    Controller is only detected if plugged into official pi keyboard and not with micro USB adapter
    troubleshootingusbcontrollerretropiepi0
    8 Posts 3 Posters 580 Views
    • IsabelleXLI
      IsabelleXL
      Pi0 on RetroPie, latest release, fresh install. Plug keyboard into adapter, and controller into keyboard, it works. Plug controller directly into adapter, no go. Would this rule out power supply? Anything I can troubleshoot before looking into different USB adapter?
        mitu Global Moderator @IsabelleXL
        @greengrounds Try looking into the dmesg output after plugging the controller.
        Can you give more details about your system - as requested in https://retropie.org.uk/forum/topic/3/read-this-first ? What controller/adapter are you using ?
        IsabelleXLI 1 Reply Last reply Reply Quote 0
        • IsabelleXLI
          IsabelleXL @mitu
          @mitu I’m using a Sony classic controller from the ps classic
          Edit: I’m using a standard micro USB to USB c adapter that came with the kit, and that’s also what I use to connect the official raspberry keyboard to
            edmaul69 @IsabelleXL
            @greengrounds i think you mean usb a, not usb c. Anywhoo, there is a possibility the adapter isnt making a good connection with the psx controller. I would try a more standard adapter. Also without a hub the pi0’s can be wonky with controllers.
            • IsabelleXLI
              IsabelleXL @edmaul69
              @edmaul69 okay, ya because it works perfectly with the official keyboard as a hub. Any advice on looking for a cheap hub? I want to make this RetroPie for an elderly person and it has to be plug and play, and I can’t lend them my keyboard :p
                @greengrounds you can use one of these. Plug the micro usb into the inside micro usb on the pi. Not the one marked as power.
                https://www.ebay.com/itm/3-in1-Micro-USB-HUB-Male-to-Female-USB-2-0-Charging-Host-OTG-Adapter-Cable-NEW/163305715787?hash=item2605c7784b:g:mMAAAOSwCE5bm1vM
                • IsabelleXLI
                  @edmaul69 thanks
                    @greengrounds but yeah put the power supply into that hub. Then the power supply is giving power to the controller and the pi.
