    Re: Is there a simple way to make DragonRise controllers work with Daphne??
    dragonrisedaphne
    3 Posts 2 Posters 490 Views
      traknchase
      When following the instructions posted on the previous thread, I get the following error:
      fatal: could not create work tree dir 'tmp/build/daphne': Permission denied
      How can I get around this?
        The tmp/build folder is root owned, so you probably need to prefix the git command with sudo:
        sudo git clone https://github.com/grant2258/daphne-emu.git tmp/build/daphne
          traknchase @mitu
          @mitu That did it! Thank you!!!
