            @psyke83 said in Bluetooth no longer working after fresh install:
                            Nope.
                            pi@theaterretropie:~/RetroPie-Setup $ git checkout 2c9fa79a1ae41c2988d21bd179c33ce515e29245
                            fatal: reference is not a tree: 2c9fa79a1ae41c2988d21bd179c33ce515e29245
                              Nope.
                              Very odd. Did you clone from a forked repository instead of the official one? What's the output of git remote -v in that folder?
                              P.S. You should encapsulate code via the code tag icon in the editor to avoid the spam filter (and to keep the text tidy).
                                @psyke83 Oh yeah good point. It was more of a laziness thing on my part I won't lie. :-)
                                pi@theaterretropie:~/RetroPie-Setup $ git remote -v
                                origin	https://github.com/RetroPie/RetroPie-Setup.git (fetch)
                                origin	https://github.com/RetroPie/RetroPie-Setup.git (push)
                                  Really bizarre. The only possibility I can think of is that you somehow have a shallow copy of the repository, so it doesn't include the history of commits up to what we need.
                                  Make sure you're on the master branch, then try to force the whole history to be downloaded:
                                  git checkout master
                                  git pull --unshallow
                                  You can see what the oldest commit is via git log --reverse - in my case, it shows the very first commit to the repository from 2012.
                                    Ah yes that makes complete sense! Our instructions will have you clone a shallow copy (--depth=1): https://github.com/RetroPie/RetroPie-Setup/blob/master/README.md
                                    Forcing an unshallow will fix the issue.
                                      @psyke83 Hey that worked!
                                      HEAD is now at 179e2f37... Merge pull request #2591 from cmitu/dolphin-build
                                      When I go into the Setup script, the last commit is now listed as three weeks ago along with the HEAD number. I cleaned out the entire registered Bluetooth device list in bluetoothctl. Let me do some testing and get back to you.
                                        charleszimm @charleszimm
                                        @charleszimm Hung at the Searching... loop. That's what we expected to see, right?
                                          Maybe, yes. To bypass that, make sure to remove any devices that are causing the Connected: yes/no messages to loop in bluetoothctl before selecting the "Register" menu option.
                                          It might be OK to run a bluetoothctl session in a separate shell if you want to monitor what's happening in the Bluetooth stack at the same time as you're running the script.
                                            @psyke83 Okay I lied. It didn't hang but it takes about roughly 2 minutes before it completed searching. I left the Searching... screen up in the SSH session, went to grab a drink, came back, and the results were there.
                                            I was able to connect the controller without problems in Switch mode through the setup script without any problems (which that was always how I had my SN30 Pro setup, even back when I was running Jessie). Restarted the Pi and was able to reconnect the controller without any problems.
                                            So what has changed between the commits?
                                            Bluetooth.service still gives some weird messages that don't leave me warm and fuzzy however.
                                            pi@theaterretropie:~ $ systemctl status bluetooth.service
                                            ā— bluetooth.service - Bluetooth service
                                               Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
                                               Active: active (running) since Wed 2019-02-20 13:20:59 EST; 2min 38s ago
                                                 Docs: man:bluetoothd(8)
                                             Main PID: 515 (bluetoothd)
                                               Status: "Running"
                                               CGroup: /system.slice/bluetooth.service
                                                       └─515 /usr/lib/bluetooth/bluetoothd
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: Starting SDP server
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: Bluetooth management interface 1.14 initialized
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: Failed to obtain handles for "Service Changed" characteristic
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: avrcp-controller: Protocol not supported (93)
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: audio-avrcp-target: Protocol not supported (93)
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: Sap driver initialization failed.
                                            Feb 20 13:20:59 theaterretropie bluetoothd[515]: sap-server: Operation not permitted (1)
                                            Feb 20 13:21:01 theaterretropie bluetoothd[515]: Failed to set privacy: Rejected (0x0b)
