    Setting up Half-Life through RetroPie (A Guide)
    half-lifexash3d
    147 Posts 30 Posters 65.3k Views
      Johan_Liebert511 @quicksilver
      @quicksilver I'm here again. I finally learned some Linux and managed to set half life up. I wanted to play on Gamepad but as soon as I try to bind a button, for example jump, it crashes. I played a bit and it looks like I can only move the joysticks. I did step 3 but am using the old xash3d version since the mega file doesnt show up and I dont know how to compile. Can you upload the mega file again or help me in other ways?
      Thanks for your Work
      quicksilverQ A 2 Replies Last reply Reply Quote 1
      • quicksilverQ
        quicksilver @Johan_Liebert511
        @johan_liebert511 I'll see if I can reupload it for you
        • RubicaiR
          Rubicai
          It works great thank you! But I can't download the newer version of xash3d, it seems the folder is empty. Could it be reuploaded?
            amp12f @Johan_Liebert511
            @quicksilver Awesome tutorial. Looking forward to playing. I seem to be having the same issue that @Johan_Liebert511 mentioned. I’ve already got the libraries compiled, joypad flag added to the script, and the game starts up just fine. It’s just when I try and do any sort of key mapping of either the keyboard or the gamepad from the menu that the game crashes back to the RetroPie homescreen. Here’s a dump of runcommand.log. Seems to complain at the very end about a segmentation fault once I try changing any sort of control mapping
            Running on a Raspberry Pi 4
            pi@retropie:~ $ cat /dev/shm/runcommand.log
            Parameters:
            Executing: SDL_VIDEO_KMSDRM_CRTCID=87 SDL_VIDEO_KMSDRM_MODEID=29 /opt/retropie/ports/xash3d/Xash3D.sh
            [14:24:55] /home/pi/RetroPie/roms/ports/Half-Life is working directory now
                    Xash3D FWGS (build 2316, Linux-arm) started at Aug03 2021 [14:24.55]
            [14:24:55] Joystick: SDL
            [14:24:55] 1 joysticks found:
            [14:24:55] 0    : Pro Controller
            [14:24:55] Pass +set joy_index N to command line, where N is number, to select active joystick
            [14:24:55] Selected joystick: Pro Controller
                    Axes: 4
                    Hats: 1
                    Buttons: 16
                    Balls: 0
            [14:24:55] Cannot load xashcomm.lst
            [14:24:56] bpp 32
            [14:24:56] R_ChangeDisplaySettings: Setting video mode to 1280x720 windowed
            [14:24:56] Video: V3D 4.2
            [14:24:56] AVI: Not supported
            [14:24:56] vgui_support: not found
            [14:24:56] Loading new-style background from game succeded
            [14:24:56] fontconfig: Trebuchet MS -> /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
            [14:24:56] Uploaded Trebuchet MS_24_500_font.bmp to 149
            [14:24:56] Rendering Trebuchet MS(24, 500) took 0.034199 seconds
            [14:24:56] Uploaded Trebuchet MS_18_500_font.bmp to 150
            [14:24:56] Rendering Trebuchet MS(18, 500) took 0.015570 seconds
            [14:24:56] Uploaded Trebuchet MS_37_500_font.bmp to 151
            [14:24:56] Rendering Trebuchet MS(37, 500) took 0.036755 seconds
            [14:24:56] fontconfig: Trebuchet MS -> /usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf
            [14:24:56] Uploaded Trebuchet MS_24_1000_font.bmp to 152
            [14:24:56] Rendering Trebuchet MS(24, 1000) took 0.022665 seconds
            [14:24:56] fontconfig: Tahoma -> /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
            [14:24:56] Uploaded Tahoma_16_500_o1_font.bmp to 153
            [14:24:56] Rendering Tahoma(16, 500) took 0.035306 seconds
            [14:24:56] Using SDL audio driver: alsa @ 44100 Hz
            [14:24:56] Reading config script file settings.scr
            [14:24:56] Reading config script file user.scr
            [14:24:56] execing config.cfg
            [14:24:56] execing valve.rc
            [14:24:56] execing language.cfg
            [14:24:56] execing autoexec.cfg
            [14:24:56] execing violence.cfg
            [14:24:56] Couldn't open file resource/mainui_english.txt. Some strings will not be localized!.
            [14:24:56] Localize_AddToDict: loaded 241 words from resource/gameui_english.txt
            [14:24:56] Localize_AddToDict: loaded 190 words from resource/valve_english.txt
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] -1 -1
            [14:25:08] opt/retropie/ports/xash3d/Xash3D.sh: line 1:  2695 Segmentation fault      LD_LIBRARY_PATH=/home/pi/RetroPie/roms/ports/Half-Life /home/pi/RetroPie/roms/ports/Half-Life/xash3d -console -clientlib cl_dlls/client.so -dll dlls/hl.so -sdl_joy_old_api
            • quicksilverQ
              quicksilver @amp12f
              @amp12f @Rubicai @Johan_Liebert511 I have reuploaded (I think) the updated binary. Please let me know if it works.
              RubicaiR ExarKunIvE 2 Replies Last reply Reply Quote 0
              • RubicaiR
                Rubicai @quicksilver
                @quicksilver I've just installed it and it's working fine, I still can't get to map the controls from the game since it crashes and for some reason the triggers (I'm using a DualShock 4 to play) seem to do the same, but it's no issue for me and it happened before, but thanks so much, this is a great guide!
                • ExarKunIvE
                  ExarKunIv @quicksilver
                  @quicksilver is your binary any different then what zerojay already has in his collection for RetroPie-Extra. since in see in his script that it is installing from github.com/FWGS/xash3d-fwgs
                  just wondering
                  • quicksilverQ
                    quicksilver @ExarKunIv
                    @exarkuniv they're coming from the same source then. In fact zerojays is going to be more up to date than mine. At the time I created this post I don't believe zerojay had a script for half-life. His is probably the better way to go at this point though I haven't looked at it closely.
                    ExarKunIvE L 2 Replies Last reply Reply Quote 1
                    • ExarKunIvE
                      @quicksilver cool, just trying to help so not to make for work for people where its not needed
                      • L
                        luckyluca @quicksilver
                        @quicksilver
                        Thanks for this guide.
                        I got it working, except it crashes to desktop everytime I try to assign a button in-game.
                        Has this been resolved?
                        I tried both compile from source in Retropie-Source, run from Binary, and your own Binary.
                        Also, would you kindly share your config.txt, I'm especially after mapping a menu button, as currently it is not possible to open the menu button with the 8bitdo joypad alone.
                        Many thanks!
                        EDIT:
                        I switched to xash3d-fwgs and everything works now
                          richradd
                          Are you the same QuickSilver from 15+ years ago
                          QuickSilver extreme?
                          http://qsextreme.com/
                          • quicksilverQ
                            quicksilver @richradd
                            @richradd no that's not me
                            • E
                              eputley @quicksilver
                              @quicksilver Does this still work? Im not seeing xash3d come up in my packages after i put "wget --no-check-certificate https://github.com/sergiopoverony/xash3d/raw/master/xash3d.sh
                              " into my terminal.
                              mituM ExarKunIvE 2 Replies Last reply Reply Quote 0
                                mitu Global Moderator @eputley
                                @eputley The downloaded file needs to be placed in a certain folder, it won't work if you just download it somewhere. Run:
                                cd $HOME/RetroPie-Setup/scriptmodules/ports
                                wget https://github.com/sergiopoverony/xash3d/raw/master/xash3d.sh
                                then run again RetroPie-Setup.
                                • ExarKunIvE
                                  ExarKunIv @eputley
                                  @eputley there is a updated script in the main repo for Retropie-Extra
                                  https://github.com/Exarkuniv/RetroPie-Extra
                                  • E
                                    eputley @ExarKunIv
                                    @ExarKunIv Which folder is the code in? Im really not familar with these things.
                                    • E
                                      eputley @ExarKunIv
                                      @ExarKunIv Okay I downloaded it from the retropie experimental section, can I follow the instructions of this original post now? Or has anything else changed? Thanks for the help btw
                                      • ExarKunIvE
                                        ExarKunIv @eputley
                                        @eputley the script is in the experimental section
                                        And you just need to add your game files.
                                        But this post will help with that
                                        • E
                                          eputley @ExarKunIv
                                          @ExarKunIv So I tried add my game files but unlike others in this thread I dont have a folder for Half life in my roms/ports/folderscreenshot.PNG
                                          • E
                                            eputley @eputley
                                            @eputley So im not sure where to put my valve folder I tried putting it in the ports section but it wouldnt launch the game then I tried putting it in xash3d folder that didnt work either
