    Problems with C64 and N64 emulation
    generalvice c64amiberryn64controls
    24 Posts 4 Posters 6.4k Views
    • E
      evilscytheman @mitu
      Maybe the menu button is stuck ? Can you use the 'Select' (Share) button instead and see if it happens again ?
      it was the same ... you mentioned resetting the core options ... with all that problems I started from the beginning...
      New retropie install.
      PS4 controller setup with ds4drv
      PS4 Controller setup in Emulationstation, keyboard not setup as controller, because that seemed to messing up things (at least for me)
      But now the controller isn't recognized in Retroarch. It is bewitched :(
      I cant even get into the settings menu in the Retroarch mainmenu because the enter button of my keyboard is not recognized. Arrows are working, but nothing else.
      Now my confusion is perfect... Sorry but it seems I'm not compatible with that :)
        mitu Global Moderator @evilscytheman
        @evilscytheman said in Problems with C64 and N64 emulation:
        Why do you install ds4drv ? It's an old un-maintained driver which is not needed for a PS4 dualshock controller. Just connect the controller via bluetooth and configure it in EmulationStation.
        • E
          evilscytheman @mitu
          @mitu said in Problems with C64 and N64 emulation:
          Because of this statement in the DOCs
          "If you wish to use either a USB Bluetooth adapter or the Pi 3's built-in Bluetooth then regular Bluetooth pairing in the menu may work, or you may need to use the userspace controller driver called ds4drv. It depends on your individual controller."
          Because pairing didn't work in the menu, I tried with ds4drv.
          But OK, i will delete ds4drv and retry without it.
            We may have to amend the docs and don't recommend ds4drv anymore. Try with regular bluetooth pairing again - it should work.
