    Reduce controller sensitivity
    n64controllersensitivity
    5 Posts 3 Posters 5.9k Views
    • langestL
      langest
      Is it possible to reduce the sensitivity of the joystick on a controller for N64 emulators?
      I don't want to extend the dead zone but rather be able to just turn just a little in Diddy Kong Racing and F-Zero.
        You can try re-mapping your gamepad through xboxdrv, which has a sensitivity adjustment for the joystick axis.
        • langestL
          langest
          I think I found the solution here: N64 Controller Analogue Stick issues
          I will test later.
            barbudreadmon @mitu
            @mitu on a sidenote, retroarch now has a setting for this, since 1.7.8 iirc
            • langestL
              langest
              Turns out that the dead zone was set too high.
              When the joystick finally tilted out of the dead zone it had gone too far for the smaller motions. I set it to almost nothing in comparison to what it was and now everything is nicer to play.
