    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 113.8k Views
      phialek @mechafatnick
      @mechafatnick
      I don't know what a standard x server is. :))
      modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/5.10.52-v7l+
      xrandr: Failed to get size of gamma for output default
      xrandr: cannot find mode 800x600
      I really think the problem is in those lines
      • FollyF
        Folly @phialek
        @phialek
        Can you do commands in the terminal ?
        Can you post the output of "xrandr" ?
        Perhaps there is a lead, in there.
        Just type "xrandr" like this :
        pi@raspberrypi:~ $ xrandr
        Screen 0: minimum 320 x 200, current 1600 x 900, maximum 7680 x 7680
        HDMI-1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 440mm x 250mm
           1600x900      60.00*+
           1920x1080     60.00    59.94
           1440x900      59.90
           1280x800      59.91
           1152x864      75.00
           1280x720      60.00    59.94
           1024x768      75.03    60.00
           832x624       74.55
           800x600       75.00    60.32    56.25
           720x480       60.00    59.94
           640x480       75.00    60.00    59.94
           720x400       70.08
          phialek @Folly
          @folly
          The outcome is quite funny:
          Can't open display
          That's all what the terminal is giving me back.
          • FollyF
            Folly @phialek
            @phialek
            Oh yea sorry, I forgot, you can't run xrandr without X-windows/xinit.
            As you do not have a desktop environment.
            So in this state, this output is ok.
            We have to do it a bit different.
            Can you add a line in /opt/retropie/configs/supermodel/emulators.cfg :
            xrandr = "XINIT:xrandr"
            And when you boot a rom select this line at launch.
            Now the output of xrandr will show in :
            /dev/shm/runcommand.log
              phialek @Folly
              @folly
              ok
              this is the outcome:
              Parameters:
              Executing: xinit /dev/shm/retropie_xinitrc -- vt1 -keeptty
              X.Org X Server 1.20.4
              X Protocol Version 11, Revision 0
              Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
              Current Operating System: Linux retropie 5.10.52-v7l+ #1441 SMP Tue Aug 3 18:11:56 BST 2021 armv7l
              Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:37:FC:DD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=2aba0d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
              Build Date: 19 April 2021 03:23:36PM
              xorg-server 2:1.20.4-1+rpt3+deb10u3 (https://www.debian.org/support)
              Current version of pixman: 0.36.0
              Before reporting problems, check http://wiki.x.org
              to make sure that you have the latest version.
              Markers: (--) probed, (**) from config file, (==) default setting,
              (++) from command line, (!!) notice, (II) informational,
              (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
              (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Wed Aug 11 19:34:27 2021
              (==) Using system config directory "/usr/share/X11/xorg.conf.d"
              xrandr: cannot find mode 640x480
              Set mode 640x480@60Hz on default
              Executing (via xinit): SDL_VIDEO_KMSDRM_CRTCID=87 SDL_VIDEO_KMSDRM_MODEID=37 xrandr
              Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
              default connected 1920x1080+0+0 0mm x 0mm
              1920x1080 0.00*
              xinit: connection to X server lost
              waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
              • FollyF
                Folly @phialek
                @phialek
                Thanks.
                There are a few things I see.
                xrandr only sees 1 resolution.
                And I don't have this :
                Well, I have to think about that.
                Not really sure where to look.
                I think I will hook up a TV and see what my output is.
                I will look at it tomorrow again and it can take a while before I respond to it.
                  phialek @Folly
                  @folly
                  im really thankful!
                    @phialek said in Sega model 3 #segamodel3:
                    1920x1080 0.00*
                    This may happen because you modified config.txt and instructed the bootloader to ignore the display's EDID. Did you edit the config.txt file ? Then post the contents here - surrounded by code tags (```).
                      phialek @mitu
                      thanks for your help. ive defiantly altered the config file because of overclocking, which runs stable. ive also tested supermodel without oc whivh was even slower. here is the config:
                      # http://rpf.io/configtxt
                      #hdmi_safe=1
                      disable_overscan=1
                      #overscan_left=16
                      #overscan_right=16
                      #overscan_top=16
                      #overscan_bottom=16
                      # overscan.
                      #framebuffer_width=1280
                      #framebuffer_height=720
                      hdmi_force_hotplug=1
                      hdmi_group=2
                      hdmi_mode=82
                      hdmi_ignore_edid_audio=1
                      #hdmi_drive=2
                      # no display
                      #config_hdmi_boost=4
                      # uncomment for composite PAL
                      #sdtv_mode=2
                      #arm_freq=800
                      over_voltage=8
                      arm_freq=2147
                      gpu_freq=750
                      #dtparam=i2c_arm=on
                      #dtparam=i2s=on
                      #dtparam=spi=on
                      # Uncomment this to enable infrared communication.
                      dtparam=audio=on
                      [pi4]
                      # Enable DRM VC4 V3D driver on top of the dispmanx display stack
                      dtoverlay=vc4-fkms-v3d
                      max_framebuffers=2
                      [all]
                      #dtoverlay=vc4-fkms-v3d
                      #overscan_scale=1
                      gpu_mem=64
                        mitu Global Moderator @phialek
                        @phialek Any reason you've added the hdmi_group/mode options ? Comment them, along with the hdmi_force_audio_edid=1 and try again. If you have a Pi4, the gpu_mem is also redundant and it's not needed (default is 76M).
                          phialek @mitu
                          I think i was trying to rotate the screen in moonlight, but i don't remember that really.
                          Can i just delete the hdmi group and hdmi mode comments there?
                          • FollyF
                            Folly @phialek
                            @phialek
                            Good call of @mitu.
                            Actually I was thinking a bit in the same area, yesterday.
                            I would not delete the lines just comment them with # .
                            Your pi should boot if you comment those lines, just like this :
                            #hdmi_force_hotplug=1
                            #hdmi_group=2
                            #hdmi_mode=82
                            #hdmi_ignore_edid_audio=1
                            Be aware that you always turn on your TV or monitor before turning on the pi.
                            Not the other way around, as the pi might not recognize the TV or monitor.
                              phialek @Folly
                              @folly
                              That is a small problem. I have a cabinet and everything will is powered on at the sane time. I will try it out anyway :)
                              • FollyF
                                Folly @phialek
                                @folly
                                Powering the tv and pi at the same time will often give the same problem, not recognizing the TV or monitor properly.
                                Curious if it will improve after all recommendations.
                                  phialek @Folly
                                  @folly
                                  unfortunatly that didnt help at all....
                                  the log changed though, no more errors. but performance is as slow as before.
                                  supermodel
                                  Supermodel-mechafatnick-496x384
                                  /home/pi/RetroPie/roms/supermodel/daytona2.zip
                                  SDL_VIDEO_KMSDRM_CRTCID=87 SDL_VIDEO_KMSDRM_MODEID=37 pushd /opt/retropie/emulators/supermodel-mechafatnick; SDL_VIDEO_KMSDRM_CRTCID=87 SDL_VIDEO_KMSDRM_MODEID=37 ./supermodel -res=496,384 "/home/pi/RetroPie/roms/supermodel/daytona2.zip"
                                  • FollyF
                                    Folly @phialek
                                    @phialek
                                    Sad to hear it isn't improved.
                                      phialek @Folly
                                      @folly
                                      It's ok, ill stream those games over moonlight.
                                      Im sure though that one day i will get it to work ;)
                                        mechafatnick @phialek
                                        @phialek How do other games hold up? Try Virtua Fighter 3.
                                        • FollyF
                                          Folly @mechafatnick
                                          @mechafatnick said in Sega model 3 #segamodel3:
                                          @folly Yes we talked about that didn't we? This is a good plan
                                          I canceled my idea of making a new thread, at this moment.
                                          It seems there isn't that much amino for it, otherwise more people would have reacted on the idea.
                                          We can always do it in the future, when there is more desire.
                                          Agreed ?
                                          CrushC LibationL 2 Replies Last reply Reply Quote 0
                                          • CrushC
                                            Crush @Folly
                                            @folly I was waiting with great anticipation for it :-p cause i'm totally lost in this thread, not sure whats still relevant and what is now obsolete instruction wize.
