    Setting up Half-Life through RetroPie (A Guide)
    half-lifexash3d
    147 Posts 30 Posters 64.7k Views
      plimbs @ExarKunIv
      @ExarKunIv WOW. Excellent work! Flawlessly installs and runs, and I really like the improved menus over the original Extras script.
      • ExarKunIvE
        ExarKunIv @plimbs
        @plimbs I'm glad it worked out for you
        I'm happy you like the new menu. @sleve_mcdichael worked hard on it.
          Retro Arcade Fan @ExarKunIv
          @ExarKunIv Hi. When I type in the following:
          cd ~
          cd RetroPie-Extra/
          ./update-extras.sh
          I get this:
          -bash: ./update-extras.sh: No such file or directory
          • ExarKunIvE
            ExarKunIv @Retro Arcade Fan
            @Retro-Arcade-Fan
            Next time make a new post or in suggestions for ports #2
            Just to keep this post more for half life
            When did you fist download RetroPie-Extra. If was awhile ago.
            Things have changed so your load probably doesn't have that file to update it.
              @ExarKunIv I am posting here specifically for Half Life. Tried it before and didn't have success. Read here that the updated extras made it work. Yes, it's been several months since I first installed extras.
              That being said, to get Half Life working, what's the best way to proceed please?
              • ExarKunIvE
                @Retro-Arcade-Fan yes 2 weeks ago the half life script was updated.
                we changed the update script back in april so if it before then then look here for help.
                https://retropie.org.uk/forum/topic/31580/suggestions-for-ports-2/191
                is it was after, then ./update-extras.sh should work
                  @ExarKunIv Definitely before. I went to the link but there seems to be conflicting postings. It's a long post. Is the following the best way to update an old install?
                  cd ~/RetroPie-Extra
                  git pull origin
                  ./install-extras.sh
                  or
                  git reset --hard HEAD^
                  git remote set-url origin https://github.com/Exarkuniv/RetroPie-Extra
                  git pull origin
                  • ExarKunIvE
                    @Retro-Arcade-Fan said in Setting up Half-Life through RetroPie (A Guide):
                    git pull origin
                    i would say that since you have the same thing going on as who @sleve_mcdichael was helping
                      @ExarKunIv Alright. Update finished. However, after 30 minutes, I got this error:
                      Could not successfully build xash3d-fwgs - xash3d-fwgs - Half-Life Engine Port (/home/pi/RetroPie-Setup/tmp/build/xash3d-fwgs/xash3d-fwgs/build/mainui/libmenu.so not found).
                      /home/pi
                      • ExarKunIvE
                        @Retro-Arcade-Fan i think somehow it is still running the old script.
                        i did a fresh download from my github it installs fine.
                        but now what to do to fix it
                          @ExarKunIv When/If you or someone else figures it out, please let me know. In the meantime, is there any way to just do the updated install for half life?
                          p.s.: What does "clean source folder" mean under the install?
                          @sleve_mcdichael any ideas?
                          ExarKunIvE 2 Replies Last reply Reply Quote 0
                          • ExarKunIvE
                            clean source folder
                            cleans the folder the install script uses to build the files that are needed for the port to work. cleaning it just deletes that folder.
                            • ExarKunIvE
                              @Retro-Arcade-Fan after you updated it did you run
                              cd RetroPie-Extra/
                              ./install-extras.sh
                              you updating the script does not install or update any of the ones that are already installed to where the RetroPie menu sees them. you need to reinstall them.
                              i think that will overwrite them. not too sure @sleve_mcdichael would know better on what the install-extras does
                                @ExarKunIv Yes I did. It said it was up to date.
                                What about removing extras entirely and reinstalling it? Or too painstaking?
                                • ExarKunIvE
                                  @Retro-Arcade-Fan it will say updated when it updated the main script.
                                  That doesn't install any of the new scripts.to where RetroPie sees them
                                  You have to do that with install-extras. This will open a GUI where you can remove and or install the new ones
                                  Personally I would wipe out retropie extras completely and redownload because the fact is that I have gone through an updated and tested every single script and if yours is from that long past it's going to have script that don't work or don't work properly
                                  If you use the GUI The remove function I think would wipe out even the old scripts also that you currently have
                                    @ExarKunIv That seemed to work, thank you. I removed it all and reinstalled. Thought it would take longer, but was quick. Then installed xash3d-fwgs.
                                    • ExarKunIvE
                                      @Retro-Arcade-Fan I'm glad that worked out.
                                      Yeah it is a bit confusing from going from a old repo to a new version when we changed quite a bit on how things get installed.
                                        @ExarKunIv Thanks. The take-away seems to be it's best to remove and install from scratch! So excited to play Half Life again on my arcade cabinet. Thanks again for all of your help!! I appreciate all of your previous and future work on these ports.
                                          plimbs
                                          I'm seeing this thread now. I am not 100% sure this is your issue @Retro-Arcade-Fan, but it is what happened to me. I had the old/original version of the Extras scripts installed. They are mixed in with all the other normal Retropie setup scripts. The new install places the scripts in a better location, making them more manageable, but if you already had the prior version they will still be there and Retropie won't recognize the new ones.
                                          My simple fix to this was to compare the cloned folder from git with the existing Retropie setup folders and remove any matching files. Then, you can "clean install" from install-extras.sh.
                                          Here is a simple command for you:
                                          diff -qrs RetroPie-Setup/scriptmodules/ RetroPie-Extra/scriptmodules/ | grep -v "Only" | cut -d " " -f2 | xargs rm
                                            Retro Arcade Fan @plimbs
                                            @plimbs Thanks for chiming in here. Fortunately once I removed the old install and did the new install, it fixed the problem. It's playing perfectly now.
