    lr-atari800, 5200, artifacting, BASIC, and other guidance
    lr-atari800atari5200atari 8-bitatari 800artifacts
    55 Posts 9 Posters 20.6k Views
    • rkosterR
      rkoster @jamrom2
      @jamrom2 OK, ruling out more issues...
      First, let's see if the script is editing the right location. Can you verify this path is where your core options file lives?
      /opt/retropie/configs/all/retroarch-core-options.cfg
      Second, if atari800.cfg is now named lr-atari800.cfg then all the lines like this:
      sed -i 's/DISABLE\_BASIC=.*/DISABLE\_BASIC=0/g' /opt/retropie/configs/atari800/atari800.cfg
      in the script will need changed to have the correct path and name for that file. If the path is the same, that means it'd be
      sed -i 's/DISABLE\_BASIC=.*/DISABLE\_BASIC=0/g' /opt/retropie/configs/atari800/lr-atari800.cfg
      If the file location moved with the updated core, then the whole path would need to change as well as the filename. There's like a dozen places in the script where that update would need to be made to point at the correct location for lr-atari800.cfg.
      Apologies for having you do all this testing and checking, but I'm not able to work on my setup just now -- maybe this weekend. But I am hopeful it's just a path error resulting from the update to the emu core.
      Github/helper scripts * Creativision/Arcadia/Astrocade guide * Amiga guide * Atari 8bit guide
      • jamrom2J
        jamrom2 @rkoster
        @rkoster I'm happy to help.
        My retroarch-core-options.cfg lives in /opt/retropie/configs/atari800/ .
        I don't see it in the location you posted. I will put it there to test. The rest of the locations you mentioned I have already changed hoping that would effect something.
        Let me see if moving that file does anything.
        Sorry... correction from above... yes.. I see the file in the location you posted. I have two now. One in that location, and one in /opt/retropie/configs/atari800.
        rkosterR 1 Reply Last reply Reply Quote 0
        • rkosterR
          rkoster @jamrom2
          @jamrom2 One of those is overriding the other, I bet.
          You could try:
          • deleting the one in /opt/retropie/configs/atari800 (Make a backup copy first of course).
          • editing the script to change all references to /opt/retropie/configs/all/retroarch-core-options.cfg into /opt/retropie/configs/atari800/retroarch-core-options.cfg
          I wonder if an update moved the location of retroarach-core-options.cfg... the docs do not seem to indicate so.
          • jamrom2J
            jamrom2 @rkoster
            @rkoster said in lr-atari800, 5200, artifacting, BASIC, and other guidance:
            Nice work! That did the trick. The location in the script needs to be updated from /opt/retropie/configs/all/retroarch-core-options.cfg to /opt/retropie/configs/atari800/retroarch-core-options.cfg
            I tested a few different games that use BASIC, OSb and all different Artificating. They all worked and it's switching in and out of the artifacting as it should.
            Flight Simulator II #2 Artifacting
            Hellcat Ace - OSb and BASIC
            Micro League Baseball CITA Artifiacting
            Crush, Crumble and Chomp - OSb and BASIC #1 Artifacting
            MULE - nothing
            rkosterR 1 Reply Last reply Reply Quote 1
            • rkosterR
              rkoster @jamrom2
              @jamrom2 I guess the location of retroarch-core-options.cfg must have moved (or exploded into separate files per emu?)
              Hey @mitu, do you happen to know? If I update the script, I want to make sure it's correct.
                mitu Global Moderator @rkoster
                I haven't followed the recent discussion, but yes - by default RetroArch will use a separate options file (.opt) per-core, instead of a single file (/opt/retropie/configs/all/retroarch-core-options.cfg). However, the RetroPie default configuration doesn't enable this option. This doesn't prevent the situation when the user will reset the RetroArch's configuration to default and this option will be automatically enabled.
                On a related note, the next RetroArch version (1.9.1) has a new 'save core options per content folder' option which will make it easier to maintain separate core options for each folder, without extra configurations necessary.
                • rkosterR
                  rkoster @mitu
                  @mitu Ah, OK. I suppose I can modify both locations just in case, or check the option and modify the appropriate location... Blah.
                  Getting to be time to modify the actual core to do what this script does, maybe. :D I've been putting it off... A lot of people use this script now!
                  • rkosterR
                    rkoster @rkoster
                    And it occurs to me that having separate core configs per content folder won't solve the Atari 8 bit problems, because this script modifies both the core options and the core's own config file in order to get to all the settings. hmm.
                    RapidEdwin08R 1 Reply Last reply Reply Quote 0
                    • jamrom2J jamrom2 referenced this topic on
                    • RapidEdwin08R
                      RapidEdwin08 @rkoster
                      @rkoster THANK YOU for your work on this...
                      Are we still following this thread mainly?
                      It's still linked on the RetroPie Docs page, so I suppose so?
                      I'm working on a simple menu driven script that will assist with getting lr-atari800 working for atari5200 Roms-DIR on a clean RetroPie 4.7.1 out-of-box install.
                      So far I included Segmentation fault fix (Disable Menu Widgets in retroarch.cfg), and the Memo Pad fix (5200 settings for retroarch-core-options.cfg).
                      I also wanted to include an Installer for your Awesome runcommand-onstart.sh script, with the fixes mentioned here,in a .diff file if that's OK.
                      Here's a Sample of .diff to confirm the changes are needed/correct:
                      +# [202202] Updated [atari800.cfg] to [lr-atari800.cfg]
                      +# [202202] Updated to include all x3 [retroarch-core-options.cfg] Locations:
                      +# /opt/retropie/configs/all/retroarch-core-options.cfg
                      +# /opt/retropie/configs/atari800/retroarch-core-options.cfg
                      +# /opt/retropie/configs/atari5200/retroarch-core-options.cfg
                      Still some work to do, but Should I post it here? Start a new thread?
                      Raspberry Pi B, Pi B+, Pi2 B, Pi3 B, Pi3 B+, Pi Zero W, Pi4 (4GB/8GB), Pi5 (8GB/16GB), Pi Zero 2 W, GPi V1, minisforum GK50 / RetroPie 4.8.x
                      • rkosterR
                        rkoster @RapidEdwin08
                        @rapidedwin08 As far as a new thread or this one, it's up to @mitu and other mods, I suppose; usually really old threads are preferred to stay dead, but in this case it's certainly true that a lot of folks use this script actively.
                        I don't remember if I have updated the github with that diff; I probably should! But either way, it's fine with me if you create an installer based on this code.
                        At some point, I'd like to get some of this functionality into the core itself and simplify everyone's lives!
                        RapidEdwin08R 1 Reply Last reply Reply Quote 2
                        • RapidEdwin08R
                          @rkoster
                          As mentioned, here's a Menu driven script to assist with lr-atari800 Tweaks:
                          https://github.com/RapidEdwin08/lr-atari800-tweaks
                          Can be ran from retropiemenu (or manually):
                          wget https://raw.githubusercontent.com/RapidEdwin08/lr-atari800-tweaks/main/lr-atari800-tweaks.sh -P ~/RetroPie/retropiemenu
                          • rkosterR
                            @rapidedwin08 Awesome!
                            It occurs to me that since you have the diff done already, if you make a fork of https://github.com/raphkoster/lr-atari800-runcommand-onstart, make the changes, and do a pull request, I can just merge them into the master.
                            • RapidEdwin08R
                              Done..
                              Feel free to double check and let me know if changes/additions/subtractions are needed.
                              • rkosterR
                                @rapidedwin08 Merged, thanks!
                                  cdaters
                                  I just stumbled upon this post...is this about getting 5200(and 800) carts to auto-launch? I am getting ready to build out an 800 and 5200 section on my build. I started with the 5200 and I spent the better part of this afternoon trying to work through the RetroPie documentation of loading carts, extracting, saving, etc. and I only got three to autoload so far...
                                  Though in fairness, it was a busy day for me building JavaScript rules for online ordering templates for some of our customers, lol....among other things...
