    Disappearing sprites (possible frameskip issue)
    issueframeskipgraphical issuesnes9xraspberry pi 4
    21 Posts 5 Posters 5.7k Views
      blackster
      I had the same issue. The problem is that RetroPie manage default resolution very bad.
      To solve this and other performance issues just play with the resolution and set the best that fits your needs.
      You have to enter the raspbi-config -> display options.
      If the system crashes when you select display options, use this trick:
      Enter the menu and before opening display options disconnect the HDMI.
      Than open display options (with screen off) and connect HDMI again.
      It should solve the problem.
      After I changed resolution I experienced a big performance jump!
      And all that glitches and sprite problems was solved
