    Have to switch my RPi 4 on twice for it to work
    raspberrypi4retropiepower problemoverclocking
    9 Posts 3 Posters 734 Views
    • hawkes_84H
      hawkes_84
      Hi
      Bit of a strange one but every time I switch my Raspberry Pi 4 on I have to turn it off and on again for it to work. When I switch it on initially I get the rainbow band over the screen but then it just stays black and then I literally switch it off and on and again and it functions as normal. It's hardly devastating but a bit annoying. It do currently have it overclocked (not sure to which figures) . Also I'm not using an official Pi power pack so perhaps that's a factor?
      Feels like I have to switch it on once to warm it up for a few seconds. They off and on again for it to work. Any ideas on why this happens?
      many thanks
      • quicksilverQ
        quicksilver @hawkes_84
        @hawkes_84 is the green LED light on your pi still flickering while the screen is black? Can you confirm that your TV isnt automatically switching inputs during the boot process?
        hawkes_84H 1 Reply Last reply Reply Quote 0
        • hawkes_84H
          hawkes_84 @quicksilver
          @quicksilver switching inputs? From what to what? I check if the green light is flickering next time. I know it's being recognised because my TV actually says "raspberry Pi" in the corner
          • MeatjunkM
            Meatjunk
            I get the same problem, the green light is on solid and I'm making sure it's set to the right input on my tv
            hawkes_84H 1 Reply Last reply Reply Quote 1
            • hawkes_84H
              hawkes_84 @Meatjunk
              @Meatjunk so what exactly is the issue and how is it rectified?
              • quicksilverQ
                @hawkes_84 said in Have to switch my RPi 4 on twice for it to work:
                For whatever reason, my Vizio TV will sometimes switch inputs automatically to another HDMI input while my pi is booting and I have to switch it back to the correct one. I'm not sure why it happens but it sounded similar to your issue.
                hawkes_84H 2 Replies Last reply Reply Quote 0
                • hawkes_84H
                  @quicksilver surely switching inputs means it receives a signal from a different HDMI cable etc?
                  I'm not sure this has happened since the channel it's on remains the same and surely to rectify I would just switch it back to the correct channel?
                  • hawkes_84H
                    @quicksilver Just tried it again and only the red light comes on the first time i turn it on - not the green light. The green light comes on the 2nd time
                    • quicksilverQ
                      quicksilver
                      Can you post the info requested here? It will help to troubleshoot your issue. https://retropie.org.uk/forum/topic/3/read-this-first
                      Also may want to take a look at this post. Specifically the pi 4 section.
                      https://www.raspberrypi.org/forums/viewtopic.php?t=58151
