    Going back from usb storage to microSD
    usb drivemicrosd card
    5 Posts 4 Posters 736 Views
    • chubstaC
      chubsta
      Have decided to use my Pi400 for purely computer emulation - C64, Spectrum etc. Currently have all of my roms on a 2tb external USB HD so the plan is to remove all non-computer roms, which should only leave a few systems taking up a small amount of space , therefore the hd is not needed.
      Will it be as simple as just copying the 'retropi-mount' folders to the microsd card and all will be well is is there more to it than that?
      Raspberry Pi 400 - overclocked to 2.3GHz
      Theme - Comic book
      Emulators: All of them...
      Roms: Pretty much all of them...
      Favourite games: Circus Charlie, Gorf, Gauntlet Legends
      Controllers: Mayflash F101
      KN4THXK dankcushionsD 2 Replies Last reply Reply Quote 0
      • KN4THXK
        KN4THX @chubsta
        @chubsta From my experience in the last, the usb storage overrides the sd card 'Retropie' folder. It's still there on the card, just not looked at. So yes, it should be that simple.
        "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
          dankcushions Global Moderator @chubsta
          @chubsta one thing you could do is rename retropie-mount folder to retropie, then when you reinsert it will copy everything left in there to the SD, as per https://retropie.org.uk/docs/Transferring-Roms/#usb-stick
          chubstaC 1 Reply Last reply Reply Quote 2
          • chubstaC
            chubsta @dankcushions
            @dankcushions said in Going back from usb storage to microSD:
            That’s an interesting way to do it, didn’t think of that! One thing though, would it just transfer the ROMs or would it move all the associated scraped data which I have in the rom folders too?
            Thanks for the help guys, always like to get an opinion before I try something and mess up!
            Theme - Comic book
              The rom folders are copied verbatim and there's no filtering done, so it will copy anything there, including any artwork scraped.
