    8Bitdo NES30 Pro Bluetooth controllers not registering right analog left and right positions properly
    bluetoothcontroller8bitdo nes30 pranalogright
    64 Posts 10 Posters 11.7k Views
    • ExarKunIvE
      ExarKunIv
      @BuZz @mitu
      No other thoughts on what's going on.
      With my three controllers and three systems
      Other then I'm SOL. And should stick with 4.4
        mitu Global Moderator @ExarKunIv
        @ExarKunIv said in 8Bitdo NES30 Pro Bluetooth controllers not registering right analog left and right positions properly:
        Not really. But I don't understand why your gamepad doesn't work connected in Switch mode. The manual says that once paired in Switch mode, the controller will automatically pair in that mode by just starting it with the Start button.
          G30FF @ExarKunIv
          @ExarKunIv Yes it was in Android/D-Input mode when I ran my test. I was also on the latest firmware for the N30 Pro 2.
          • ExarKunIvE
            ExarKunIv @mitu
            @mitu for my Pro 2 that will work, but for my older pro, neither will boot in to the switch mode from the start, need to hold down the start and y each time
            and the way im taking the wording they have in the manual
            is that the controller will not have to be paired once it is paired, not that the controller will boot in the paired mode.
            but that is how im reading
            @G30FF and you are running the latest build for retropie, i started to have problems after 4.4.8
            • ExarKunIvE
              ExarKunIv
              Update.
              for me it does not matter what i use. it will just not see the left on the right analog stick.
              i even plugged in my FC30 with usb. after i cleaned out the ES controller list. and it will still not work.
              i tried this on 2 systems and both my NES30 and FC30. both will not work with USB
                G30FF @ExarKunIv
                @ExarKunIv I was on 4.4.9 when I tested it.
                  crono141
                  I ran into this today too with fc30 pro. The stick works fine in retroarch if I manually remap it, but emulation station won't map it.
                    mitu Global Moderator @crono141
                    @crono141 Can you update your Emulationstation package and re-try ?
                    • ExarKunIvE
                      ExarKunIv @mitu
                      i updated it yesterday when i saw buzz was rolling back the SDL2. and it worked yesterday
                      • ExarKunIvE
                        ExarKunIv
                        i updated one of my other systems and its back to not working again.
                        how can i see what SDL2 version is running. i see that where was a new commit a few hours ago
                          @ExarKunIv So probably the issue appeared because of the new SDL version.
                          What is confusing is that you reported this happened when upgrading to 4.4.9 (released 27 days ago), but the SDL switch happened 9 days ago, when 4.4.11 was tagged. Furthermore, the original topic was started on 22 Feb, long before the SDL version was updated.
                          • ExarKunIvE
                            ExarKunIv @mitu
                            @mitu yea, not sure either.
                            • ExarKunIvE
                              ExarKunIv
                              im beginning to question if it worked for me yesterday or not.
                              sadly i lost that card with all the swapping and such. so i dont have the build from last night now.
                              so for now im just going to stick to stock 4.4
                              • ExarKunIvE
                                ExarKunIv
                                @mitu did a clean load, updated everything. and even with what buzz did. the left on the right stick still does not work.
                                but will work once i use anything to back me out of ES.
                                just wanted to let someone know. and yes i have tried 3 different 8bit controllers and 3 different boards. the out come is still the same.
                                i even manually revert the SDL package just for the heck of it. still the same.
                                so ill just stick with 4.4 and just keep testing as new updates come about
                                  joeljoel1947 @ExarKunIv
                                  @ExarKunIv I’m having the same issue here and found this thread by googling. 8bitdo SF30 Pro. Everything will map EXCEPT the right analog stick won’t register left. Very frustrating. Will try some of the recommendations here.
                                  • ExarKunIvE
                                    ExarKunIv @joeljoel1947
                                    @joeljoel1947 hate to say, im glad im not alone.
                                    so far i have not gotten anything to work, so it is something deeper. just the question is what
                                      psyke83 Global Moderator
                                      This is probably the cause of the issue: https://github.com/RetroPie/EmulationStation/commit/b097648dde9ed6c431592f3ca6e7c34e08d7575c
                                      @buzz - The problem could be avoided if the axis adjustment is only done for trigger mapping. Will look at it when I have time, but it might be best just to revert this for now (keeping in mind that reverting breaks mapping for controllers using hid-sony driver).
                                      ExarKunIvE BuZzB 2 Replies Last reply Reply Quote 0
                                      • ExarKunIvE
                                        ExarKunIv @psyke83
                                        @psyke83 how do you revert, if i may ask?
                                        but with my limited knowlage with the coding, it is easy for me not to get things :P
                                        • Z
                                          zeroblu3 @GeekOB
                                          This post is deleted!
                                            BuZz administrators @psyke83
                                            @psyke83 Aah. Forgot about that. My previous test change had similar issues (was much more hacky that yours :-) ). Will revert and rebuild for now - thanks.
