    Hatari and Retropie, problems configuring it with F12 (SOLVED)
    hataricontrolsretropiegpi case
    13 Posts 3 Posters 2.0k Views
    • F
      fumanxu
      Since I'm executing retropie through a GPI Case, for me is complicated to use a keyboard. I installed Hatari via retropie, but it seems that it doesn't "inherit" the common controls configuration of retropie like the rest of emulators, so I cannot execute the hotkeys , and the controller buttons are not working for me.
      I read this fantastic tutorial (https://retroresolution.com/2016/04/23/power-without-the-price-atari-st-and-ste-computing-on-the-raspberry-pi-with-retropies-hatari-emulator), but it implies to press F12 to start the "initial" configuration (to map buttons, select TOS and so on), and as commented, I can't.
      My question is, is it possible to map something manually to press f12 via the controller mapped in retropie? or maybe, is possible to configure manually via ssh ?
      Thanks and regards.
        mitu Global Moderator @fumanxu
        @fumanxu Try installing lr-hatari, as a Libretro core it will be auto-configured with the gamepad settings like the rest of the controllers.
        Otherwise, you can try and copy the configuration files from another RetroPie installation to the new RetroPie system (\\retropie\configs\atarist) and maybe modify it accordingly.
        • F
          fumanxu
          Thank you for replying.
          About libreto... How can achieve this? Could you send me a link.
          In the other hand, I copied a config file I've found from internet and I was able to specify a different tos image, but I still have problems with the mapping of the controls. The config file I added has strange coses in the mapping of up/down/left/right that I'm not sure that fit with the codes of my controller
            To install packages (including new emulators) see the Docs. I think lr-hatari is in the experimental section of the packages.
            • F
              fumanxu
              Great
              I was able to install lr-hatari from the package manager. I previously removed hatari and all related config in order to guarantee start from scratch.
              Now my problem is that if I select an atari st disk from emustation, the white modal screen to launch the emulator is displayed but then black screen and returns again to emustation
              I launched the config from the white modal screen and I can select default emulator, video options etc, but no one configuration related to atari
              I also checked the run command.log file but no errors seem to be displayed.
              Am I doing something wrong?
                @fumanxu Doesn't Hatari need some BIOS files to work ? Are you sure your ROMs are ok ?
                • F
                  fumanxu @mitu
                  @mitu no, hatari didn't needed tos since it uses emutos. In any case I replicated hatari.cfg (as commented before pointing to other tos images) and it works
                  Regarding the roms, in principle the st files are ok, they are the same used with hatari previously... And they were executed (without controller support) with the previous hatari
                    @fumanxu Ok, add more info about your system (see https://retropie.org.uk/forum/topic/3/read-this-first) and also post the log file of the emulator - /dev/shm/runcommand.log.
                    • F
                      fumanxu
                      Ok, Thank you again for all this valuable support.
                      Pi Model or other hardware:Pi Zero W
                      Power Supply used: GPI case batteries
                      RetroPie Version Used : 4.4
                      USB Devices connected: no
                      Controller used: gpi case controller built in
                      Error messages received:
                      In principle, no error messages received.
                      Parameters:
                      Executing: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --conf$
                      [libretro-test]: Got size: 640 x 480.
                      Retro SYSTEM_DIRECTORY /home/pi/RetroPie/BIOS
                      Retro SAVE_DIRECTORY /home/pi/RetroPie/roms/atarist/
                      Retro CONTENT_DIRECTORY /home/pi/.config/retroarch/downloads
                      Retro DeInit
                      I installed lr-hatari from package manager as commented in previous posts of this thread.
                      Not applicable
                      lr-hatari
                      Not sure which file is needed... there are a lot in retropie.
                      How to replicate the problem:
                      • Install lr-hatari
                      • Copied st files to /home/pi/RetroPie/roms/atarist, in principle they are working since they were tested with hatari (no libreto emulator). The problem with hatari is that the controller is not recognised and I can't access to setup via F12 to configure it in GPI Case.
                      • emustation recognizes the st files as ATARI and when I select one of the files the modal white screen to configure the atari emulator launcher is displayed.
                      • I push button to configure and lr-hatari is selected as default emulator.
                      • If I launch emulator, black screen and returned to emustation.
                        @fumanxu said in Hatari and Retropie, problems configuring it with F12:
                        This is changed from the default - did you use 'Save Configuration' in RetroArch or used 'Save Configuration on Exit' ? What's the name of the ROM you're trying to run ?
                          You actually need the BIOS files - at least tos.img to use lr-hatari, so make sure you have the file.
                          • F
                            fumanxu
                            Yes, that was the real problem. Since there is not any error, I didn't see which was the proble,
                            I read at https://github.com/libretro/hatari that : "To use this core you need a valid TOS ROM image named 'tos.img' in your RetroArch system directory."
                            So I put it in the system folder that /dev/shm/runcommand.log says :
                            Now It is working, with controller support and even virtual keyboard displayed when click on Y button.
                            I have another problem with the performance, but I think it should be placed in another thread.
                            Thanks a lot for the support.
                            • rkosterR
                              rkoster
                              I saw this thread, so I set up lr-hatari, got it working, and updated the docs, mostly just from the core's github readme. It worked pretty much first try, but the docs previously only covered Hatari standalone.
                              One thing I am not clear on is how you get the core to look at different BIOS files in order to emulate the STE or Falcon, but I haven't tried that yet.
                              Github/helper scripts * Creativision/Arcadia/Astrocade guide * Amiga guide * Atari 8bit guide
