    Setting up Half-Life through RetroPie (A Guide)
    half-lifexash3d
    147 Posts 30 Posters 64.7k Views
    • ExarKunIvE
      ExarKunIv @eputley
      @eputley is there a valve folder within xash3d-fwgs?
      If so put it in there
      E 2 Replies Last reply Reply Quote 0
      • E
        eputley @ExarKunIv
        @ExarKunIv Yes there is but it dowsnt contain all the files in my valve folder from steam, so I tried replacing it with my valve folder but it still wont launch
        • E
          eputley @eputley
          • E
            eputley @ExarKunIv
            @ExarKunIv And I did put my valve folder into the xash3d valve folder as well, maybe i need to remove everything and try again?
            ExarKunIvE 2 Replies Last reply Reply Quote 0
            • ExarKunIvE
              ExarKunIv @eputley
              @eputley I believe you just need to put the contents of your valve folder into the valve folder in the xashd3-fwgs folder.
              Sorry I'm at close to my pi right now
              I know this is in the help part of the script
              rp_module_help="Please add your full version Half-Life data files (folders /valve, /bshift and /gearbox) to $romdir/ports/xash3d-fwgs/ to play."
              So tell me.
              Are there other folders in side of the dashed folder.
              There should be a gearbox, bshift and valve folder in there
              • ExarKunIvE
                ExarKunIv @eputley
                @eputley everything that you showed me in the picture a few posts above need to stay in there that is what is needed to run the game on a pie
                So if you did delete it no big deal just rerun the script
                Then add the contents of your veil folder into that valve folder
                So all your files other folders etc are going to be next to those files that you have in that picture
                • E
                  eputley @ExarKunIv
                  @ExarKunIv Yes inside of the "xash3d-fwgs" folder there is a folder for bshift, gerbox, and valve, inside the valve folder I add my personal valve folder from steam, but the other folder for bshift and gearbox I havent put anything in, do I need to add the valve folder to those as well? or are they separate things
                  • ExarKunIvE
                    ExarKunIv @eputley
                    @eputley those other folders are going to be for the other two games opposing force and blue shift
                    All you need to do is pull everything out of the valve folder that you put in there and put it into the main valve folder that was made by the script
                    • ExarKunIvE
                      ExarKunIv @eputley
                      @eputley when I can, if I can. I'm on vacation right now. I will post what my folder looks like on my system
                      • E
                        eputley @quicksilver
                        @quicksilver Oh okay I was thinking about doing that but I noticed some of the contents in the script made valve folder already have things that are in my steam valve folder, So should i just move eveything in my valve folder in anyway?
                        Here is my steam valve folder as compared to the other valve folder image I sent earliervalve2.PNG
                        ExarKunIvE E 2 Replies Last reply Reply Quote 0
                        • ExarKunIvE
                          ExarKunIv @eputley
                          @eputley Yes you want to move everything over but not overwrite anything that will pop up saying there is a duplicate file
                          Like I said you need to keep the files at the script made because they are different core files that are built to run on a pie if you replace them it won't work because those are built to run on a computer
                          • E
                            eputley @ExarKunIv
                            @ExarKunIv Oh my god it worked! thank you this has been driving me mad. Now I just need to figure out how to configure the controlls to my game pad lol
                            ExarKunIvE 1 Reply Last reply Reply Quote 1
                            • ExarKunIvE
                              ExarKunIv @eputley
                              @eputley I'm glad to help with that.
                              For the controller I just used a custom xboxdrv to mimic a keyboard.
                              I could never get my 8bitdo controller to work right with it. And I'm more familiar with making xboxdrv mappings
                              • E
                                eputley @eputley
                                @eputley well thanks again and enjoy your vacation!
                                • E
                                  eputley
                                  @quicksilver If anybody knows how to set up a gamepad controller with the new version of xash3d please let me know what to do
                                  • E
                                    eputley @ExarKunIv
                                    @ExarKunIv so does the step:3 here not apply with the new xash3d-fwgs? I just dont get where youre supposed to add that "-sdl_joy_old_api" line. or if you even still do that.
                                    • ExarKunIvE
                                      ExarKunIv @eputley
                                      @eputley I don't know. I might of tryed that back then. But since I use a different way I don't bother anymore
                                      The method above is for a old script which is why it might not work anymore
                                      • E
                                        @quicksilver Yeah from what ive been seeing from other people is that when they updated xash3d it they were having no problems using their controllers but for me when I boot up half life it only recognized my mouse and keyboard I have no input on my controller
                                          plimbs
                                          Setting up a new Pi 4. I can no longer build Xash3D from source, per the instructions. (I have forgotten whether I was able to the first time I did this on a 4.) I installed from binary instead. Then I used @quicksilver's xash3d-fwgs replacement file. It seems to run.
                                          The message I got was that libmenu.so could not be found.
                                          Maybe this is a new issue with the most recent changes in the repo? I'm not sure.
                                          • ExarKunIvE
                                            ExarKunIv @plimbs
                                            @plimbs
                                            https://github.com/Exarkuniv/RetroPie-Extra
                                            Has a new updated install script, I believe to fix that issue
                                            P R 2 Replies Last reply Reply Quote 0
