    • FollyF
      Folly @DTEAM
      @DTEAM
      Ok, that is good information.
      Not sure whats the problem.
      I will have to think about it for a while.
      I tried a low resolution 720x400 and it looks good, so low resolutions are not the problem. (good to know)
      Is your config looking like this ?, with a bit different values :
      custom_viewport_height = "252"
      custom_viewport_width = "329"
      custom_viewport_x = "198"
      custom_viewport_y = "74"
      input_overlay = "/opt/retropie/configs/all/retroarch/overlay/realistic/720.cfg"
      aspect_ratio_index = "23"
      video_shader = "/opt/retropie/configs/all/retroarch/shaders/fake-crt-geom.glslp"
      My runcommand.log does not find cfg overides, does yours find some (so it will undo some settings from the overlay cfg) ?:
      [INFO] [Overrides]: No core-specific overrides found at "/home/pi/.config/retroarch/config/MAME/MAME.cfg".
      [INFO] [Overrides]: No content-dir-specific overrides found at "/home/pi/.config/retroarch/config/MAME/realistic.cfg".
      [INFO] [Overrides]: No game-specific overrides found at "/home/pi/.config/retroarch/config/MAME/ 720.cfg".
      Can you find the scaling options in the RetroArch GUI, mine look like this (here we can see that the viewport values are working) (z > settings > video > scaling) :
      DTEAMD 3 Replies Last reply Reply Quote 0
      • DTEAMD
        DTEAM @Folly
        @Folly
        Aspect Ratio = Core provided
        • FollyF
          Folly @DTEAM
          @DTEAM
          Not sure why, but it has to be "custom".
          I will try "core" here, and see what happens.
          • DTEAMD
            DTEAM @Folly
            @Folly said in Development of module-script generator for lr-mess and mame standalone:
            No, in /opt/retropie/configs.hdmi/all/retroarch/overlay/realistic my 720.cfg look like this :
            overlays = 1
            overlay0_full_screen = true
            overlay0_descs = 0
            This Realistic Arcade Overlay was made by: OrionsAngel
            in /opt/retropie/configs.hdmi/all/retroarch/config/MAME/realistic, it looks like this
            **720.zip.cfg ** and **720.7z.cfg **
            custom_viewport_height = "303"
            custom_viewport_width = "365"
            custom_viewport_x = "220"
            custom_viewport_y = "89"
            • FollyF
              Folly @DTEAM
              @DTEAM
              I mean > /home/pi/RetroPie/roms/realistic/720.zip.cfg
              I tried "core" (22) and then the viewport settings are off.
              When I set it from core to custom into the RetroArch GUI (scaling) it will shrink again to the viewport values.
              Can you try that, to see if it works ?
              Edit I see what the problem is.
              It's the configs.hdmi directory.
              I think it was part of the Valerino fork.
              It should be linked to the normal /opt/retropie/configs directory.
              But when it's not the .zip.cfg and .7z.cfg can't be moved by my script to the /home/pi/RetroPie/roms/realistic roms directory.
              (or by definition there wasn't a /home/pi/RetroPie/roms/realistic in the first place so the files can't be moved, perhaps)
              So you should move or copy the .zip.cfg and .7z.cfg to the /home/pi/RetroPie/roms/realistic roms directory.
              • DTEAMD
                DTEAM @Folly
                I have no folder realistic in /home/pi/RetroPie/roms/
                The only one I have is in /opt/retropie/configs.hdmi/all/retroarch/config/MAME/
                I will do that. I have to go now, I'll try tomorrow
                FollyF 2 Replies Last reply Reply Quote 1
                • FollyF
                  Folly @DTEAM
                  @DTEAM
                  EDIT: Skip this part, look at the next post.
                  Install this again.
                  Choose and install HANDHELD/PLUG&PLAY/CATEGORIES > Submenu
                  Forcing Arcade Category => realistic
                  Then you should have the /home/pi/RetroPie/roms/realistic
                  • Place your 720.zip there.
                  • Move the 720.zip.cfg there.
                  • Test the rom.
                  • If it doesn't work, edit the file 720.zip.cfg so it will find the config.hdmi directory.
                  Select realistic in emulationstation.
                  I think it should work then. ;-)
                  • FollyF
                    Folly @DTEAM
                    @DTEAM
                    Good luck tomorrow, I think we are on the right track now.
                    With the information from yesterday I updated the script.
                    So try this update first.
                    I did some tests with linking directories.
                    Moving and removing from within linked directories should work.
                    So you probably have :
                    /opt/retropie/configs.hdmi/all/retroarch/...... (is the actual folder)
                    /opt/retropie/configs/all/retroarch/...... (is the linked folder)
                    You did not have the roms/realistic directory.
                    When not there it can't move the files.
                    So I fixed this when selecting "Setup Orionsangels Arcade Overlays Part1 > roms/realistic" it will check if the roms/realistic directory exists.
                    If not the it will automatically install the Arcade realistic category/folder.
                    Just press <n> when you see this, it will skip downloading the file again :
                    getting your desired file
                    File exists !, do you want to overwrite it ? [Y/N] n
                    https://github.com/FollyMaddy/RetroPie-Share/commit/268c0e19b0dc974976a15211b8f377a98ca99ee2
                    https://github.com/FollyMaddy/RetroPie-Share/commit/461719f82c8bedbdbf5e08c2369d278c47b23ab0
                    • DTEAMD
                      DTEAM @Folly
                      Nothing on my side. the folder doesn't contain those files.
                      In my /opt/retropie/configs.hdmi/arcade, my retroarch.cfg contain this :
                      input_overlay = "/opt/retropie/configs/all/retroarch/overlay/MAME-Horizontal.cfg"
                      input_overlay_opacity = "1.000000"
                      input_remapping_directory = "/opt/retropie/configs/arcade/"
                      The MAME-Horizontal.cfg doesn't exist
                      Note: For configs.hdmi , it doesn't matter because I have a symbolic link (configs = configs.hdmi ). It should be good.
                      • FollyF
                        Folly @DTEAM
                        @DTEAM said in Development of module-script generator for lr-mess and mame standalone:
                        Ok, that looks good too then.
                        Strange, the script part I added, for setting up the realistic overlays, does nothing with that directory.
                        What's inside that retroarch.cfg will only have effect when you run roms from the arcade folder.
                        I would suggest you remove the overlay lines in that retroarch.cfg.
                        Have you tried my updated script ?
                        I have updated it again to get rid of possible issues with /config.hdmi/ folder
                        I would like you to run it.
                        You only have to do this :
                        CHEATS/ARTWORK/BEZELS > Submenu
                        I hope this is the solution to the problem.
                        When no .zip.cfg and .7z.cfg files come into the /home/pi/RetroPie/roms/realistic then I would like to see your latest log from /home/pi/RetroPie-Setup/logs.
                        Just extract the latest, after you tried.
                        Then we might find the error.
                        Hopefully it will not be necessary.
                        https://github.com/FollyMaddy/RetroPie-Share/commit/ab2643eaaff18007e68b6d0213d0d29457cba121
                        DTEAMD 2 Replies Last reply Reply Quote 0
                        • DTEAMD
                          DTEAM @Folly
                          @Folly
                          It works if I put 720.7z.cfg and 720.zip.cfg directly in
                          /home/pi/RetroPie/roms/arcade/
                          It don't recognize /home/pi/RetroPie/roms/realistic
                          • DTEAMD
                            DTEAM @Folly
                            yes
                            Parameters:
                            Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2016/mamearcade2016_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/baddudes.7z" --appendconfig /dev/shm/retroarch.cfg
                            SOURCE FILE: ../../../../../src/mame/drivers/dec0.cpp
                            PARENT: 0
                            DESCRIPTION: Bad Dudes vs. Dragonninja (US)
                            YEAR: 1988
                            MANUFACTURER: Data East USA
                            Value  not supported for option netdevprovider - falling back to auto
                            ei31.9a NO GOOD DUMP KNOWN
                            WARNING: the machine might not run correctly.
                            MAIN FIRST
                            w:256 h:240 a:1.333333
                            RETRO DEINIT
                            retro_finish begin
                            Average speed: 99.43% (3 seconds)
                            retro exit machine
                            retro_finish end
                            • FollyF
                              Folly @DTEAM
                              @Folly
                              Does the 720.zip.cfg contain this now ? :
                              input_overlay = "/home/pi/RetroPie/downloads/Orionsangels_Arcade_Overlays_For_Retroarch_Part1/overlay/realistic/720.cfg"
                              So the viewport is ok and the bezel is loaded now when running from :
                              • FollyF
                                Folly @DTEAM
                                Not the log I was expecting ;-)
                                  JimmyFromTheBay @DTEAM
                                  @Folly
                                  The rom is fine. When I put this rom in the JAKKS folder, it works. I don't know what's going on with my classich folder. Roms with MAME artwork and retroarch overlays (at the same time) do not work. I'll see what I can do. The problem is 100% on my side, not related to the script.
                                  Solved: It was my emulators.cfg file in /opt/retropie/configs/all . It seems it was corrupted. I deleted everything inside. Now it's fine and I'll start to do MAME artworks (MAME format) for classich with @JIMMYFROMTHEBAY bezels if he agrees.
                                  Fine by me :)
                                  Anything I post on these forums is fair game to be used by anyone for anything, no need to ask.
                                  • FollyF
                                    Folly @JimmyFromTheBay
                                    @JimmyFromTheBay
                                    Can you give the realistic bezels a try ?
                                    • OrionsangelO
                                      Orionsangel
                                      It's fine as long as you give credit and links. I actually welcome it because with what you're doing these bezels can be used by more people.
                                      • FollyF
                                        Folly @Orionsangel
                                        @Orionsangel
                                        Added you in the first post.
                                        I saw that some files are missing from part1.
                                        And I would like to have just 1 pack that I can download and generate files from.
                                        Or perhaps better, have all the files separately on a google drive.
                                        Can we discuss that in an other thread ?
                                        • DTEAMD
                                          DTEAM @Folly
                                          yes
                                          • FollyF
                                            Folly @DTEAM
                                            @DTEAM
                                            So everything works now from the arcade folder.
                                            (apart from bios files not found)
                                            But not from the realistic folder, correct ?
                                            You should check if you have /opt/retropie/config(.hdmi)/realistic containing also the emulators.cfg etc.
                                            And that realistic is found in the es_systems of emulationstation.
