    • FollyF
      Folly
      @DTEAM
      @Folly said in Development of module-script generator for lr-mess and mame standalone:
      The overlays do not always align in different resolutions.
      I found that this is basically a 16:9 / 4:3 problem.
      The bezels from Jimmy are 16:9 and will work on different resolutions which are 16:9.
      So for lr-mess we probably just need 2 different bezels, one for 16:9 and one for 4:3.
      What resolution or screen-ratio do you think you use ?
      I use 800x600 (4:3) very often and then I have the same problem when using a 16:9 picture.
      You will notice with cgalaxy :
      Can you check this one for me (cut off borders to match 4:3) :
      The script is accommodated to handle both now :
      https://github.com/FollyMaddy/RetroPie-Share/commit/f17089a730147facd41d79306410316ddabbd69b
      • DTEAMD
        DTEAM @Folly
        I'm using a 5" touchscreen (800x480) . This is non-standard for large screens, but standard for small screens. This is why I prefer to use "MAME artworks"
        With your script, are you able to run Alien Chase? I can't run 25% of MAME/lr-mess games in classich. I will check if the problem is on my side.
        • FollyF
          Folly
          @DTEAM
          I will test that game when I am on my Pi, now on a boot traveling for my work.
          On my macbook here it works. (not really know how to play though)
          Are you at least willing to combine the lr-mess bezels into the mame artwork files and place them on the google-drive ?
          Others will enjoy that for sure, including me ;-)
          This is the first one :
          https://ufile.io/ph2miz4n
          (be sure you don't overwrite existing files if they are already there)
          • FollyF
            Folly @DTEAM
            @DTEAM said in Development of module-script generator for lr-mess and mame standalone:
            Yes it does work, at least I think it does.
            It's a tricky game though.
            I had to find the manual and read that a bit on how to play.
            Didn't play long but it seems it works ok.
            Found a bunch of manuals here :
            https://www.handheldmuseum.com
            https://www.handheldmuseum.com/Manuals/index.html
            Btw.
            If it doesn't work then it's probably not due to my script.
            You can post your loader-line from the first lines of the runcommand.log so I can compare and test.
            I think you have the same file as I have but check if you have the same file as I have :
            pi@raspberrypi:~/RetroPie/roms/classich $ sha1sum alnchase.7z
            0f6a2b9d157b96bf41c134675e9841d459b4cd3b  alnchase.7z
            From mame-0.231-merged
            • FollyF Folly referenced this topic on
            • FollyF
              Folly @DTEAM
              @DTEAM @jamrom2
              If you both are interested, I added some interesting stuff in the script :
              • ability to install lr-mame
              • ability to detect systems between arcade or non-arcade
              • use arcade/non-arcade detection to use appropriate libretto core in generated module-script
              • add ability to install arcade categories
              • ability to push a rom index file to the appropriate roms directory (for the handheld/p&p/categories) the file will contain the rom-names associated with that category.
              • detecting all Atari ST/STE/MEGA STE types as retro pie name “atarist”
                ( for the future, the systems don't work very good )
              • categories are also added in the restricted part
              I updated the animated gif in the first post with the latest version.
              I found a nice way to speed up the process of making an animated gif quickly.
              • DTEAMD
                DTEAM @Folly
                @DTEAM
                I have no problem with classich, everything seems ok.
                I think it's a problem on your side.
                Can you check the runcommand.log ?
                A week ago I had a problem with classich.
                The rom files I had were 0kb, that was my problem back then.
                My files seems to be good. Here's my runcommand:
                Parameters:
                Executing: /opt/retropie/emulators/mame/mame -rompath /home/pi/RetroPie/BIOS/mame\;/home/pi/RetroPie/roms/classich -v -c -ui_active -statename classich/"ginv2000" -autoframeskip  "ginv2000"
                Attempting load of mame.ini
                Parsing mame.ini
                Parsing mame.ini
                Attempting load of horizont.ini
                Attempting load of console.ini
                Attempting load of source/hh_tms1k.ini
                Attempting load of ginv2000.ini
                Starting plugin hiscore...
                Starting plugin data...
                Parsing mame.ini
                Parsing mame.ini
                Available videodrivers: x11 KMSDRM RPI dummy
                Current Videodriver: KMSDRM
                	Display #0
                		Renderdrivers:
                			    opengl (0x0)
                			 opengles2 (0x0)
                			  opengles (0x0)
                			  software (0x0)
                Available audio drivers:
                	pulseaudio
                	alsa
                	sndio
                	dsp
                	disk
                	dummy
                Build version:      0.242 (mame0242)
                Build architecure:
                Build defines 1:    SDLMAME_UNIX=1 SDLMAME_X11=1 SDLMAME_LINUX=1
                Build defines 1:    LSB_FIRST=1
                SDL/OpenGL defines: SDL_COMPILEDVERSION=2010 USE_OPENGL=1
                Compiler defines A: __GNUC__=8 __GNUC_MINOR__=3 __GNUC_PATCHLEVEL__=0 __VERSION__="8.3.0"
                Compiler defines B: __unix__=1
                Compiler defines C: __USE_FORTIFY_LEVEL=0
                Enter init_monitors
                Adding monitor screen0 (800 x 480)
                Leave init_monitors
                Enter sdlwindow_init
                Using SDL native texturing driver (SDL 2.0+)
                Loaded opengl shared library: <default>
                Hints:
                	SDL_FRAMEBUFFER_ACCELERATION             (NULL)
                	SDL_RENDER_DRIVER                        (NULL)
                	SDL_RENDER_OPENGL_SHADERS                (NULL)
                	SDL_RENDER_SCALE_QUALITY                 (NULL)
                	SDL_RENDER_VSYNC                         (NULL)
                	SDL_VIDEO_X11_XVIDMODE                   (NULL)
                	SDL_VIDEO_X11_XINERAMA                   (NULL)
                	SDL_VIDEO_X11_XRANDR                     (NULL)
                	SDL_GRAB_KEYBOARD                        (NULL)
                	SDL_VIDEO_MINIMIZE_ON_FOCUS_LOSS         (NULL)
                	SDL_IOS_IDLE_TIMER_DISABLED              (NULL)
                	SDL_IOS_ORIENTATIONS                     (NULL)
                	SDL_XINPUT_ENABLED                       (NULL)
                	SDL_GAMECONTROLLERCONFIG                 (NULL)
                	SDL_JOYSTICK_ALLOW_BACKGROUND_EVENTS     (NULL)
                	SDL_ALLOW_TOPMOST                        (NULL)
                	SDL_TIMER_RESOLUTION                     (NULL)
                	SDL_RENDER_DIRECT3D_THREADSAFE           (NULL)
                	SDL_VIDEO_ALLOW_SCREENSAVER              (NULL)
                	SDL_ACCELEROMETER_AS_JOYSTICK            (NULL)
                	SDL_MAC_CTRL_CLICK_EMULATE_RIGHT_CLICK   (NULL)
                	SDL_VIDEO_WIN_D3DCOMPILER                (NULL)
                	SDL_VIDEO_WINDOW_SHARE_PIXEL_FORMAT      (NULL)
                	SDL_VIDEO_MAC_FULLSCREEN_SPACES          (NULL)
                	SDL_MOUSE_RELATIVE_MODE_WARP             (NULL)
                	SDL_RENDER_DIRECT3D11_DEBUG              (NULL)
                	SDL_VIDEO_HIGHDPI_DISABLED               (NULL)
                	SDL_WINRT_PRIVACY_POLICY_URL             (NULL)
                	SDL_WINRT_PRIVACY_POLICY_LABEL           (NULL)
                	SDL_WINRT_HANDLE_BACK_BUTTON             (NULL)
                Leave sdlwindow_init
                Enter sdl_info::create
                Leave renderer_sdl2::create
                window: using renderer opengl
                renderer: flag SDL_RENDERER_ACCELERATED
                renderer: flag SDL_RENDERER_TARGETTEXTURE
                Audio: Start initialization
                Audio: Driver is alsa
                Audio: frequency: 44100, channels: 2, samples: 512
                sdl_create_buffers: creating stream buffer of 22528 bytes
                Audio: End initialization
                Keyboard: Start initialization
                Input: Adding keyboard #0: System keyboard (device id: System keyboard)
                Keyboard: Registered System keyboard
                Keyboard: End initialization
                Mouse: Start initialization
                Input: Adding mouse #0: System mouse (device id: System mouse)
                Mouse: Registered System mouse
                Mouse: End initialization
                Joystick: Start initialization
                Input: Adding joystick #0: TeensyduinoKeyboard/Mouse/Joystick (device id: 03000000c01600008204000011010000)
                Joystick: Teensyduino Keyboard/Mouse/Joystick [GUID 03000000c01600008204000011010000]
                Joystick:   ...  5 axes, 32 buttons 1 hats 0 balls
                Joystick:   ...  Physical id 0 mapped to logical id 1
                Joystick:   ...  Does not have haptic capability
                Input: Adding joystick #1: TeensyduinoKeyboard/Mouse/Joystick (device id: 03000000c01600008204000011010000)
                Joystick:   ...  10 axes, 148 buttons 1 hats 0 balls
                Joystick:   ...  Physical id 1 mapped to logical id 2
                Joystick:   ...  Has 148 buttons which exceeds supported 32 buttons
                Joystick: End initialization
                Searching font Liberation Sans in -. path/s
                font Liberation Sans|Regular is not TrueType or BDF, using MAME default
                unzip: opened archive file /home/pi/RetroPie/roms/classich/ginv2000.zip
                unzip: /home/pi/RetroPie/roms/classich/ginv2000.zip couldn't find ECD
                mp1604 NOT FOUND (tried in ginv2000)
                tms1100_common2_micro.pla NOT FOUND (tried in ginv2000)
                tms1100_ginv2000_output.pla NOT FOUND (tried in ginv2000)
                ginv2000.svg NOT FOUND (tried in ginv2000)
                Fatal error: Required files are missing, the machine cannot be run.
                sdl_kill: closing audio
                Enter sdlwindow_exit
                Leave sdlwindow_exit
                Do you see something
                • FollyF
                  Folly @DTEAM
                  You need a good ginv2000.7z
                  Look here :
                  https://retropie.org.uk/forum/topic/28345/old-computer-appreciation-thread/1336
                  You can select it in the first that saves in BIOS/mame or the second that saves in RetroPie/downloads.
                  And copy it later to classich.
                  Or do all from the categories that are written directly in classich.
                  Mine works ! (I used mame 0241)
                  • FollyF
                    Folly @DTEAM
                    You also have the newest mame.
                    This version might need a new romset for ginv2000
                    If thats the problem you have to look in the hash table and check the finenames and the checksuns and repack the file again.
                    EDIT:
                    Tested my version on 0242 and it worked.
                    The proper way to check the roms is (I think you can't find it in the hash) :
                    pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listroms ginv2000
                    ROMs required for driver "ginv2000".
                    Name                                   Size Checksum
                    mp1604                                 2048 CRC(f1646d0b) SHA1(65601931d81e3eef7bf22a08de5a146910ce8137)
                    tms1100_common2_micro.pla               867 CRC(7cc90264) SHA1(c6e1cf1ffb178061da9e31858514f7cd94e86990)
                    tms1100_ginv2000_output.pla             365 CRC(520bb003) SHA1(1640ae54f8dcc257e0ad0cbe0281b38fcbd8da35)
                    ginv2000.svg                         374443 CRC(a4ce1e6d) SHA1(57d9ff05d634a8d495b9d544a2a959790cd10b6b)
                    • DTEAMD
                      DTEAM @Folly
                      @Folly
                      The rom is fine. When I put this rom in the JAKKS folder, it works. I don't know what's going on with my classich folder. Roms with MAME artwork and retroarch overlays (at the same time) do not work. I'll see what I can do. The problem is 100% on my side, not related to the script.
                      Solved: It was my emulators.cfg file in /opt/retropie/configs/all . It seems it was corrupted. I deleted everything inside. Now it's fine and I'll start to do MAME artworks (MAME format) for classich with @JIMMYFROMTHEBAY bezels if he agrees.
                      FollyF J 3 Replies Last reply Reply Quote 1
                      • FollyF
                        Folly @DTEAM
                        @DTEAM
                        Glad you found the problem ;-)
                        • FollyF
                          Folly @DTEAM
                          @DTEAM
                          I am thinking of adding DEMO tutorials inside the script.
                          I found the program called asciinema.
                          I used it for creating the base for the new animated gif in the first post.
                          The nice thing about asciinema is that it creates a text based file which doesn't create huge files and asciinema can also be used to play the files.
                          I think ascii-art and ascii-art movies could also be possible this way.
                          You can have a look here :
                          https://asciinema.org
                          Here is a nice one :
                          • FollyF
                            Folly
                            Is there a possibility to add asciinema .cast files as an attachment inside a post ?
                            I tried some things but they didn't work.
                            I now convert it from .cast to .gif to get a good result.
                            Here you will find the docs :
                            https://asciinema.org/docs/usage
                            Do you have an idea ?
                            • DTEAMD
                              DTEAM @Folly
                              I looked at the hyperlink with the animation videos. It looks very good. It doesn't look friendly user.. for me. A learning curve seems to be necessary.
                                mitu Global Moderator @Folly
                                You can post the URL to the Asciicast now and it will be embedded. The forum has an 'embedding' plugin that does some translation to make it look nice, but Asciinema wasn't one of the supported sites. Should be now (see your previous post).
                                • FollyF
                                  Folly @mitu
                                  I used the share button to find what to insert and also found the better docs for this :
                                  https://asciinema.org/docs/embedding
                                  I used the markdown now, it works but the "video" is displayed outside the post.
                                  Is it also possible to add script tags to play it inside the post ?
                                  Markdown :
                                    There was an error in my configuration. Now you should be able to post just the link and a player should be embedded automatically, you don't need any code added. Just provide the link to the cast as https://asciinema.org/a/<CAST_ID>.
                                    Reload the page and look at your first post. Actually your first post has a gif embedded. Add the cast link under it and see how it works.
                                    • FollyF
                                      Folly @mitu
                                      I don't have the link right now of my cast.
                                      Basically, I reloaded the page and accordingly the link of the matrix should play now, if I understood correctly.
                                      Or am I wrong ?
                                      I will do some tests later, Have to go to work now ;-)
                                        Yes, doesn't it play already ?
                                        • FollyF
                                          Folly @mitu
                                          Just tried again.
                                          Yep, it works now.
                                          WOW ;-)
                                          Thanks !
                                          Edit (this is the first asciinema test) :
                                            Hm, it looks fishy in latest Firefox (the asciicast is cut on the right side), but Chrome seems to display it ok. Might have to fiddle with the embed plugin to make it look ok.
