    Missing Sound Effects in DK and DKJr
    sounddonkey konglibretro
    4 Posts 2 Posters 1.2k Views
      spanishsnowman
      I've the posts and resolutions for the missing effects in these games, such as Mario running, or DKjr moving around. I know the resolution is to get the sample files in the right folder.
      This isn't working for me. I can open the sample files and play the .WAV so I know they're right ones, but they just aren't working.
      I have my ROMS in the roms\mame-libreto\roms folder, and the sample files in the roms\mame-libreto\samples folder.
      Any suggestions?
      YFZdudeY 1 Reply Last reply Reply Quote 0
      • YFZdudeY
        YFZdude @spanishsnowman
        @spanishsnowman said in Missing Sound Effects in DK and DKJr:
        I have my .... sample files in the roms\mame-libreto\samples folder.
        Any suggestions?
        That appears to be the incorrect path according to https://retropie.org.uk/docs/MAME/#lr-mame2003-mame-2003
        Samples ........................... /home/pi/RetroPie/BIOS/mame2003/samples/
        Of course if you are using a different version of MAME you will need to check that page either further up or down to match the version you use.
          spanishsnowman @YFZdude
          @yfzdude Thanks. I'll move them and give it a try.
            @yfzdude Totally worked. Thanks for pointing out the doc.
