    N64 games running slow on Rasberry Pi 4..Help!!
    n64rasberry pi 4retropie
    4 Posts 4 Posters 672 Views
      stephenrossi20
      is there a way to make them run more smooth?? all options are on the table
      lostlessL quicksilverQ DreamcastKidD 3 Replies Last reply Reply Quote 0
      • lostlessL
        lostless @stephenrossi20
        @stephenrossi20 try dropping the resolution to 320x240. N64 is so so even on a pi4 since it’s more gpu/bandwidth based and doesn’t use much cpu and therefore can’t take advantage of the better cpu of the pi4
        • quicksilverQ
          quicksilver @stephenrossi20
          @stephenrossi20 most games run fine for me. Would help if you gave us all the info requested here https://retropie.org.uk/forum/topic/3/read-this-first.
          • DreamcastKidD
            DreamcastKid Banned @stephenrossi20
            @stephenrossi20 said in N64 games running slow on Rasberry Pi 4..Help!!:
            Overclock your GPU and via the Runcommand, select a recommended N64 Emulator, Resolution, Setting per Rom/Game as detailed in this list below ...
            https://docs.google.com/spreadsheets/d/1Rq4shU1RUSdcc7cTVWeORMD-mcO6BwXwQ7TGw8f5_zw/view#gid=1983504515
