    • DTEAMD
      DTEAM
      @Folly @valerino
      When we use the script, It generate at least 2 packages to install (excepted for gameandwatch, tigerh,all_in1, classich, etc. - systems from my post).
      Sometime It's 4 and more. Would you like to keep it like that or regroup everything in one package line?
      • FollyF
        Folly @DTEAM
        @dteam
        What you mean is can we make 1 script that installs for multiple media and a basename line.
        Indeed I had that same idea a month ago.
        I would be nice if I could change this.
        But this will require a very smart part in the script.
        And I have to take 2 things into account :
        • remember all entry's of 1 system until the last entry and then inject them in the script
        • join the media and cmd parts
        I haven't had an idea on how to change this.
        At the moment it does all one by one, so keeping it simple.
        I will add it to the future ideas.
        Perhaps we get a great idea on improving this.
        DTEAMD FollyF 2 Replies Last reply Reply Quote 0
        • FollyF
          Folly @DTEAM
          @DTEAM
          Can you check this post again about gamate ?
          https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-and-mame-standalone/12
          Seems I didn't added a comment in the first post about a fix.
          I did a test with gmaster (Game Master) and you did the change and It works. You fixed It. You can add a comment in the first post.
          And what about C64 and Atari Jaguar ?
          • DTEAMD
            DTEAM @Folly
            @dteam
            Sorry, my mistake, when we install one system ex.:
            bash $version gmaster
            it generate multiple packages . Do we keep it like this or we converge everythings in one package line in the Retropie package menu. You already answered. Thanks
            • DTEAMD
              DTEAM
              @Folly @valerino
              In the hash folder. We can found 5 .hsi files including two for MSX and MSX2. Do you know if they use It to integrate all computers related to MSX in one system, such as MSX2 or MSX?
              • FollyF
                Folly @DTEAM
                @Folly @valerino
                I opened it with a text editor.
                It contains the <extrainfo> parameter which are the cartridge mapper types for some games to help the emulation.
                I think the MSX2 type will also use the msx.hsi because I didn't find double games in both msx.hsi and msx2.hsi.
                • FollyF
                  Folly @Folly
                  @DTEAM
                  Perhaps I have a better idea.
                  Maybe I can create an empty dummy file for a system that comes along for the first time and then inject all commands one by one later in that dummy file, sort of speak, while checking if the file already exists or not.
                  I will check this solution later when I am in the flow of programming.
                  • FollyF
                    Folly
                    @DTEAM
                    I had a look again at the mame-basename lines from the generated-cmd module scripts.
                    I have doubts about it, can't see exactly what I am missing here,
                    but we should have a deeper look into this.
                    Perhaps we don't have to keep them in there.
                    • V
                      valerino
                      hi guys!
                      here i am :)
                      i will look better later (i have first to improve further the crt/hdmi option in my fork).
                      2 things for now :
                      1. as far as i see, @Folly script can be surely included as something like a menu option in retropie configuration. something like "add mame/mess systems", selecting it will show the systems it may add, you select the ones you want, it will generate the needed lr-scripts.
                      2. i'm understanding you are supporting both mame and lr-mess. why not supporting mame only at this point, which is the 'main' project (afaik mess is discontinued) ? the command line interface anyway should be the same.
                      regards!
                      v.
                      • FollyF
                        Folly @valerino
                        @valerino
                        Welcome to our thread.
                        You are correct, it would be nice to have a menu part from within the Retropie-setup.
                        Do you have an idea on how to construct this ?
                        Though, I think we face a problem, how do we select the ones we want out of more that 7000 systems ?
                        For the mess part, perhaps you know more about that.
                        But as far as I know lr-mess is still alive within the mamedev source.
                        For example -cas support has been added for Philips P2000T which will also work if lr-mess is used.
                        Or is it also possible to load Philips P2000T in lr-mame ?
                        As far as I know it is still splitted :
                        • lr-mame for arcade/console computers
                        • lr-mess for regular computers
                        It would be nice if we can still use a libretro-core which have an advantage with joystick support and retroarch functions.
                        • V
                          valerino @Folly
                          @folly i'm looking just now in the retropie sources if there's some readymade api to make something like a menu with sort-of-checkboxes (i would need it also for my hdmi/crt thing). that would be the ideal solution for your script too. anyway, if it's not there, we can make it.
                          about mame/mess.... afaik mess is discontinued and all is merged into mame (beware, i refer to mame/mess, without considering the retroarch core). so if mess have it, mame should too in the first place. maybe im wrong ?
                          v.
                          • FollyF
                            Folly @valerino
                            @valerino said in Development of module-script generator for lr-mess and mame standalone:
                            Nice, keep me posted.
                            I know it can be confusing, but I think it is still :
                            • standalone mame does both arcade/console and regular
                            • arcade/console and regular are splitted into lr-mame and lr-mess
                            We can do a test.
                            If lr-mame will do what lr-mess does, then we can drop lr-mess.
                            Edit :
                            How do we load, for example, a -cartfor Atari Jaguar with lr-mame, if we want to test ?
                            V DTEAMD 2 Replies Last reply Reply Quote 1
                            • V
                              valerino @Folly
                              @folly never used mame/lr-mame for anything else than arcades, sincerely (since the non-arcade drivers are not comparable to standalone dedicated emulator or lr-cores). anyway, since mame and mess should be essentially the same thing, nothing should change in the command line interface, should be exactly the same.
                              FollyF George SpiggottG 2 Replies Last reply Reply Quote 1
                              • FollyF
                                Folly @valerino
                                @valerino
                                Ok, I did the test.
                                Normally I use your run_mess.sh script for running lr-mess and I have a cmd line that runs directly for, for example handhelds.
                                So I installed lr-mame from the exp packages.
                                Renamed it like lr-mess and placed it in that directory.
                                Tried it just like lr-mess but that didn't work.
                                Also tried with one of the handhelds directly, it said it can't find the driver.
                                So I presume lr-mame has only arcade drivers.
                                • V
                                  valerino @Folly
                                  @folly so you're right. weird. but i'm pretty sure for the standalone version is like i said, only mame is mantained.
                                  • George SpiggottG
                                    George Spiggott @valerino
                                    It would be a boon to Jaguar gamers to only have to install lr-mame to act as an additional emulator choice and also to use the same core for arcade.
                                    Currently running:
                                    Retropie 4.8.9 on a Pi Zero 2W (Overclock Settings: CPU 1400Mhz)
                                    ES-DE on a GMKtec K6 (Windows 11, 32GB RAM)
                                    • FollyF
                                      Folly @valerino
                                      @valerino
                                      Sure you are correct about that.
                                      Edit:
                                      I Looked it up in the scripts :
                                      The main branch in github is : https://github.com/mamedev/mame .
                                      Above branch is forked in the libretro github : https://github.com/libretro/mame
                                      Both branches are mainained.
                                      lr-mame and lr-mess maintained in the libretro/mame source and mame from the mamedev source.
                                      So these three are maintained
                                      • standalone mame ( containing basically mame / mess , compiled from mamedev)
                                      • lr-mame ( containing basically mame(arcade) , compiled from libretro/mame)
                                      • lr-mess ( containing basically mess(non-arcade) , compiled from libretro/mame)
                                      • FollyF
                                        Folly @George Spiggott
                                        @george-spiggott said in Development of module-script generator for lr-mess and mame standalone:
                                        Yes, it would be.
                                        But I think there is a reason that these packages are still splitted.
                                        • DTEAMD
                                          DTEAM @Folly
                                          Exactly what It is. MAME standalone is the most « up to date » one.... suppose to be ...
                                          We should keep both. Separately or not in the official Retropie package menu?.. I don’t know. If you do It separately, the user could install only one of those 2 emulators. It could be interesting.
                                          • V
                                            valerino
                                            ok, the menu thing can be implemented using the dialog api (its builtin in the shell, used throughout retropie menu but not with the checkboxes afaik).
                                            dialog --title "title" \
                                            --checklist "choose options" 0 0 4 \
                                            1 option1 off \
                                            2 option2 on \
                                            3 option3 off \
                                            4 option4 off
                                            then after clicking a button you have the result in $INPUT.
                                            i imagine the checklist could be populated with an array from built from mame output.
