    Setting up Half-Life through RetroPie (A Guide)
    half-lifexash3d
    147 Posts 30 Posters 64.7k Views
      Codafire @quicksilver
      @quicksilver can you send me a link? Thanks!!!
      • quicksilverQ
        quicksilver @Codafire
        @codafire said in Setting up Half-Life through RetroPie (A Guide):
        https://mega.nz/folder/xBpAgYYb#arEdY1Y2DVere_gGRqeFjw
          Johan_Liebert511
          I always get the message "permission denied" when I want to place the "valve" folder inside
          • quicksilverQ
            quicksilver @Johan_Liebert511
            @johan_liebert511 said in Setting up Half-Life through RetroPie (A Guide):
            Sounds like a permissions or ownership issue. Check to make sure the half-life folder is owned by user pi and has proper permissions.
              Johan_Liebert511 @quicksilver
              @quicksilver
              If you mean I didnt log in properly, I did it as pi user. But the files say in properties that they are from "root [0]". I also cant change them because of "permission denied"
                Rafael
                Hi,
                I'm having difficulty in step 3:
                1. If you wish to use a controller to play this game edit the file /opt/retropie/ports/xash3d/Xash3D.sh and add -sdl_joy_old_api to the end of the line. You can also remove -console from that line if you don't want the constant console messages on screen.
                I can't find ports/xash3d, I only see ports/Half-Life. For some reason Xash3D.sh is inside ports.
                I tried to edit Xash3D.sh by adding -sdl_joy_old_api. It looked like this:
                #!/bin/bash
                "/opt/retropie/supplementary/runcommand/runcommand.sh" 0 PORT "Xash3D" "" -sdl_joy_old_api
                But it did not work, the control still does not respond.
                Sorry for bad English, I'm using google translator =)
                • quicksilverQ
                  quicksilver @Rafael
                  @rafael you're editing the wrong file. Make sure you're not editing the .sh file in the roms directory.
                  R J 2 Replies Last reply Reply Quote 0
                    Rafael @quicksilver
                    @quicksilver thanks so much, I was looking in the wrong directory. It's working fine now.
                      @quicksilver I managed to run the game but the first 3 options of the game (New Game, Hazard Course and Load Game) can`t be used. I cant start a new game.
                      • quicksilverQ
                        @johan_liebert511 make sure you are using the steam version of the game otherwise you'll have issues. I have heard you can use a cd copy of the game but you'll need to patch it to a newer version in order for it to work properly with xash3d. You'll need to consult the xash3d documentation for further details as I can't remember off the top of my head which patch version is the minimum requirement.
                          plimbs
                          @quicksilver Dude, this is awesome info from you! Works perfect on my pi 4 with mouse and keyboard.
                          On my 3b, I can seemingly compile the new FWGS version, but I get errors trying to use it. The game is very playable with original install script. Neither one recognizes my bluetooth controllers at all so I cannot play with a controller.
                          Has anyone managed to compile FWGS and run successfully on the 3b?
                            plimbs @plimbs
                            This is what I get :
                            pi@retropie3:~ $ cat /dev/shm/runcommand.log
                            Parameters:
                            Executing: /opt/retropie/ports/xash3d/Xash3D.sh
                            [15:39:58] Console initialized.
                            [15:39:58] IN_TouchInit()
                            [15:39:58] execing video.cfg
                            [15:39:58] Found renderer gl: OpenGL
                            [15:39:58] Found renderer soft: Software
                            [15:39:58] Loading renderer: gl -> libref_gl.so
                            [15:39:58] execing opengl.cfg
                            [15:39:58] Trying safe opengl mode 0
                            [15:39:58] bpp 32
                            [15:39:58] Sys_Warn: Error: Can't initialize libref_gl.so renderer!
                            [15:39:58] Loading renderer: soft -> libref_soft.so
                            [15:39:58] r_fullbright is cheat protected.
                            [15:39:58] r_lightmap is cheat protected.
                            [15:39:58] Sys_Warn: invalid mode, engine will run in 640x480
                            [15:39:58] Sys_Warn: could not revert to safe mode!
                            [15:39:58] failed to initialize software blitter, fallback to glblit
                            [15:39:58] Sys_Warn: Error: Can't initialize libref_soft.so renderer!
                              mitu Global Moderator @plimbs
                              @plimbs said in Setting up Half-Life through RetroPie (A Guide):
                              The Pi3 doesn't have OpenGL support with the default drivers - only OpenGL ES.
                                plimbs @mitu
                                @mitu Yes, you are right. I knew that as well. But it also fails to fall back to the software renderer, which runs very well on the Pi 3 with the older code base. Wondering if anyone else got past this.
                                • quicksilverQ
                                  quicksilver @plimbs
                                  @plimbs I do have xash3d running on my pi zero so it should work on a pi 3 if you compile it correctly. Unless they no longer support OpenGLES or something.
                                  Edit: xash3d github states it supports gles so I'm not sure what the issue is.
                                  • PittStoneP
                                    PittStone
                                    Hello, i need help with xash3d-fwgs Controller Setup. My right Analog Controlls for look up and left, right not working. If i go to controller setups the right Analogs not working. I use Logitech Wireless Controller. Maybe its an dinput problem? And xash3d works only with xinput?
                                      plimbs @quicksilver
                                      @quicksilver So that must be the question... Am I compiling correctly? I get no errors that I can see during the build. It completes successfully.
                                      • ExarKunIvE
                                        ExarKunIv @plimbs
                                        @plimbs it seems that someone will need to go on github and ask the devs for xash3d about it.
                                        thats what i did to get it to compile again with the script from zerojay.
                                        now i have a pi4 and i have not tested it yet. so im not much help on this
                                        and i used the old way to get it working on my Pi3, and that way uses the old version from FWGS
                                          KiloMane
                                          @quicksilver i’m stuck on step three- If you wish to use a controller to play this game edit the file /opt/retropie/ports/xash3d/Xash3D.sh and add -sdl_joy_old_api to the end of the line. You can also remove -console from that line if you don't want the constant console messages on screen- I don’t know where to put the line of code or how it should look, but I can’t get it to work please help :/ -Pi4 retropie xash3d (not fwgs), controller sn30pro or Xbox one also hoping to setup controls for Piboy DMG
                                          • quicksilverQ
                                            quicksilver @KiloMane
                                            @kilomane said in Setting up Half-Life through RetroPie (A Guide):
                                            You need to edit the file located at /opt/retropie/ports/xash3d/Xash3D.shand remove -console from the line of text in that file and add -sdl_joy_old_apiat the end of the line of text to enable joystick control.
