    Razer Atrox Arcade Stick Help
    controllerarcade stickdriversretro piexbox one
    3 Posts 2 Posters 587 Views
      Sircoynie
      Hi,
      Apologies for being new but I was wondering if anyone has had any experience with getting the Razer Atrox XboxOne controller to work with Retropi? I have seen a thread about this on here gut it gives no explanation on how it was solved and is very old.
      Note: xInput driver install has not resolved my issue, LT and RT are still not mapping?
      Many thanks for the help.
        @Sircoynie said in Razer Atrox Arcade Stick Help:
        I think the solution was to mod the stick with an IPAC usb encoder.
        So i bought some electronic switches and a custom usb keyboard encoder (ipac2), installed it in my atrox and ended up with a fully working xbox one and raspberry pi machine.
        Can you try to test the controller with jstest, from the command line and see if the inputs are registered ? Exit EmulationStation and run from the terminal
        jstest /dev/input/js0
        You can exit the test by pressing Ctrl+C.
          Sircoynie @mitu
          @mitu said in Razer Atrox Arcade Stick Help:
          I will give that a try and get back to you thanks.
