    Fixing Screen Tearing issues on RPI4
    configurationgraphicspi4 8gbscreentearing
    43 Posts 13 Posters 23.2k Views
      bluestang @GreenHawk84
      @greenhawk84 the KMS driver for the RPi4 renders omxplayer inoperable. You’ll need to disable it in EmulationStation so that VLC is used instead.
      The FKMS driver will be forever broken when it comes to vsync and tearing. Hence why the KMS driver is actively being worked on and FKMS is not. At some point, any emulator that relies on displaymanx for the RPi4 will need code changes if they want to support the KMS driver.
      Eventually the KMS driver will become the featured driver. The latest 5.10.17 kernel works fairly well with it. You should just be able to get from apt.
      GreenHawk84G 1 Reply Last reply Reply Quote 2
      • GreenHawk84G
        GreenHawk84 @bluestang
        @bluestang wow, that's rather disappointing news, since there is no telling when kms will be fully implemented. I find that both ways cause showstoppers for me, one being kms breaks a bunch of other stuff, and then of course now having some very noticeable tearing. I guess I can just hope things improve sooner than later, if there is a way to donate I will.
          dankcushions Global Moderator @GreenHawk84
          @greenhawk84 to be clear they’re never going to fix dispmanx/omx support. these utilise features of the original closed source gpu firmware that they have replaced with an open, more standard linux solution. it’s not all bad news, though, as there’s typically an alternative solution (eg vlc rather than omx, but you may have to re-encode/replace your videos).
