    2.2k Posts 36 Posters 7.2m Views
    • DTEAMD
      DTEAM @Folly
      Have you found your password again ?
      Unfortunately no, but I'll create a new account and and a new Google Drive to transfer all those files. I'll keep the actual structure, only the Google Drive link will change.
      • F
        Folly @DTEAM
        @DTEAM
        Ok, a new one is good too.
        • F Folly referenced this topic on
        • DTEAMD
          DTEAM @Folly
          @Folly
          I received an answer from Google. I was able to reinitiate my password. I’m good to continue with my Google drive.
          • F
            Folly @DTEAM
            @DTEAM
            You are a lucky man.
            Nice that we don't have to change all the links in the script and the posts ;-)
            I have done 6 handheld backgrounds now, hopefully I can do some more this week.
            I also noticed a few missing artwork files like, gnw_pinball (which I added now).
            So we should check for more if we can.
            DTEAMD 2 Replies Last reply Reply Quote 0
            • DTEAMD
              DTEAM @Folly
              @Folly
              Sure, give me a download link when you are ready and I'll put all those files on the Google drive. I'll be available to do that Wednesday.
              • F
                Folly @DTEAM
                @DTEAM
                https://drive.google.com/drive/folders/1YkISUXfKsdHvMv6HACwKhsVHBiGGHCjv
                Progress :
                • DTEAMD
                  DTEAM @Folly
                  This post is deleted!
                  • DTEAMD
                    DTEAM @Folly
                    @Folly
                    Done!
                    • F
                      Folly
                      @duglor said in Creating ES gamelists with media for MAME/lr-mess:
                      @Folly @DTEAM @testudo Does the Mess-Archimedes work now with .adf (not the amiga type) files such as Hamsters? I have not been able to find a bios file or files that have made it run. :(
                      Yes, you can use commands to get all information from MAME as MESS is part of this and lr-mess/lr-mame are basically the same source but libretro-cores that run in RetroArch.
                      For more information on commands you can see here :
                      https://docs.mamedev.org/commandline/commandline-all.html
                      This is an example on how to get information about what media is supported by a default system :
                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listmedia aa310
                      SYSTEM           MEDIA NAME       (brief)    IMAGE FILE EXTENSIONS SUPPORTED
                      aa310            floppydisk       (flop)     .mfi  .dfi  .hfe  .mfm  .td0  .imd  .d77  .d88  .1dd  .cqm  .cqi  .dsk  .ima  .img  .ufi  .360  .ipf  .adf  .apd  .jfd  .ads  .adm  .adl  .ssd  .bbc  .dsd  .st   .msa
                      The .adf format seems to be supported for the archimedes aa310.
                      Not sure how you run Archimedes but I assume you use this project or the older Valerino approach.
                      You can find bios roms in mame-merged. (do a google search)
                      For aa310 you should find aa310.zip and archimedes_keyboard.zip.
                      When using this project place it in :
                      /home/pi/RetroPie/BIOS/mame
                      When using the Valerino module-script, place it in :
                      This command will give the BIOS info of aa310 :
                      pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listroms aa310
                      Or you can find the information in the verbose log, when the are missing, in (after trying to run a game) :
                      /dev/shm/runcommand.log
                      • F
                        Folly
                        @duglor
                        Try reading the first post and view the animated gif on how to install a particular system.
                        If you can't figure it out then we are here to help.
                        Such a help discussion is useful because if something is missing in post 1, for first users, the I can add some useful information.
                        duglorD 2 Replies Last reply Reply Quote 0
                        • duglorD
                          duglor @Folly
                          @Folly Ok- will do--- meanwhile, are you aware of problem where if you load an overlay for the mess-vectrex emulator, it remains there for all further mess programs in different emulators and you have to keep removing the overlay no matter how many times you remove it and save the core file with no overlay in it.
                          the tmpmess core or whatever it may be called :) Every mess related game (no matter what system) loads up with the armor attack vector game background from Vectrex :p
                          • F
                            Folly @duglor
                            @duglor
                            First make your own image, just like @mitu says :
                            https://retropie.org.uk/forum/topic/33443/what-file-tells-the-various-mames-to-use-their-artwork-cfg-files-with-their-matching-name-roms/4
                            duglorD 1 Reply Last reply Reply Quote 0
                            • duglorD
                              duglor @Folly
                              @duglor
                              IT WORKED! I HAVE HAMSTERS AND THE OTHERS WORKING! Thanks for your great help. One thing, though, you forgot to tell me I had to download the .sh file and install it into the pie first :D
                              Thanks so much!!
                              • duglorD
                                duglor @Folly
                                @Folly Well....i have worked with mame since the 90s and helped make 2 drivers with sound emulation. It cannot be that hard. It has to be a cfg or ini file here or there. I just need to know which one and where and i can take it from there as all the art (pngs and cfgs) are there on the pie with the matching rom names. It should be something that autoloads, but it doesn't nor is there something within mame that does it. There is a crazy long 1 by 1 way to it within the retroarch that would take me 4000 minutes do do 1000 games. hehe. ANyway...I'll find the culprit ini or cfg if it's the last thing i do. I wish the guy that built it would just tell me where it is, but he's been hard to get a hold of.
                                • F
                                  Folly @duglor
                                  @duglor
                                  Check your /dev/shm/runcommand.log.
                                  You might find which overlay is loaded.
                                  (turn on verbose mode in the qui => press a key just before a game starts)
                                  Check the overlay folder for default overlays :
                                  /opt/retropie/configs/all/retroarch/overlay
                                  Check your retroarch.cfg if overlays are loaded :
                                  /opt/retropie/configs/all/retroarch.cfg
                                  Or check the driver specific one :
                                  /opt/retropie/configs/<driver>/retroarch.cfg
                                  Or indeed check your ini's.
                                  • duglorD
                                    duglor @Folly
                                    @Folly Thank you. The Archimedes Emulator is running great. I've remapped things to the joypad is well. Very great job there! @testudo
                                    F 2 Replies Last reply Reply Quote 1
                                    • F
                                      Folly @duglor
                                      @duglor
                                      Very nice indeed ;-)
                                      • F
                                        Folly @bbilford83
                                        @bbilford83
                                        I had a look again at your default.cfg for the button mappings.
                                        As I can recall button 9 is used for opening the mame gui.
                                        Button 9 is my "start" button is yours the same ?
                                        What I am missing is that when a joystick button is set in the default.cfg the keyboard tab key will probably not work anymore or am I wrong ?
                                        Btw.
                                        @Retrodade wants to share some button mappings for all_in1.
                                        His post in "Tutorial: Handheld and Plug & Play systems with MAME"
                                        Would you like to test them with your 8bitdo/PiBoy when he shares it ?
                                        Then we could merge the configs.
                                          bbilford83 @Folly
                                          @Folly I don't recall just by the numbers but I know that for me the button to open the MAME UI is the R3 button... like when you push down on the right analog stick. I think, but am not sure, that for me 10 and 11 are start and select. Maybe that means the .cfgs won't be too helpful after all :(.
                                          I actually don't have the all-in-one games setup on my build, so at least as of now I couldn't test them. It seemed like a lot more work for scraping and such because there are so many and honestly I like the Konami/Tiger ones because they're all so similar and the same manufacturer. I could try to get my act together and add them though.
                                          • F
                                            Folly @bbilford83
                                            Well, I like the driver configs you made, there is a lot of similarity between joysticks.
                                            And of-course when you download you get the info for which joystick they are made so basically that shouldn't be a problem.
                                            The default.cfg could be an other story.
                                            Reading your post I think we still have to leave out the default.cfg for now.
                                            I would like to get a good idea to implement a joystick solution as a more uniform solution so configs can be used for more joysticks.
                                            Sadly I still don't have such an idea just yet.
                                            Perhaps it will come in the future ;-)
                                            Indeed, much work.
                                            Let's wait and see what @Retrodade will share.
