    Custom Build Atari themed cabinet
    arcaderetro piediycabinet buildcabinet
    31 Posts 7 Posters 6.6k Views
    • karmathingK
      karmathing @backstander
      @backstander Thanks! You're right - I'll try it out before altering.
      • karmathingK
        karmathing @Clyde
        @Clyde Marquee... don't know. probably follow the overall design and give it a name. Ataricade? Atarcade? But it may mean more custom printing which is beyond my wallet at the moment. Balloon was after my youngest's party! I do love a balloon, and so does he.
        • karmathingK
          karmathing @chubsta
          @chubsta For the sake of authenticity you're right - and I tried REALLY hard to make it look like it rolled out of a factory. Unfortunately the 16:9 monitor was a freebie so It'll stay for a while. Would be simple to change internally, but it'll have to wait.
            allahandro @karmathing
            @karmathing If it's the right height for you, the screen should be fine. but aesthetically it does look too high. I would try to bring it down a few inches, maybe 3 or 4 at the most. But if it's too hard, it's your arcade! It looks really good right now!
            • W
              wstanek
              @karmathing Really looks great! Very well done, love the graphics. How does it play? A tip for single player setup: when using the left side stick, map the buttons on the right side as well so you can stand centered up on the cab in a proper horse stance.
              Ideas since you asked:
              I think your screen is ok. With a black bezel, you wont notice the vertical position as much. Consider black (maybe with your graphics in a subtle way and instructions.) I would not drop it down if it interferes with your comfort. If you do drop it down an inch or two, you might also want to angle it back a bit.
              Looks really good! Now build another one with a vertical monitor and a 4 way stick.
              ws
              Latest Build: https://retropie.org.uk/forum/topic/23649/mad-planets-cabinet-build-finished?_=1578928113680
                Clyde @karmathing
                @karmathing On the second thought, you could mount the monitor in a vertical position. It won't look as „too anything“ (e.g. too high) like that and you could play vertical games with a bigger picture. Just an idea …
                • W
                  wstanek
                  Here:
                  ClydeC 1 Reply Last reply Reply Quote 3
                  • W
                    wstanek @Clyde
                    @Clyde You're right on, vertical fits the space very well. You'd have to have a 4 way stick. He's just gonna have to build another one!!
                    ws
                    ClydeC 2 Replies Last reply Reply Quote 0
                      Clyde @wstanek
                      @wstanek … or that. 😉
                        Clyde @wstanek
                        @wstanek … or two. 😄
                          Clyde @wstanek
                          @wstanek Not every vertical game is 4-way, though. Many arcade SHMUPs are vertical and 8-way. But with either the xboxdrv (item 2D) or switchable Joysticks like the Ultimarc Mag-Stik Plus (I have two of them built into my upright cabinet, see my review here), that wouldn't be an issue.
