    Setting up Half-Life through RetroPie (A Guide)
    half-lifexash3d
    147 Posts 30 Posters 65.7k Views
      plimbs
      @ExarKunIv failing to build Half-Life again. Git location "DEPRECATED in favor of https://github.com/FWGS/xash3d-fwgs."
      • ExarKunIvE
        ExarKunIv @plimbs
        @plimbs cant confirm.
        i just pulled my script from my github and built it just fine,
        give it a try again and if it is still not working, i would recommend removing that script and redownloading it from the github
          plimbs @ExarKunIv
          @ExarKunIv I apologize. I'm stupid. I didn't hunt down every last trace of the original scripts, and there was still a piece out there running instead of yours.
            A Former User
            This post is deleted!
            • L
              LowpolyBros.
              Game crashes when i try to change bindings, any fixes? I have the newer version of xash3d installed
              • N
                Nash @LowpolyBros.
                @LowpolyBros Still crashing in 2025. You can edit keyboard.cfg in valve folder to bind keys.
                If you want to bind gamepad, you must find two files "gamepad.cfg" and "userconfig.cfg" to put in valve folder, and edit gamepad.cfg.
                • N
                  Nash
                  Opposing Force start but I'am alone in the training boot camp. Seems like some scripts are broken, the ship that should crash during intro doesn't crash and fly to infinty and beyond.
                  Is this a new bug, or is it a known issue that has existed since the beginning ? Can it be fixed ?
                  It was a pain to start Blue Shift with unlocked maps. The linked patch doesn't exist anymore, and others doesn't work. The only solution is to find pre-patched maps pack.
                  With this Blue Shift can start :
                  https://www.moddb.com/games/half-life-blue-shift/downloads/blue-shift-unlocked-game-dlls-and-patched-maps
