    Retropie amiberry image sound and control issues
    retropie amigaamigaamiberryretropieno sound
    12 Posts 4 Posters 1.5k Views
      trippy86
      Hi
      I downloaded an image already setup and all wotking nicely, but i have come across two problems
      1. New WHDload games i have added run but no with sound, im using files from Retroplay's WHD
        http://eab.abime.net/showthread.php?t=61028
      All the games that were already on the image work fine, sound is perfect
      1. I cant get any of my wireless logitech, microsoft or asus mice to work at all, my wireless cheap Xenta keyboard works fine.
      If anyone knows of a decent keyboard or mouse or combo unit good for amiga or retro gaming please let me know.
      All files are on the SD card, no usb device is used for storage
      If anyone has any ideas into either of these i would be so grateful for the help
      Trippy
        BuZz administrators @trippy86
        @trippy86 Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
        we don't support 3rd party images - download our official release and if you run into issues we can advise.
          trippy86
          My Apologies. Just to clarify its not an image from a random website it was actually a copy of an image from someone I know, it was made sometime ago so it required updating which I've done
          He has told me it was an official image download from the main page and he built it from that
          I've already asked him but hes not been using the software for a long time and doesn't know what the issue is
          I hope this is acceptable ?
            mitu Global Moderator @trippy86
            @trippy86 said in Retropie amiberry image sound and control issues:
            Not really, since we can't know what configurations or customizations have been made to the image. Starting with a new image would make it easier to diagnose the eventual issues you may encounter as @buzz said.
              trippy86 @mitu
              @mitu fair enough I understand, unfortunately I've already put a lot of time and extra customizations into this existing Image so I cant bare to start from scratch.
              Thanks for the replies anyway
              Trippy
                trippy86
                Just incase anyone has this same problem I resolved it by changing the audio to force HDMI. Can be done via retropie - emulationstation in raspi-config or edit /boot/config.txt
                  trippy86
                  One last thing, do wireless mice work on amiberry in retropie as I cant get them to work.......tried both a cheap one and my logitech m515
                  Thx
                  • Thorr69T
                    Thorr69
                    It shouldn't matter if they are wired or wireless. The issue you have to deal with is more likely that the WHLoad setups you are using are configured for controller use and not for keyboard/mouse use.
                    RPi 3b
                    Official PSU
                    Official RetroPie image
                    Pandora's Box 5 controller
                      trippy86 @Thorr69
                      @Thorr69 even on mouse based games? I've tried a number of games that a purely point and click games which require a mouse. Can see the mouse pointer but no movement
                      • Thorr69T
                        Thorr69 @trippy86
                        @trippy86 Try moving your joystick and see if the mouse pointer moves. If it does then it's set to use the controller instead of the mouse.
                        RPi 3b
                        Official PSU
                          trippy86 @Thorr69
                          @Thorr69 no movement on that either. If I go into amiberry settings it shows mouse as port 0 and joystick as port 1
                          • Thorr69T
                            Thorr69
                            Some mouse-only games are still setup to use just controllers and not the attached mouse/keyboard when you use the WHDLoad version. Populous, for example. I don't know what i need to do to unset that, so I can't make any suggestion for you on this either (if it's the case).
                            My only other suggestion would be to disconnect your controllers before firing up an amiga game and/or switch USB ports so that your mouse and keyboard are on the lower port numbers (0 and 1).
                            RPi 3b
                            Official PSU
