    2.3k Posts 37 Posters 7.3m Views
    • DTEAMD
      DTEAM @Folly
      @Folly said in Development of module-script generator for lr-mess and mame standalone:
      @DTEAM
      Can you test it again.
      I updated the script.
      The config directory for mame is back to default.
      It should be fixed now.
      https://github.com/FollyMaddy/RetroPie-Share/commit/ffb480144328b436625d7c03266e5092771dc109
      https://github.com/FollyMaddy/RetroPie-Share/commit/77b05a8d5c605e7c0f99444939b45bf971319b72
      It works perfectly !!!! Savestates also with system name (see Gamate)
      • DTEAMD
        DTEAM @DTEAM
        @Folly
        @DTEAM
        Gamate and MSX2 (I did my tests on Gamate for now)
        Today, I tested MSX2 (cartridge) and it works well . Is it possible to combine MSX2 (Sony HB-F700) extra with default (flop and cart). We have to do two installations to do that. Also, I think you could add MSX 2 in your categorie (systems discussed in the forum). MAME is now my favorite emulator for MSX2; gamepad easy to set and a working savestate. I'll be able to play MetalGear and save my game without black screen.
        Great job!!!
        F 2 Replies Last reply Reply Quote 0
        • F
          Folly @DTEAM
          @DTEAM
          Nice to hear that it works so good. ;-)
          I think it's possible to split all the MSX1/MSX2/MSX2+/TURBO-R machines so it will be installed as the retropie-name/categories msx/msx2/msx2+/msxturbor.
          ALL DONE, everything looks good, ready for testing.
          Added recognition for "Atari 7800" too. (a7800->atari7800)
          I have had the idea to combine the default and extra installers so it can be installed in one go.
          For now, I don't have a good idea on how to accomplish that.
          I will have a look at it.
          • F
            Folly @DTEAM
            @DTEAM said in Development of module-script generator for lr-mess and mame standalone:
            Re-read your post.
            Now on second thought, I think you mean something different than what I implemented.
            Did you mean that you want the hbf700p in the "pre-sorted-lists / forum-list" ?
            Edit :
            Added to the predefined forum list :
            • vg802020 (MSX1)
            • hbf700p (MSX2)
            • DTEAMD
              DTEAM @Folly
              @Folly
              I tested a fresh installation of classich today and the command lines in emulator.cfg doesn't work. I don't know why. Also., we could add lr-gw emulator in the list for classich.
              lr-gw = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-gw/gw_libretro.so --config /opt/retropie/configs/classich/retroarch.cfg %ROM%"
              F 3 Replies Last reply Reply Quote 0
              • F
                Folly @DTEAM
                @DTEAM
                Will have a look at classich if I can find some problems.
                EDIT:
                Adding lr-gw will be problematic to implement, I think.
                DONE :
                https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-and-mame-standalone/1048
                • F
                  Folly @DTEAM
                  @DTEAM
                  I have no problem with classich, everything seems ok.
                  I think it's a problem on your side.
                  Can you check the runcommand.log ?
                  A week ago I had a problem with classich.
                  The rom files I had were 0kb, that was my problem back then.
                  DTEAMD 2 Replies Last reply Reply Quote 0
                  • F
                    Folly @DTEAM
                    I can have a look.
                    EDIT:
                    Added a new line combining the 2 installs (classich +lr-gw).
                    When everything looks good, then we have to change the HELP part, in the line, later.
                    Not needed anymore :
                    If it can't be done nicely then making a modified 3rd-party module-script for lr-gw can also be a possibility.
                    https://github.com/FollyMaddy/RetroPie-Share/commit/d406ca32ec48a660f27c7f2cf122b7d58ae8653c
                    • F Folly referenced this topic on
                    • F
                      Folly @jamrom2
                      @jamrom2
                      https://github.com/FollyMaddy/RetroPie-Share/commit/4a0256ca23f3ae410e7c5f82f16a16c4e802e84f
                      • jamrom2J
                        jamrom2 @Folly
                        @Folly
                        I was able to "cure" it for myself by just copying the lines missing from my previous install. It works good for now. :)
                        • F
                          Folly
                          From now on I will try to update only 1 file to save some time :
                          00-scriptmodules-00/supplementary/add-mamedev-systems.sh
                          And I will try to stop updating versions in the 00-workdir-00 if possible.
                          Electron can now be used with dfs210 to load disks.
                          This add will increase the possibility to load many more disks, just like elkulator does.
                          To load with the correct bios was problematic, they helped me out here :
                          https://forums.bannister.org/ubbthreads.php?ubb=showflat&Number=120623#Post120623
                          https://github.com/FollyMaddy/RetroPie-Share/commit/b1dcab570fc88649bab4c10f1b04f8c1d19204d7
                          • DTEAMD
                            DTEAM @Folly
                            @DTEAM
                            Everything is working fine now. I used the latest script. lr-gw works well too. Good work!!
                            • F
                              Folly @DTEAM
                              @DTEAM
                              Thanks ;-)
                              Have you also been thinking of adding the bezels from here :
                              https://retropie.org.uk/forum/topic/32310/bezels-for-coleco-tabletop-arcade-games
                              Into the mame artwork ?
                              jamrom2J DTEAMD 2 Replies Last reply Reply Quote 0
                              • jamrom2J
                                jamrom2 @Folly
                                @DTEAM
                                Thanks ;-)
                                If you haven't done so already, definately try them. They're great. Really adds to the game.
                                I have bezel's from all over, and many I made combining artwork from other artists working on MAME. Makes a world of difference to the look of the game!
                                • F
                                  Folly @jamrom2
                                  @jamrom2
                                  Yes, I have tried them.
                                  Would be nice when it's possible to integrate them into the Standalone Mame Artwork (from our downloads in the script) and the possibility to then extract the bezels for lr-mess and build them up with the correct .cfg files, just like we do with the backgrounds of many handhelds.
                                  Then we only have to download the artwork in the script and generate the bezels for lr-mess without having to download the bezels and create all these .cfg files separately .
                                  • DTEAMD
                                    DTEAM @Folly
                                    @DTEAM
                                    Thanks ;-)
                                    I use them with instructions from @jamrom2 (thanks by the way!). However, the Pengo-specific instructions don't work for me. I don't know if it's because I have a 5" screen. If I have some time, I could convert some to MAME artworks. In some cases, they already existed in MAME artwork format.
                                    • F
                                      Folly @DTEAM
                                      @DTEAM
                                      So when some of them already exist then we could use these.
                                      Only the bezel has to be always the same name in the specific <artwork>.zip (for example bezel.png).
                                      Then we can extract them just like we do with background.png and create overlay configs specific to the bezels.
                                      What do you think, can we make that happen ;-)
                                      We can just start with only 1 and see how it goes.
                                      Btw.
                                      You should read this about MSX and loading with basename (issue) :
                                      https://forums.bannister.org/ubbthreads.php?ubb=showflat&Number=120612#Post120612
                                      • DTEAMD
                                        DTEAM @Folly
                                        @DTEAM
                                        I prefer the "Mame Artwork" option to the "Overlay in Retroarch" option. When you create a MAME artwork, it is not affected by the shape or size of the screen compared to "Overlays in Retroarch"
                                        • F
                                          Folly @DTEAM
                                          @DTEAM
                                          I haven't tried Pengo, indeed it's a different config layout.
                                          We should do the other regular ones first.
                                          Then we can always do Pengo later, If we want.
                                          Rectification :
                                          We should use the filename Bezel.png in an artwork file and make sure there is no Background.png in the same file.
                                          • F
                                            Folly @DTEAM
                                            @DTEAM
                                            Indeed you are correct about that.
                                            The overlays do not always align in different resolutions.
                                            But I think it's a nice feature and perhaps the Bezels can be adjusted so the will work on different resolutions.
                                            Anyhow I added it in the script.
                                            I have still 2 separate lines for Background overlays and Bezel overlays.
                                            So nobody is forced to create the bezels if they don't want to.
                                            I think you can already add just a zip file with a bezel inside to test.
                                            I renamed cgalaxn.png to Bezel.png and zipped that as cgalaxn.zip.
                                            The file had no effect on mame.
                                            So we can just test for lr-mess only at first and then create it later for mame, If you know what I mean.
                                            My configs will also have this (because the Background overlays have that too) :
                                            input_overlay_scale = 1.000000
                                            Edit :
                                            It should be possible for different resolutions we can also create bezels for specific resolutions and call it for example Bezel-1600x900.png and make the options available for these different resolutions
                                            https://github.com/FollyMaddy/RetroPie-Share/commit/a05e12ce7b8014cba7cbd5716b2a77e34ba29b8a
