    Horizontal retropie display. HELP
    helphorizontalxrandrplease helpdont work
    42 Posts 2 Posters 6.7k Views
      mitu Global Moderator @A Former User
      @xTekFede In this case, you should look in the Settings -> Video -> Scaling and see if changing the parameters there makes a difference.
        A Former User @mitu
        @mitu Thank you thank you, I was going crazy, in the end I had to put the scaling to 1 and put
        aspect_ratio_index = "1"
        Thank you very much, From the heart, I LOVE YOU , Thank you very much
        Just one thing, I put in the cmdline.txt
        video = HDMI-A-1: 480x800M @ 60rotate = 90
        with the various settings but it doesn't work
          @xTekFede said in Horizontal retropie display. HELP:
          You shouldn't have any spaces in the boot parameter
          video=HDMI-A-1:480x800M@60rotate=90
            A Former User @mitu
            @mitu There are no spaces, sorry I was wrong to copy
              Try this:
              video=HDMI-A-1:480x800M@60,rotate=90
                A Former User @mitu
                @mitu If I put the comma remains vertical, but for a second in the initial load it turns and then returns vertically
                  A Former User
                  It works but not in the boot, it does nothing THANK YOU SO MUCH
                    A Former User
                    Wait I just noticed one thing, that setting 16:9 works the games at 16:9 but not the ones at 4:3 how do I do? I would like to change to individual emulators can you?
                      Try turning off 'Integer Scaling' and remove the 'scale factor' so RetroArch scales it to the window height/width.
                      ? 3 Replies Last reply Reply Quote 0
                        A Former User @mitu
                        This post is deleted!
                          A Former User @mitu
                          @mitu without Integer Scaling it returns crushed
                            A Former User @mitu
                            @mitu I noticed that if I activate Integer Scaling the psp works normally, but the retroarch settings don't work anymore, and if I deactivate Integer Scaling, the settings go but the games are crushed
                              A Former User
                              ah no retroarch does not start even if you deactivate it now
                                A Former User
                                Sorry again, now retroarch doesn't start anymore, not even the configuration, and the only emulator that goes is lr-ppsspp
                                  I suggest you start with the default RetroArch configuration, then add just the video rotation parameter and see how each core behaves. By default, RetroArch should use the whole screen if no scaling is applied to the videoport.
                                    A Former User
                                    Integer Scaling
                                    I just tried it, it doesn't work, the retroarch configuration doesn't start in the retropie settings, now I send you the retroarch.cfg file if it's okay with you:
                                    https://drive.google.com/open?id=1CNJ7506IEPJpXZbgE8DmkfC0MHmjgn5k
                                      A Former User
                                      I thought it was
                                      video_drivers  =  "xvideo"
                                      what driver should i use
                                        A Former User @A Former User
                                        I tried putting gl and it works now
                                        which one do you recommend to use
                                          A Former User
                                          Only the configuration section of retroarch and lr-ppsspp works, the other emulators don't even start
                                            I recommend you start with the default RetroArch configuration, as I said before. The default video driver in RetroPie is the gl driver.
