    Updated, now Start and Select won’t work
    4.5.3controllerstartselect
    9 Posts 3 Posters 3.2k Views
      Arcuza
      Did an update from 4.3 to 4.5.3 on Raspberry PI 3B+ and now Start and Select won’t work, neither in Emulation Station or in game.
      Since remapping controllers seems to only be accessible through Emulation Station Options/Start-menu, I’m not able to remap the controller either.
      Can you please help me by describing how I can delete the current controller entry (I have a keyboard, so I can access and edit config) so I can reboot and remap the controller?
      Thank you so much for your support!
      • hooperreH
        hooperre
        You can use the Enter key to access the menu of EmulationStation and use the keys to navigate to remap the controller. I believe Z functions as the A button and X functions as the b button by default.
        If you want to delete the entry, exit EmulationStation or SSH into the Raspberry Pi and enter the following command in the command console:
        cd /opt/retropie/configs/all/retroarch-joypads/
        Then press Tab twice and the command console should bring up all the files related to joypads. Find your file.
        rm [begin typing file name] The tab key is your friend here and can help to auto enter your file. Enter will delete the file.
        4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
        • quicksilverQ
          quicksilver @Arcuza
          @Arcuza reboot with controller unplugged, it will prompt you to map a controller upon rebooting. Should be able to plug in your controller then, press and hold any button and then remap as needed.
          A 2 Replies Last reply Reply Quote 0
            Arcuza @quicksilver
            @quicksilver Thank you very much. Will try. If this works, this is exactly what I’m looking for.
              Arcuza @quicksilver
              @quicksilver Sorry, didn’t work. As soon as I plugged the controller in it was automatically detected and I didn’t got a chance to remap.
              • quicksilverQ
                quicksilver @Arcuza
                @Arcuza sorry, I was mistaken do this instead:
                From the main menu, go into Retropie settings, Retropie Setup, Configuration / tools, emulation station, and then select option 1 "Clear/Reset Emulation Station Input Configuration".
                Once you do this your controller may stop working. You might need to plug in a keyboard if you cant reboot the system with your controller. Hit f4 to bring up a terminal, then type the following to reboot the pi (make sure you have your controller plugged in):
                sudo shutdown -r now
                Once the system comes back up you will be prompted to remap your controller, after which it should start working.
                  Arcuza @quicksilver
                  @quicksilver Thank you!!! Works even better. After deleting settings, controller was working inside retropie settings terminal interface, so I was able to reboot and configure input at startup.
                  One thing though. Now my controller, a Speedlink Torid, is recognized as Xbox 360 controller rather than Speedlink Torid like on 4.3.
                  Have there been any changes to default controller driver? Which one is preferred now, xboxdrv or xpad or?
                  Thank you very much for all your support!
                  • quicksilverQ
                    quicksilver @Arcuza
                    @Arcuza xpad driver is default for many controllers. Do not use xboxdriver unless you need it to configure non-libretro emulators (most people probably do not need it). If you controller is behaving correctly now I wouldn't worry how emulation station recognizes it.
                      Arcuza @quicksilver
                      @quicksilver Thank you very much and have a great weekend.
